ABS Kill Switch mod for 05+ Offroad EASY WAY! (PICS)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Aug 7, 2011.
  1. Dec 30, 2012 at 11:24 AM
    #141
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I have a locker, so that doesn't apply. :p
  2. Dec 30, 2012 at 7:51 PM
    #142
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Exactly. You can flip the abs kill switch anytime and abs, vsc, and trac are disabled. Turn the switch back off at anytime and the truck goes back to an oem state with all systems working again. And I agree with you on the whole engaging rear diff thing. I doubt it would do anything, but there is no point in risking it. Just flip your abs kill switch off and engage the rear diff
  3. Dec 30, 2012 at 8:09 PM
    #143
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    i had by abs killswitch on then went to L4 and hit my diff lock button :anonymous:
    nothing happened lol
  4. Dec 30, 2012 at 8:11 PM
    #144
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Nothing bad happened or the diff didn't engage or ?
  5. Dec 30, 2012 at 8:22 PM
    #145
    BulletToothTony
    Nothing happened at all, i presume since teh computer thinks its already engaged it wouldnt try to engage it a second time....
    i turned off the killswitch and then turned on the locker and everything worked as normal
  6. Dec 30, 2012 at 8:57 PM
    #146
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    good to know
  7. Jan 5, 2013 at 12:55 PM
    #147
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    05/ 07,09/11Tacoma access cab 4x4
    For 09 TRD Sport with VSC I used pin 4 on same plug which is a green wire ..cut it and installed a switch on the dash..I can turn on and off ABS/ VSC anytime without any issues. Works on the fly without having to reset.
  8. Jan 5, 2013 at 11:23 PM
    #148
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Good to know thanks! :)
  9. Jan 6, 2013 at 7:10 PM
    #149
    Herculean
    Herculean Active Member
    Brandon
    SoCal
    A/R Chambers, BFG KM2's, Donahoes, Fox 2.0, Sliders, flowmaster, some little stuff.
    I didn't read through all 9 previous pages, but I thought I'd mention what I did in case it helps somebody. I already had the simplified locker mod done (the one that grounds out a wire going to the ECU). I was in the dash anyway to fix something else and I didn't have another switch lying around, so I tied the ground side of that existing mod to the ABS disable wire described in this thread. This way I only have to flip the one switch and it disables the nannys. I haven't really tested that the ABS is truly off, but the light cycles on and off as expected and the locker definitely engages. I'll post up if any issues arise with it, but so far it seems to work flawlessly.
  10. Jan 8, 2013 at 12:34 PM
    #150
    oldtommyboy
    oldtommyboy Well-Known Member
    tom
    pa.
    tacome tx pro
    Snowsk8er2- Damn I'm slow but finally did the abs and alt. locker mod,got them hooked up nicely up in the corner of my console.Works great,if its bad out,I can leave the lid up,rest my arm there with my fingers on the switches.
    And if not driving it or goes in for inspection,I lock the console and take the key,none the wiser. Ha ha,thx for the help and crom for the orginal link.
  11. Jan 9, 2013 at 12:25 AM
    #151
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Thanks and congrats on finally doing it. I found a new driving condition in which the abs kill switch will probably get flipped. While heading to the gorman meet last weekend and going through the canyon, vsc tripped on a few times. I assume with the larger tires I put on 2 weeks ago my truck now has more body roll and driving through a windy road at anything faster than "slow" the yaw sensor trips thinking I'm about to start sliding and kicks vsc on braking various wheels trying to run me off the road, when in fact I am just fine. Luckily with the abs kill switch flipped, vsc and trac are also disabled and I will probably end up flipping it really quick anytime I am in a canyon situation. I figure I can drive my own truck by myself, better than it trying to help me when I'm in fact not in any trouble.
    Enough of my rant, here's a :thumbsup:
  12. Jan 9, 2013 at 6:41 AM
    #152
    oldtommyboy
    tom
    pa.
    tacome tx pro
    I hear what your saying. I just mainly plan on using the abs mod when stopping in snow then flip it back off after stopping so i will get back my lsd in the snow and where i put the switch,it should work great. i was out checking everything out yesterday,this will work great.
    Now all i want to do is the inverter and and xtra outlet in the console and finish some leds in the cab and a switch to turn off my dtrl's.
    already did the fog light mod and locks in the bed.
    good times.
  13. Jan 9, 2013 at 7:50 PM
    #153
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Correct on the A-TRAC for sure. Not sure if TRAC is the correct terminology. From what I've read, that described what I was thinking of. A-TRAC is only for 4wd if I'm correct. All I know is that when I flip the abs kill switch, my truck will lock up under braking, and spin the tires in a straight line or around a corner with the back end stepping out.
  14. Jan 9, 2013 at 8:15 PM
    #154
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Exactly. I may have tried to get fancy and use the wrong terminology. When the switch is on, there is no electrical traction control assistance on.
  15. Jan 9, 2013 at 10:24 PM
    #155
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Correct. While in 4L A-TRAC will still work. But at that point, being in 4l already kills abs. This is more of a higher speed (highway or around town) while in the snow in either 2wd or 4h or through the desert/ other off road terrain in 2wd or 4h where this mod will be benefited the most. Or in the case I stated earlier with a lifted/ larger tires truck and canyon driving to get vsc to not kick in around the corners
  16. Jan 9, 2013 at 10:47 PM
    #156
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    From my testing, when hitting the abs kill switch and according to ^^^^ list. You are essentially in either modes 3 or 5 depending on whether or not you are in 2 or 4wd, with the addition of abs being off (which is better anytime you are off road or in the snow in my opinion, and will reduce stopping distance in all circumstances). And the added benefit of not having to come to a complete stop and hold the vsc button for they claim 3+ sec, though it seems more like 8-10 when I've done it
  17. Jan 9, 2013 at 11:05 PM
    #157
    Chickenmunga
    Keizer, Oregon
    Dont count on it. DavidK would never defile the holiest of holies
  18. Jan 10, 2013 at 7:39 AM
    #158
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I'm guessing your method is the same as this one, but with the GREEN wire splice at a different plug location on the harness: http://www.tacomaworld.com/forum/2n...easy-caveman-can-do-abs-disable-mod-pics.html
    I'm trying to determine if/how this ABS-Kill mod can be used in conjunction
    with the Yellow Wire Mod on my '11 Sport (w/ VSC & TRAC). Can anyone confirm this, has anyone tried?
  19. Jan 10, 2013 at 7:49 AM
    #159
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    This statement is wrong. I have a 4WD tacoma and do not have vsc or trac.
  20. Jan 10, 2013 at 7:58 AM
    #160
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    What model and year are you? I believe nothing pre-09 had vsc or trac
