2013 Bluetooth touchscreen install in my 06
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajw1986, Jan 26, 2014.
  1. May 3, 2014 at 1:05 PM
    #41
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    I installed mine today in my 05 access cab the same install as the OP and All went well. :) I should have taken more pictures during the install, but I was in a rush and forgot until I was finished. I couldn't be more happy with the finished product. I did do some trimming to the plastic as talked about with pictures in the other thread to help it fit flush.
    Here is the other thread with pictures of the trimming. I trimmed mine with a dremel tool and did not take it out of the truck.
    http://www.tacomaworld.com/forum/au...igation-retrofit-diy-w-info-part-numbers.html
  2. Jun 26, 2014 at 7:01 AM
    #42
    Coolerman
    Dan
    Rochester, NY
    Has anyone tried connecting a backup camera to one of these 2013 bluetooth touchscreen non/nav units? I am just curious if these support it, and if there are plug n play if you get the right connectors?
  3. Jun 26, 2014 at 7:56 AM
    #43
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    If you have a backup camera already in your truck yes you can get a harness that will divert the cam to the radio screen on the 13 radio. There is a guy on ebay selling them.
    #43
  4. Jun 26, 2014 at 8:51 AM
    #44
    MarkH
    MarkH Well-Known Member
    Mark
    San Jose, CA
    13 PreRunner TRD Off Road
    So I have a question for everyone upgrading to the newer touch screen Toyota stereos, why?
    The stereo is OK, but nothing really special. The display washes out badly in sunlight, and Toyota did not think to design a sun shield. The bluetooth is good, but nothing special. It does not support voice dialing, and is very slow to reconnect with your phone if the connection is dropped for some reason. With all the excellent after market stereos, why spend the money on the factory radio?
  5. Jun 26, 2014 at 8:57 AM
    #45
    BORNWILDGUY
    Rich
    Florida
    I for one like the factory look and still can add an amp/sub and with changing out the door speakers using the factory head unit having a good sounding stereo. The built in navigation on the 2014 deck is pretty good as well and alot better than spending 1k on a good aftermarket deck w nav when you can get the factory 14 w nav for only 450.
  6. Jun 26, 2014 at 9:17 AM
    #46
    MarkH
    Mark
    San Jose, CA
    I agree on the price issue, it will probably be more expensive to go after market. The Alpine FIT kit stereos are all over $1k. I just wish Toyota has seen fit to make this unit fully functional, it has less bluetooth features than the 5 year old stereo I had in my last car. And maybe something to address the issues with sunlight on the screen. Is the Entune any better in sunlight than the base touch screen?
  7. Jun 26, 2014 at 9:33 AM
    #47
    BORNWILDGUY
    Rich
    Florida
    You still get glare on the entune like the base radio. If they would have made the screen more vertical instead go with the contour of the dash the galre would be greatly reduced.
  8. Jun 26, 2014 at 9:45 AM
    #48
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    WTB 2014 Heat Unit If someone has one to sell PM me
  9. Jun 26, 2014 at 11:17 AM
    #49
    MarkH
    Mark
    San Jose, CA
    Maybe changing the screen angle would help, though they could have also designed a sun shade into the trim panel. Anyway, off my rant now.
  10. Jun 26, 2014 at 12:54 PM
    #50
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    I have a 2014 Nav radio in my 2009, and with all the materials and plugs/harnesses I'm in less than an aftermarket and there are no issues with compatibility with my existing backup camera, my steering wheel controls, etc. And it's the clean OEM look.
    Bluetooth connects very fast
    Maps work awesome
    Apps like IHeartRadio and Pandora work like a charm
    No complaints here.
  11. Jun 26, 2014 at 8:43 PM
    #51
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Were did you get the head unit and for how much?
  12. Jun 27, 2014 at 10:50 AM
    #52
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
  13. Jul 5, 2014 at 11:13 PM
    #53
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    For the guys doing the Non-Nav, Non-JBL, Non-Entune radio swap into a truck that didn't come with the USB/Aux hook-up: Where you able to hook up a USB slot by just running a stock harness from the radio to the dash and hooking it to a stock switch?
    Did you need different brackets? I see different posts with people saying they used different brackets. Did the 2013 radio you bought come with brackets, or did you reuse the existing ones?
    Also, to the OP. Did you have to do anything special to get your steering wheel controls to work, or did you just hook up the HU and the existing wiring did the rest?
  14. Jul 6, 2014 at 8:48 AM
    #54
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    The USB port fits into one of the slots below the HVAC controls without any modifications.
  15. Jul 6, 2014 at 8:55 AM
    #55
    SpeedoJosh
    Florida
    Then is it simply running a cord/harness from the switch to the back of the radio?
  16. Jul 6, 2014 at 10:14 AM
    #56
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
  17. Jul 6, 2014 at 10:19 AM
    #57
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
  18. Jul 6, 2014 at 1:25 PM
    #58
    SpeedoJosh
    Florida
    Isn't that for aftermarket head units? I'm curious if I can bypass the hacking of switches/wires, and do a simple plug and play since the new tacomas have the USB slot. I imagine it'd be just as simple as a plug in the back of head unit, then a toyota cord running from the 2013 touch screen to the Toyota USB plug on the dash.
  19. Jul 6, 2014 at 2:12 PM
    #59
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Josh I'm sorry - I'll find the part number for you when I get home. It was an eBay plug. There's a Toyota one but the eBay plug does the truck at a fraction of the price.
    #59
  20. Jul 6, 2014 at 2:14 PM
    #60
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
