R12: Bi-Xenon Projector Retrofit Kits
Discussion in 'Group Buys' started by TRSAndrew, Dec 28, 2012.
Thread Status:
Not open for further replies.
  1. Jan 1, 2013 at 11:19 AM
    Scotty3
    Scotty3 Well-Known Member
    charley
    Elverta
    2011 4WD TRD Off Road
    too many to list
    im interested in getting in on another round but will have to wait a few weeks for funds to recover from the holidays.
  2. Jan 1, 2013 at 12:32 PM
    MarkM
    MarkM Well-Known Member
    Mark
    Indiana
    2017 TRD Pro / BRO
    I want in, how hard is the install?
  3. Jan 1, 2013 at 1:08 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Looks like this one is going to take a while to fill up.
    I figured it would go quick because it's been a couple of months and the last two filled quickly, but I think people are waiting for tax refunds.
  4. Jan 1, 2013 at 1:17 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    http://www.tacomaworld.com/forum/lighting/212064-hid-retrofit-2009-tacoma-extended-cab.html
    http://www.tacomaworld.com/forum/lighting/207026-morimoto-mini-stage-iii-kit-h1-step-step-pics.html
    http://www.tacomaworld.com/forum/lighting/252938-hid-conversion-02-taco.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/231575-retrofit-help-those-need.html
    http://www.tacomaworld.com/forum/2n...012-retrofit-bhlm-halos-finally-finished.html
    The first two threads really cover you.
    The D2S and H1 are both the same procedure. The projector housings replace the stock bulb. You just need to open up the headlight housings and install them.
    The FX-R are more involved and are going to take some trial and error getting them aimed properly before locking everything down and sealing up the housings.
    I'm very happy with my D2S conversion.
  5. Jan 1, 2013 at 1:19 PM
    fallon
    fallon Well-Known Member
    Colorado
    TRD Sport 4x4
    Look at the link I posted a couple posts ago. That's the best resource I've found on how to install the FX-Rs. Mini's will be about the same without having to cut the bowl.
    Remove headlights
    Bake in oven for a few minutes
    Pull lenses off the rest of the housing
    BLHM (optional but easy while the housing is open)
    Bake painted stuff in the oven for a bit to cure paint & prevent your lights from fogging later (if you do a BLHM)
    Cut out some of the bowl (for FX-Rs only)
    Mount & align projectors
    Glue &/or bolt projectors to the bowl (RX-Rs only)
    Mount ballasts & wire things up
    Mount headlights in the vehicle without the lenses
    Align the new lights (more precisely make sure that you didn't mess anything up preventing you from properly aligning them & having to bake things apart later)
    Pull headlights
    Heat & reseal headlights
    Mount headlights
    Fiddle with the alignment a bit to get it perfect
    It took me 2 weekends at a leisurely pace.... Including re-splitting a light due to stupidly not seating a ball & socket joint (took less than an hour as I had things pretty figured out by then).
    Also the Gatling gun shrouds don't fit the FX-Rs well, get a different shroud if you are going with FX-Rs.
  6. Jan 1, 2013 at 8:49 PM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    Im in... this is my christmas present :) i was just waiting for the next group buy!
    1 - g35man - 2 FXR
    2 - pakow - 1 FXR
    3 - rkarabao- 1 D2S
    4 - logcabinwc- either d25 or H1
    5 -
    6 -
    7 -
    8 -
    9 -
    10 -
    11 -
    12 -
    13 -
    14 -
    15 -
    16 -
    17 -
    18 -
    19 -
    20 -
    21 -
    22 -
    23 -
    24 -
    25 -
    26 -
    27 -
    28 -
    29 -
    30 - Rich91710 - 1 D2S (Depending on when the buy happens, don't rely on me for the 25 count right now)
    Now which one do you all think I should get? D25 or H1? Install seems about the same... So what are the main differences?
  7. Jan 1, 2013 at 8:54 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    D2S is an industry-standard lamp. The Philips and OSRAM are the same lamps used by automakers... Philips is covered by the GB.
    H1 is only available in Morimoto lamps.
    IMHO, D2S has a more even pattern, H1 has more of a hot spot, but some prefer that for better projection down the road... I like better coverage out the sides.
    Also, the H1 has a near-field cutoff that is not present on the D2S.. creates a dark area in front of the vehicle. It can be removed during installation.
  8. Jan 1, 2013 at 9:08 PM
    logcabinwc
    Micah
    SF East Bay
    Well it would seem the main difference then is whether to have the hot spot for better forward projection or a more even light output to see more of the sides..
