Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jan 24, 2013 at 4:42 AM
    #261
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Hmm when goes over speed bump clank. The fact that he has 5100s might disprove the over extended shock theory if it isn't the sway bar or other issues
  2. Jan 24, 2013 at 5:58 AM
    #262
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You guys getting the clank, have you checked to make sure your LCA bolts are torqued? Even if they're tight, but not tightened to spec, it can cause a clunk when you hit a bump.
  3. Jan 24, 2013 at 6:06 AM
    #263
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    So got another question for you gents. Those of you who have the Dakar OME leaf packs, have you removed any leaves from it? If so, is it just the overload you remove? And what kind of lift is that giving you?
  4. Jan 24, 2013 at 6:58 AM
    #264
    evanmb31
    evan
    connecticut
    09 trd off road
    I removed the 3rd leaf from the top. My rear is a half inch higher than the front with 885s and no top plate spacer. You can also remove the upper overload but that will only reduce the lift by the thickness of the overload leaf (5/8"?)
  5. Jan 24, 2013 at 7:17 AM
    #265
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Removing the third leaf down is a similar height reduction , 5/8"
  6. Jan 24, 2013 at 7:28 AM
    #266
    OZ-T
    Peter North
    British Columbia
    Are all you " over speed bump goes clank " guys still running stock bumpstops ?
  7. Jan 24, 2013 at 7:30 AM
    #267
    Pugga
    Massachusetts
    Where you going with that one, you think the shock is bottoming out?? :confused:
  8. Jan 24, 2013 at 7:38 AM
    #268
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    Now remember guys, most people having the clunk noise is when your wheels go down the bump not when you initially hit the supported bump.
  9. Jan 24, 2013 at 7:42 AM
    #269
    evanmb31
    evan
    connecticut
    09 trd off road
    Mine ended up reducing the lift a little more based on the averages on your thread. Im at about 23.5 in the rear
  10. Jan 24, 2013 at 8:10 AM
    #270
    OZ-T
    Peter North
    British Columbia
    Just trying to find a commonality in the set ups that this issue is related to
    So far the only thing that everyone seems to share is OME coils
    Seeing how the OME shocks and 5100 shocks have different coil seats , and people are getting this noise with stock UCA's as well as aftermarket UCA's , the only common denominator seems to be the coil , and I'm not sure how a coil is going to be responsible for this noise
  11. Jan 24, 2013 at 8:14 AM
    #271
    Pugga
    Massachusetts
    I'd be willing to bet it's coil orientation and something is contacting the coil or somethings not tightened down like the LCA bolts.
  12. Jan 24, 2013 at 9:56 AM
    #272
    AllMountainToy
    AllMountainToy Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    I removed the 3rd leaf and I am at 23 3/8 so almost 23.5. The ride is amazing and with the 885s up front with the 1/4" top spacer I am only a 1/16 of an inch difference from front to rear
  13. Jan 24, 2013 at 10:06 AM
    #273
    george2pak
    george2pak Well-Known Member
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    Brute Force Fab front& rear bumper with winch, sliders, skid plates by Relentless, tires 285/75/16" , wheels by SCS , CB Stryker SR497 etc
  14. Jan 24, 2013 at 10:09 AM
    #274
    OZ-T
    Peter North
    British Columbia
  15. Jan 24, 2013 at 10:37 AM
    #275
    george2pak
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
  16. Jan 24, 2013 at 11:14 AM
    #276
    GreatBasinTaco
    GreatBasinTaco Well-Known Member
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    OME 886's, Dakars with one overload removed, OME shocks all 4 corners. No idea what I got out of the lift, but I'm at 23 1/2" up front and 24" in the rear. No armor other than the ARB, still have the sway bar, but it's about to come off due to spring contact issues. 255/85 km2s no rubbing, no trimming.
    BandanaBerg likes this.
  17. Jan 24, 2013 at 11:15 AM
    #277
    4Wheelin4Banger
    4Wheelin4Banger [OP] Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Bite it!
  18. Jan 24, 2013 at 11:20 AM
    #278
    OZ-T
    Peter North
    British Columbia
    Official pdf files from ARB / OME ?
    You could email them
    http://arbusa.com/Contact.aspx
  19. Jan 24, 2013 at 11:23 AM
    #279
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Sharp lookin truck :thumbsup:
  20. Jan 24, 2013 at 11:23 AM
    #280
    4Wheelin4Banger
    Randy
    Looks good Mike,
    Swing by our local threads & say :wave: hi.
    Reno and surrounding areas: Official spotted, BS, and meets thread([​IMG]1 2 3 ... Last Page)
    775 Tacomas([​IMG]1 2 3 ... Last Page)
