  1. Jan 14, 2021 at 8:16 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    He's still a baby. He just thinks he's old.
    Abeyancer and 0xDEADBEEF[QUOTED] like this.
  2. Jan 14, 2021 at 8:17 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'm not sure. The thing to check on would be charging. Typically, charging lithium cells in parallel without a balance charging system will mess them up over the long run. But, these things have built in battery management systems, I suspect they'd probably be okay. Be interesting to check the manual.
    I wonder how they do in the cold as well, not that you have that problem.
    Running Board Man likes this.
  3. Jan 14, 2021 at 8:23 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    My experience in the cold with them has been good in bikes. When I first started using them, the early models would take a few cranks to get the juices flowing before they started. Newer versions had less problems. But, that was in temps no lower than mid to low 30s at the most.
    0xDEADBEEF[QUOTED] likes this.
  4. Jan 14, 2021 at 8:24 PM
    Trueblue357
    Trueblue357 Well-Known Member
    Eloy
    La Quinta
    01 Tacoma 2.7 4x4
    Yes I have both of those codes
    Tons n 40s? Yes I have new oem gas cap
    I assume it is vsv on the canister that needs to be replaced. I didn’t get chance to test it today with procedure you provided earlier but will be doing so in the morning.
  5. Jan 14, 2021 at 8:25 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I could probably make that without yard saling my drivetrain. I have fuckall for spares save for a front hub
    No fuel injection but it's on propane so it will run upside down if that's what it comes to.
    Abeyancer and ColoradoTJ[QUOTED] like this.
  6. Jan 14, 2021 at 8:28 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
  7. Jan 14, 2021 at 8:29 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  8. Jan 14, 2021 at 8:36 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Once you rule out VSVs vacuum hose leaks, filler neck and cannister leaks look for leaks on top of fuel tank. Smoke test or tank vac blowing into fuel filler and spray bottle of soapy water. The metal where gas cap Oring seats should be smooth and shiny.
    Good luck and I hope it's not the fuel pump door on tank top.
    :fingerscrossed:
  9. Jan 14, 2021 at 8:37 PM
    Wulf
    rock raisin
    Have you tried turning it off and going outside for a smoke
    Abeyancer and Silver02Taco like this.
  10. Jan 14, 2021 at 8:47 PM
    Black DOG Lila
    Virginia
  11. Jan 14, 2021 at 8:51 PM
    Trueblue357
    Eloy
    La Quinta
    01 Tacoma 2.7 4x4
  12. Jan 14, 2021 at 8:54 PM
    Wulf
    rock raisin
    All this searching... Can you find my dad?
  13. Jan 14, 2021 at 8:56 PM
    Trueblue357
    Eloy
    La Quinta
    01 Tacoma 2.7 4x4
    Yes I really hope it has nothing to do with fuel tank. You saying to blow through fuel filler and spray gas tank? Fuel pump door seal on top of tank?
  14. Jan 14, 2021 at 8:57 PM
    Trueblue357
    Eloy
    La Quinta
    01 Tacoma 2.7 4x4
    :confused:
    Black DOG Lila likes this.
  15. Jan 14, 2021 at 8:58 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    ColoradoTJ and Black DOG Lila like this.
  16. Jan 14, 2021 at 8:59 PM
    Wulf
    rock raisin
    Abeyancer likes this.
  17. Jan 14, 2021 at 9:01 PM
    Trueblue357
    Eloy
    La Quinta
    01 Tacoma 2.7 4x4
    No thanks
  18. Jan 14, 2021 at 9:02 PM
    0xDEADBEEF
    Its a truck, not your girlfriend.
    :luvya:
  19. Jan 14, 2021 at 9:05 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
  20. Jan 14, 2021 at 9:07 PM
    Wulf
    rock raisin
    What's a girlfriend
    Kwikvette likes this.