    Rich, do you think that my fogs would provide comparable "side-view-illumination", if that makes any sense? haha I almost alway drive with my fogs on if i have my headlights on, so if the D25 covers the same amount of side field as the fogs I would probably go with the H1s... if not i feel like the better side viewing would be safer while driving
  9. Jan 1, 2013 at 9:39 PM
    logcabinwc
    Micah
    SF East Bay
    oh and this was posted in one of the previous gb's and i thought it might be helpful... maybe post it in the first post again andrew? just thought it might help!
    info posted by buzzardsgottaeat
    A lot of people get the mini (H1 or D2S) because they're easiest to install
    FX-Rs are better quality but require free hand cutting of your light housing and a slightly more difficult aiming/securing process.
    Blazers are for fogs, you have to cut/rig it up custom, no plug n play or bake n reseal there.
    H4 headlights
    H10 fogs (H11 for 2012s) are the sizes you need and the harness will be the H4/9003 iirc
    H1 has been deemed a little brighter while D2S more even output. Most go with the H1 simply because its brighter but don't consider other factors. Matt and the guys at TRS mostly favor the D2S and I also like to point out that the larger shrouds fill our headlights better than the mini H1 and there is a greater selection.
    3000k is yellowish and good for fogs for its ability to cut through adverse weather
    4300k is like sunlight or stock color headlights and has the highest lumen count (brightest) of the available options
    5000k will be whiter and is the highest TRS recommends.
    6000k is also very white with a tiny bit more blue
    Any higher temp is stupid because you lose light output and fatigue your eyes and others.
    I always say 4300k is the way to go but can see how white/5000k has an appeal
    The upside to a projector retrofit vs cheap hid bulbs in your stock light housing is mainly that it is higher quality and has a clean cut off line.
    I can't think of anything else off the top of my head but that should be a good starting point for anyone who wants to start researching these.
  10. Jan 1, 2013 at 11:04 PM
    Theloneracer
    Theloneracer New Member
    mini h1 kit for me :)
  11. Jan 2, 2013 at 12:25 AM
    willimatic
    willimatic Well-Known Member
    Will
    Rancho Murieta/Folsom, CA
    06 Tacoma AC 4x4 Sport
    Just recently put my H1s in, and was wondering what the dark area in the front was from. Is there a reason they do this with the H1s?
  12. Jan 2, 2013 at 10:15 AM
    logcabinwc
    Micah
    SF East Bay
    I'm 99% sure ill probably go with the D25's. if I want to really see straight down the road more ill ten on my highs and/or get a light bar. Besides, both will be an improvement from stock :)
  13. Jan 2, 2013 at 10:47 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    anything here is an improvement from stock and retrofitting it will properly utilize the brighter output
  14. Jan 2, 2013 at 3:01 PM
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    Just added Theloneracer
  15. Jan 2, 2013 at 7:32 PM
    #35
    double dee
    double dee Well-Known Member
    Arizona
    Im in... this is my christmas present i was just waiting for the next group buy!
    1 - g35man - 2 FXR
    2 - pakow - 1 FXR
    3 - rkarabao- 1 D2S
    5 - Theloneracer - H1
    6 - double dee - D25
    7 -
    8 -
    9 -
    10 -
    11 -
    12 -
    13 -
    14 -
    15 -
    16 -
    17 -
    18 -
    19 -
    20 -
    21 -
    22 -
    23 -
    24 -
    25 -
    26 -
    27 -
    28 -
    29 -
  16. Jan 2, 2013 at 7:46 PM
    #36
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    1 - g35man - 2 FXR
    2 - pakow - 1 FXR
    3 - rkarabao- 1 D2S
    7 - Bulhas - FXR +
    8 -
    9 -
    10 -
    11 -
    12 -
    13 -
    14 -
    15 -
    16 -
    17 -
    18 -
    19 -
    20 -
    21 -
    22 -
    23 -
    24 -
    25 -
    26 -
    27 -
    28 -
    29 -
  17. Jan 2, 2013 at 7:47 PM
    #37
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    i noticed they no longer have a the blazer projector..... what would be suitable for fog lights no??
  18. Jan 2, 2013 at 7:49 PM
    #38
    Rich91710
    Rich
    Los Angeles
    08 Base
    Nothing at the present time.
    The Blazer has been gone for about 6 months.
    Plug-in kits aren't covered by the GB discount, and they're dangerous in fogs anyways.
  19. Jan 2, 2013 at 7:52 PM
    #39
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    its not for the fogs :spy:
  20. Jan 2, 2013 at 8:11 PM
    #40
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ooooooo... sounds good.
    Spent some time poking around and I fear they are gone.
    Princess Auto has them archived, NLA.
    I found two sites that offer them for something like $75 EACH (should be $50/pair)... but the sites are very "generic" looking and I wouldn't trust them with anything but Paypal... and honestly, any time I've ordered from a site with those layouts, I've been told they were out of stock and occasionally had to fight for a refund.
    There are a few listings on eBay under "Blazer projector" but I have no clue if they are "real" or not.
    #40
Thread Status:
