Non plastic bed cleats...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bdb3011, Nov 12, 2013.
  1. Nov 12, 2013 at 9:02 AM
    bdb3011
    bdb3011 [OP] Active Member
    Brandon
    Hood River, OR
    '10 Access Cab, V6, 6spd SR5
  2. Nov 12, 2013 at 9:11 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
  3. Nov 12, 2013 at 9:13 AM
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    You can make those for a whole hell of a lot cheaper than 30 buck
  4. Nov 12, 2013 at 9:15 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I have some T-Slot (fastenal, also gorilla) nuts in my rails with Eyelet bolts like those through them. Held one dirtbike just fine. Was going down rocky and very pitched trails before we unloaded the bike.
  5. Nov 12, 2013 at 9:15 AM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    This. And my dirt bike is fine with OEM cleats. :notsure: I even hauled an ATV with them. As long as they are locked correctly in the slots, I don't see a problem.
  6. Nov 12, 2013 at 9:16 AM
    Aw9d
    Aw9d That one guy
    I've lugged ATV's around with them as well and never had issues or had any concern.
  7. Nov 12, 2013 at 10:22 AM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Your bed is plastic, so why do the cleats bother you? Could always add D-Rings in the bed...
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/28533-installed-d-rings-bed-pics.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/246978-alternative-location-d-rings-bed.html
    Also, that ebay link is a rip. Just go to Home Depot....
    Superstrut 3/8 in. Channel Spring Nuts (5 for <$5)
    3/8 in. eye bolt (5 for <$5)
    5 3/8 washers (really cheap)
    I doubt you'd spend $12 for a set of 5 but your plastic cleats will work better.
  8. Nov 12, 2013 at 10:29 AM
    magnum922
    magnum922 Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    I have had mine locked correctly and pull out of the track while driving a couple of times. I now use rings i installed in the bed lower front bed and the d rings in the back.
  9. Nov 12, 2013 at 10:31 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Fiber-reinforced Sheet-Molded Composite is stronger than plastic.
  10. Nov 12, 2013 at 11:16 AM
    bdb3011
    Brandon
    Hood River, OR
    I like it, the only thing that isn't perfect is that the d-ring mod puts the d-rings inboard from the edge of the bed. This would be just fine for one bike, but with two the front wheels of each bick would be right on top of the d-rings.
    Think i'm going to do that Mod anyway. Looks good and easy.
    As far as quads go... Seems like an apples and oranges comparison. You don't have to hold the quad up... much like when you're riding it. :D :stirthepot:
    Thanks for all the quick replies and advice!
    B-
  11. Nov 12, 2013 at 11:28 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
  12. Nov 12, 2013 at 11:41 AM
    bdb3011
    Brandon
    Hood River, OR
