Bad vibration between 30 and 40 while accelerating. Need help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smurf rig329, Nov 12, 2017.
  1. Nov 12, 2017 at 11:28 PM
    Smurf rig329
    Smurf rig329 [OP] Member
    Jorge
    2010 blue tacome sport
    33 in buckshot maxxis mudders, it has a 2 inch rough country leveling kit on it. Pioneer toich screen radio.
    Idk what is causing this but whebever i accelerate from a stop to 60, it will shake from 30 to 40. Can anyone point me in the direction to fixing the issue. Thanks
  2. Nov 12, 2017 at 11:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Has anything changed just before this started? Such as New tires or rims or a lift?
    If not I would suspect a worn universal joint. If one is bad replace them all.
  3. Nov 13, 2017 at 4:36 AM
    gearcruncher
    Canadain bumper technician
    Lets look at some Vibration diagnostics . Anytime someone asks a vibration question , I copy and paste this .
    I believe there are at very minimum at least 12 different vibration issues assosiated with the Tacoma and all the vibrations / shudders get mixed into the same pot when members start posting leaving members scratching their heads .
    These are some diagnostics to try . If you bring your truck to a shop , they will be trying most of these to narrow your vibration down .
    Have you greased your driveline ?http://www.tacomaworld.com/forum/tec...rks-total.html
    Do you know how to grease your driveline properly http://aftermarket.federalmogul.com/...%20FAQ%27s.pdf
    Have you slid under the truck and inspected to see if any driveshaft weights have fallen off ?
    Have you checked your carrier bearing https://www.tacomaworld.com/threads/how-to-replacing-carrier-bearing.260283/
    Does the truck vibrate in park or neutral and does the vibration change with accelerator pedal ? This is a misfire test for your engine
    Does the truck vibrate while holding the brakes and hitting the gas - Automatic ? This is also a misfire test for your engine under load
    Does the truck vibrate in neutral at a stand still ?or coasting in neutral ?
    Does the truck vibrate in 4x4 ?
    Does the truck " Only vibrate " from 1st to 2nd gear ? https://www.tacomaworld.com/threads/vibration-when-accelerating-from-stop-anyone-fixed-it.300155/
    Does the truck only vibrate in 2 wheel drive ?https://www.tacomaworld.com/threads...differential-bearing-vibration-thread.152173/
    Does the truck vibrate with the serpentine belt removed ?
    Does the truck vibrate cold or hot ?
    Does the truck vibrate if you select neutral and coast to a slow roll without using the brakes ? What happens when you turn the truck off in Neutral at highway speed ? Can you still feel the vibration ?
    Does the truck clunk over bumps ?https://www.tacomaworld.com/threads/tacoma-loose-bed-design-flaw-explanation.388873/
    Does the truck vibrate as you are braking ? When was your last brake job ? Consider the front rotors may be warped or the rear drums are out of round .
    Does the truck vibrate with weight in the truck or empty ?
    Does the truck vibrate while upshifting ? Have you checked your trans fluid ?
    Does the truck vibrate while downshifting ? Have you checked your trans fluid ?
    When was your last transmission fluid service ?
    Is the vibration caused by your torque converter ? Tapping the brake pedal at highway speeds will release the torque converter clutch . You are not actually hitting the brakes ,but manipulating the brake switch . If the vibration goes away you can expect a misfire or a converter clutch issue .
    Read here for more information regarding automatic transmission diagnostics
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
    Now that you have a lift kit installed the truck vibrates . Did you cancel your drive line angles ?
    Have you looked at the condition of your tires ? Toyota says to rotate every 5000 miles .Tacoma tires must be road forced balanced using the Haweka adapter on the tire machine [​IMG]tsu00296.pdf
    When was the last time you rotated your tires ? Are you using LUG centric aftermarket wheels that are incredibly difficult to balance ? have you considered " HUB centric rings " http://www.amazon.ca/s/?ie=UTF8&key...vptwo=&hvqmt=e&hvdev=c&ref=pd_sl_7ybe1f1pby_e
    Have the balance weights fallen off the tires ?
    A good vibration technician can tell immediately if your vibration is caused by the rotating speed of your wheels or by the rotating speed of your driveshaft .
    If you go through this list carefully , you should be able to narrow down where the problem is .
    The proper and only way to test for bad universal joints is with the driveshaft removed . You cant tell if the universal joints are seized or tight spots with the driveshaft on the truck . You may see play in the universal joints , but you wont be able to properly check the u-joints without removing the driveshaft .All it takes to create a vibration is one seized universal cup and there are 4 cups within each joint .
    With this said , you cant tell if that cup is seized with the driveshaft connected .
    Removing the driveshaft and manipulate each universal joint by hand from side to side feeling for tight spots as you go is the only way to check for bad u joints
    If you beleive its bad motor mounts or transmission mounts , grab a big pry bar and pry at the mounts to see if the rubber is torn or weak .
    CANCEL DRIVELINE ANGLES http://www.tacomaworld.com/forum/2nd...tion-free.html
    Taco Nation and Jimmyh like this.
  4. Nov 13, 2017 at 6:09 AM
    Smurf rig329
    Jorge
    Thank you @gearcruncher i will be looking into all of those. I want to say that it will wind up being a drive line problem.
