Hidden CB Install *pics*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Jun 4, 2012.
  1. Jun 4, 2012 at 8:25 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    CB mount (upsidedown in pic) can be ordered from Eric (RelentlessTaco)
    Other Relentless Fab. products([​IMG]1 2 3 ... Last Page) by RelentlessTaco
    [​IMG]RelentlessTaco 06-04-2010 11:05 AM
  2. Jun 4, 2012 at 8:38 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    +1 Very clean install! I love clean installs like that!
  3. Jun 4, 2012 at 8:49 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Nice op clean job
  4. Jun 4, 2012 at 9:05 AM
    white toy taco
    white toy taco 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
    yea you did an awesome job OP
  5. Jun 4, 2012 at 9:12 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  6. Jun 4, 2012 at 9:16 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Nice install...
    Couple tips:
    *Never run CB coax near any other wires as it will interfere with reception. Having it under the main wire harness is a big no no.
    *CB mounted in center consul will not be heard on the trails (I know - learned the hard way). I ended up putting an aux speaker on mine.
  7. Jun 4, 2012 at 9:19 AM
    MonkeyProof
    SoCal- SGV
    X2 on the aux speakers..I have one for the CB and one ready to mount for the 2meter radio.
  8. Jun 4, 2012 at 9:24 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Good tip, didn't know that about the coax.
    And he put a aux speaker just above the gas pedel.
  9. Jun 4, 2012 at 9:32 AM
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    The rubber grommet in the firewall is so thick that I doubt any current will penetrate it. It tuned just fine, so I hope it should be good.
    *A little more research shows that you should not experience any interference or bleed as long as the wires are properly insulated and shielded.
  10. Jun 4, 2012 at 10:31 AM
    XXXX
    sKiP
    05 Prius
    As is always the case, but because CB coax is what it is & the highest rating you can get is 95% shielding if memory serves me correctly. Because coax is ALSO part of the antenna you can't get 100% shielded thus the signal will always get interference. My memory might be wrong, but I'm 99% sure that was the case when I researched 2 years ago.
    Not breaking your balls, just don't want people to take all that time then turn on a fm/am radio station and their CB cuts out or has engine noise.
    In most cases installers tell you to not even run coax on the same side of the door jamb/wire chase if other wires are present.
  11. Jun 4, 2012 at 11:01 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    In my case it'll be stored there but be out of console when in use. (it's the all in mic type)
  12. Jun 4, 2012 at 11:27 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Gotcha :thumbsup:
    I appreciate the feedback and insight. My setup sounds pretty good for what it is and I hope the same for anyone else who is attempting this install.
  13. Jun 4, 2012 at 1:17 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Nice clean install Ben
  14. Jun 4, 2012 at 1:44 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks Mitch!
  15. Jun 4, 2012 at 2:09 PM
    #35
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    nice install!
  16. Jun 4, 2012 at 7:15 PM
    #36
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Added a couple more pics...
  17. Jun 4, 2012 at 8:55 PM
    #37
    JayDirt
    JayDirt I owe it all to little chocolate donuts
    Nice work...!
  18. Jun 4, 2012 at 9:01 PM
    #38
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    subd
  19. Jun 5, 2012 at 4:13 AM
    #39
    Hubs
    Hubs Well-Known Member
    Nice work! Only concern would be wind noise from antenna...had a CB antenna on my old Trooper years ago that was mounted on right rear roof rack on top that screamed/howled while at highway speeds. Drove me nuts!
  20. Jun 5, 2012 at 6:00 AM
    #40
    IndianTaco
    IndianTaco Well-Known Member
    Looks great nice write up!
