4WD system help and information
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Nov 26, 2020.
  1. Nov 26, 2020 at 6:33 PM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I figured I would put together a collection of helpful links on the 4WD System.
    This will mostly be compiled of information already spread throughout TacomaWorld.
    If anyone else has other links or useful information feel free to drop it below.
    I’ll try to update it in this post.
    Big shoutout to @gearcruncher for the excellent information in the first link.
    Troubleshooting and useful information on the 4WD system
    1. https://www.tacomaworld.com/threads/transfer-case-transfer-cases-in-first-and-2nd-gen-trucks.345652/
    2. https://www.tacomaworld.com/threads...er-to-transfer-case-or-diff-actuators.695818/
    3. https://www.tacomaworld.com/threads/4x4-problem-i-cant-resolve.575092/#post-19056025
    4. https://www.tacomaworld.com/threads...w-to-manually-shift-the-transfer-case.703240/
    How to R/R your E-Locker 3rd Member
    https://www.tacomaworld.com/threads...d-installation-of-e-locker-3rd-member.193828/
    Manually lock / Unlock the E-Locker
    Stuck in 4Hi or 4Lo - Manually Lock / Unlock Transfer Case
    https://www.tacomaworld.com/threads...uator-or-t-case-actuator.358059/#post-9674802
    Stuck in 4WD - Manually Unlock The A.D.D.
    https://www.tacomaworld.com/threads...uator-or-t-case-actuator.358059/#post-9674854
    Front Differential Drain and Fill - DIY
    https://www.tacomaworld.com/threads/front-diff-and-transfer-case-oil-change-howto.147631/
    Rear Differential Drain and Fill
    https://www.tacomaworld.com/threads/changing-differential-fluid-a-step-by-step-how-to.24545/
    Remove and Replace Rear Axle and Seal
    https://www.tacomaworld.com/threads/rear-axle-seal-replacement.288348/
    Wheel Bearings and CV Axle DIY
    https://www.tacomaworld.com/threads...e-replace-front-wheel-bearing-2nd-gen.189356/
    CV Axle Removal- Express method
    https://www.tacomaworld.com/threads/cv-axle-replacement-express-method.266309/
    ECGS Bushing and DIY
    https://www.tacomaworld.com/threads/ecgs-bushing-replacement-and-write-up-to-follow.472081/
    Transfer case Actuator - Timing
    https://www.tacomaworld.com/threads/stuck-in-h4.731962/#post-26085475
  2. Jan 17, 2021 at 5:38 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Nice compilation of threads for the 4wd system in our trucks, I'll add this video here someone did showing the insides of the transfer case actuator and a few tips on how to fix it.
    https://www.youtube.com/watch?v=M6qHJPfxyww
