Hobie Fishing Edition
Discussion in '3rd Gen. Tacomas (2016-2023)' started by silasvirus82, Jun 9, 2017.
  1. May 3, 2018 at 6:27 AM
    #81
    silasvirus82
    silasvirus82 [OP] Well-Known Member
    NC
    3rd Gen Off-Road DCLB
    Cut the legs down on a Teton cot. I choose this one because of the length, most are too long to fit in a 6' bed. I also really like the width of this one, it's proven to be super comfortable.
    Blackout14 and Phoosa like this.
  2. May 3, 2018 at 6:46 AM
    #82
    Yukon
    Yukon Well-Known Member
    2009 Magnetic Grey SR5
    How have the quick fist's been holding up on your tank in the bed? Do you see or feel the water sloshing around? Does the pipe move? I am trying to decide to either make one for inside my bed or put one on my roof rack. I was thinking of going 4 inch pvc at 5 feet long would give about 3 gallons of water on the rack, but considering going 6 inch pipe and a 3 feet long in the bed.
  3. May 3, 2018 at 7:09 AM
    #83
    silasvirus82
    NC
    Concerning the quickfists, so far so good. I think they are rated for like 50 lbs each, and 8 gallons of water plus the weight of the tank is less than 100 lbs total. I'm definitely going to keep an eye on them long term though and watch for cracks or any sign of old age that will weaken them.
    I generally either have my tanks completely full, or completely empty, so sloshing isn't an issue. If you're going with smaller dia pipe like 4", I can't imagine it being a problem. One thing I did that may not be documented, is I added a rubber strip to the underside of the bedside tank, that protects both the tank and wheel well. My tank actually rests on the wheel well, which reduces stress on the quickfists.
    I don't know how you plan to pressurize, but at 30 psi I get a really nice blast of water. That 8 gallons goes quick (about 5 mins), so consider that when sizing your tank or spray nozzles. The shower nozzle for the roof rack tank is a super low-flow showerhead, and I'm guessing at 30 psi I probably have around 6-7 mins. https://www.amazon.com/High-Sierras...525356469&sr=8-9&keywords=low+flow+showerhead
    Yukon[QUOTED] likes this.
  4. May 3, 2018 at 7:17 AM
    #84
    Yukon
    Thanks for the update about the quick fists and about it resting on the wheel well. If I go with the 6 inch in the bed, I'll probably get a low flow 1 gpa pump (like folks use for atv sprayers) and use that. If I go the roof rack I'll just leave it gravity flow, maybe put a tire valve on it for a hand pump or hooking into a portable compressor. Not sure which way I want to go yet, money is defiantly a factor though :annoyed:
  5. May 3, 2018 at 7:25 AM
    #85
    silasvirus82
    NC
    A water pump is going to be you're best option price wise, and exactly the route I would have gone if I didn't have OBA. Consider a pressure relief valve, or remove the fill cap, when your pumping, otherwise it will create a vacuum. Same goes if using it with gravity. If I open the valves on either tank with the fill cap tight, water barely trickles out.
  6. May 3, 2018 at 7:41 AM
    #86
    Yukon
    I was defiantly going to use a relieve valve whichever way I end up going. Thanks for the feedback!
    I have a old town predator mx I fish with, hopefully upgrading to the pdl version or going for a hobie in the next year(ish). It's tough trying to fish a certain spot and constantly paddling/fishing, especially in a current or keeping up with a bait ball.
    Blackout14 likes this.
  7. May 3, 2018 at 7:58 AM
    #87
    silasvirus82
    NC
    Hell yea, peddle power is definitely a major upgrade if you're fishing. I used an old Dagger sit-on-top from maybe 2001 till I bought my Hobie new in 2015. That boat has some serious mojo encrusted on it, and I still love paddling it occasionally. There are so many great options out there now, nothing like even 5 years ago. The Hobie Compass seems like a fantastic boat for the money. Tight lines!
    Blackout14 and Yukon[QUOTED] like this.
