Forward video feed monitoring on OEM screen? I want a Transparent Hood!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OnHartung'sRoad, Mar 15, 2018.
  1. Mar 15, 2018 at 9:22 AM
    OnHartung'sRoad
    OnHartung'sRoad [OP] -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I’m thinking about an “transparent hood” project sort of like Rover’s where my headunit screen could be easily temporarily switched to a forward looking video cam as an aid for off-roading around rocks and cresting hills, etc., because you know how fun it is to take the leap of faith when you cant see what is in front of you in those situations.
    What mods have you you used for this? Does anyone have experience with the Beats Sonic Harness to do it? What model works with a 2017 Entune unit?
    Any others?
    Thanks!
    SandyTaco4x4 likes this.
  2. Mar 15, 2018 at 9:36 AM
    Taco16LB
    Taco16LB Well-Known Member
  3. Mar 15, 2018 at 9:39 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    OnHartung'sRoad[OP] likes this.
  4. Mar 15, 2018 at 9:43 AM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
  5. Mar 15, 2018 at 9:49 AM
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    I used the kit from anytime backup camera and a DPDT toggle switch to select front camera, normal, rear camera. If you're pulling the etune unit apart anyway, it's a good time to also install the navigation override switch. Anytime backup recently has an add-on to do that as well (I just cut and wired in a switch to pin 17). Something to consider.
  6. Mar 15, 2018 at 11:04 AM
    KENNY
    KENNY Well-Known Member
    Anyone have any insight how i can hook up a switch for my front camera using the VIMTY-05? I've done the diode for the rear anytime switch, but not sure how to do that for the front using this harness (holding the steering controls and navigating through the screen is supid.)
  7. Mar 15, 2018 at 11:34 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  8. Mar 15, 2018 at 2:36 PM
    OnHartung'sRoad
    What pins are the video signals on that kit? Looks like a great option! Least expensive, too, because I can put a multi-channel switcher on it and get a split view of front and rear too (thinking of view behind trailer) :)
    tcjacado likes this.
  9. Mar 16, 2018 at 7:08 AM
    Hextall
    NH
    17 Inferno OR DCSB
    I don't know for sure, but here's a bunch of threads I bookmarked when researching this mod. The info lives in these threads. with the kit, I didn't much have to think about it, but I like knowing what I was plugging in where and what it did.
    Just note... the anytime backup camera kit doesn't have a camera. I bought the iNewcow one from Amazon that fits in the toyota logo on the grill.
    https://www.tacomaworld.com/threads...ass-homelink-smartphone-mirroring-mod.473033/
    https://www.tacomaworld.com/threads/trd-pro-grill-with-front-camera.524832/#post-16847374
    https://www.tacomaworld.com/threads...ter-and-oem-style-camera-gps-switches.458293/
    https://www.tacomaworld.com/threads...one-mirroring-mod.473033/page-7#post-15472320
    http://www.toyotanation.com/forum/3...015-highlander-navi-phone-lockout-bypass.html
  10. Mar 16, 2018 at 7:09 AM
    OnHartung'sRoad
    Thank you for your help on it!
    Hextall[QUOTED] likes this.
  11. Mar 21, 2018 at 9:17 PM
    N2DesignsInc
    Los Angeles, CA
    I'm ignorant on the subject, but what's the function of a navigation override for? To replace the normal navi display/position with that of a live camera feed? (I am just guessing here)
  12. Mar 21, 2018 at 9:17 PM
    N2DesignsInc
    Los Angeles, CA
  13. Mar 21, 2018 at 9:29 PM
    OnHartung'sRoad
    Navi overide lets you press in coordinates and other stuff while driving, otherwise those functions are locked while the truck is moving.
    The other switch just flips to camera view as if you are going into reverse and the camera display switches on.
  14. Mar 21, 2018 at 9:43 PM
    N2DesignsInc
    Los Angeles, CA
    Do you know if this override allows us to read text messages on our entune when driving too?
  15. Mar 21, 2018 at 9:54 PM
    OnHartung'sRoad
    The only way I know is shown on @Taco16LB ‘s thread #2 above...
  16. Mar 21, 2018 at 10:02 PM
    tcjacado
    tcjacado Well-Known Member
    Mine reads my texts to me.
  17. Mar 21, 2018 at 10:04 PM
    OnHartung'sRoad
    Yeah, it does on mine too- I use that mode occasionally, but reading them on the screen while driving? No, thanks.
  18. Mar 21, 2018 at 10:05 PM
    tcjacado
    I don't like having to lean over to see the entune system. I would rather just hold my phone or leave it on its dash mount.
  19. Mar 22, 2018 at 4:43 AM
    Hextall
    NH
    17 Inferno OR DCSB
    There are several things in the head unit that get shut off while driving. I installed the switch primarily to allow a passenger to use these options while we are driving.
    An example is the fuel app that finds nearby gas stations will only show page one while driving (I believe), so break that circuit and you can navigate to more results.. Other apps like yelp are probably the same way.. Also, I have a Google home and my daughter pranks me by putting goofy stations on Pandora .. Which then show up on my trucks Pandora (Dora the explorer station is the latest). With the nav override I can quickly delete the station and take back control of my life (ha).
    Maybe instead of navigation Override it should be called motion chicanery.
    tonered and Bastek like this.