  8. May 5, 2018 at 3:03 PM
    #88
    silasvirus82
    NC
    Caught my first snakehead today. This one is 35" and about 15 lbs. I landed 2 others over 30" and 3 mid-20s today, plus a handful of nice bass, and lost about the same. These things are a blast to catch! Super aggressive close to the boat and they throw hooks regularly.
    Blackout14, Crimson Flam3s and Maint1 like this.
  9. May 6, 2018 at 4:30 PM
    #89
    Maint1
    Maint1 Well-Known Member
    NC
    2019 DCLB Quicksand
    17" matte black 4Runner rims
    What do you all do with the snakeheads?
  10. May 6, 2018 at 5:06 PM
    #90
    silasvirus82
    NC
    Eat um, or give them away to eat. I’ve got Asian neighbors on both sides of me, they won’t go to waste, haha.
  11. May 25, 2018 at 8:08 AM
    #91
    silasvirus82
    NC
    Ordered vanity plates:
    Scott B. likes this.
  12. Jul 2, 2018 at 6:30 AM
    #92
    silasvirus82
    NC
    Giving the Bixpy a try on my Outback. I always made fun of the guys with Torqeedos, now I'm just a hypocrite. During the initial test run (with a full load of gear) I basically got a 1 mph boost at all speeds while using the Mirage Drive, and the motor by itself pushed me 3.5 mph at 1/2 throttle and 4.5 mph at full. Realistic top speed with the motor and Mirage Drive was 5.5 mph, but 4.5-5 mph seemed to be the sweet spot. After 4 hours on the water and a total distance of 8 miles for the day I still had 4/5 left on the battery meter! I did not use the motor while fishing, but the bulk of my travel between spots it was running at various speeds. This unit costs $1099 for the universal setup and included everything you see here plus the steering system which I did not install. I opted to lock the steering forward since I'm keeping the sailing rudder functional. They also offer a rudder mount or Mirage Drive mount for those interested.
  13. Jul 2, 2018 at 11:25 AM
    #93
    silasvirus82
    NC
    Not to steer you one way or another, but the thought of losing the mirage drive was never an option for me. The motor is good to get me where I want to go, but the mirage drive is for fishing.
  14. Jul 2, 2018 at 11:26 AM
    #94
    Brandon2330
    Brandon2330 Well-Known Member
    Brandon
    Houston, TX
    2016 Tacoma TRD Off-Road 4x4
    OME Lift & Leer 100XL top
    What’s that on the hood?
  15. Jul 2, 2018 at 11:31 AM
    #95
    bunz559
    bunz559 Well-Known Member
    Fresno, CA
    2018 Tacoma TRD Off-Road
    First full day with the Tacoma this past Saturday and fishing was on my mind! Great way to break it in hauling and catching this beauty!
    silasvirus82[OP] and rollin904 like this.
  16. Jul 2, 2018 at 11:35 AM
    #96
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Been after striper lately? I've got a close relative to yours (Slayer Propel) and I've been wanting to get on the water within the next weekend or two to chase some fish
  17. Jul 2, 2018 at 11:40 AM
    #97
    silasvirus82
    NC
    Louvers from VRaptor Speedworks installed by yours truly. 3rd Gen Hood Louvers
    No stripers recently, getting way too hot. I fish for those early Spring and Fall when the bite is better. Summer is snakehead and shooting season at my house.
  18. Jul 2, 2018 at 11:49 AM
    #98
    silasvirus82
    NC
    How the heck you building a LiFePO battery for that low cost? I have a 20aH lithium that powers my fish finder, livewell, and lights, and I think it was over $200 by itself.
  19. Jul 2, 2018 at 12:06 PM
    #99
    silasvirus82
    NC
    Wow, you've got to create a post for that. Can you make me one? ;)
  20. Jul 2, 2018 at 12:11 PM
    #100
    silasvirus82
    NC
    I'd like to have a 100ah deep cycle for camping trips and home emergencies. Considering that's a $850 battery, that ain't gonna happen. I love making stuff, but electronics and batteries are not my forte.
