Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Mar 14, 2013 at 8:49 AM
    #461
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    for the 5100's , OME is the other way
  2. Mar 14, 2013 at 10:48 AM
    #462
    KPT
    KPT sees what you did there.
    09 Prerunner
    True. The title of his post referenced 5100s though.
  3. Mar 14, 2013 at 10:56 AM
    #463
    Brett C
    Brett C Active Member
    Brett
    Edgewood Tx.
    4x4
    Yes, I put on the toytech springs awhile back , now I'm adding the Bilstein 5100's .
  4. Mar 14, 2013 at 11:06 AM
    #464
    BearBait
    BearBait New Member
    Western Massachusetts
    2005 TRD
    Hey all,
    I have an 05 TRD Access Cab. Stock rear leaf springs are cracked (driver side is one good bump from failing altogether). I picked up a set of barely used Skyjacker TCR515S Soft ride springs that should jump the rear up about 1.5 inches. I want to put the Bilstein 5100 adjustable heights in the front. If the 5100's need to be set at 1.75 to level the stock leafs where do I need to set them for the additional 1.5 the Skyjackers will add?
    I've been through and through trying to find an answer to avoid asking a question that has already been asked a million times, but no luck. Any help if hugely appreciated!
  5. Mar 14, 2013 at 11:12 AM
    #465
    KPT
    09 Prerunner
    Most folks run 2.5" front with1.5" rear.
  6. Mar 14, 2013 at 11:15 AM
    #466
    OZ-T
    Peter North
    British Columbia
    don't see that
  7. Mar 14, 2013 at 11:15 AM
    #467
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Hells yeah! OME products are great IMO. I ran Dakar leafs in my 95 and couldn't have been happier. It beat the hell out of replacing stock springs (aftermarket and OEM, which I broke). :mad: Tacomas still have shit springs after all of these years. SMH.
    I installed the 2" OME Heavy Kit (SKU: OMETACO5HK) on my 2011 and can really freight the truck without much sag in the rear. As a DD under warranty I can't afford to go up 6" yet, so the 2" was a perfect option. The truck handles a lot better as well. You can have the dealer install it as well and avoid them hassling you about warranty issues. I did my own (fairly easy install) so I could afford to buy armor.
  8. Mar 14, 2013 at 12:51 PM
    #468
    KPT
    09 Prerunner
  9. Mar 15, 2013 at 11:56 AM
    #469
    Cwpick76
    Cwpick76 Well-Known Member
    CW
    Wichita, KS
    2013 Double Cab Xsp-X
    Blacked out badges.
    Have a 2013 4x4 Tacoma. I want to strengthen the suspension to be able to handle fast off road driving (trails/fields, desert/sand, bumps hops etc...) Any help or suggestions
  10. Mar 15, 2013 at 12:21 PM
    #470
    OZ-T
    Peter North
    British Columbia
    Interesting , doesn't show that way on Tapatalk
  11. Mar 15, 2013 at 7:33 PM
    #471
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    I'd suggest reading the Mid Travel and Long Travel threads for gussetting tips. You also need to think about what kind of aftermarket suspension you want to use, because the OEM parts won't like that kind of abuse.
  12. Mar 17, 2013 at 7:48 AM
    #472
    Cwpick76
    CW
    Wichita, KS
    Blacked out badges.
    Didn't see a midtravel thread. Wasnt sure if long travel was the option. I understand that I would need to replace pretty much all of OEM suspension. but wasn't sure about what I need to save some money up to buy. and any help with reliable brands of aftermarket would be great. also if there are any particular specs i need to take into account when buying upgrades would be helpful.
    I am not looking for full race spec or anything like that (unless I need to). I want to build a parts list to start working on an upgrade until i have a full set of what I need.
  13. Mar 17, 2013 at 9:15 AM
    #473
    DoorDing
    Bodie, CA
    yes
    I'm by no means a knowledgeable person on Tacoma suspensions, but this is an overview of what I've picked up from a few months on TW.
    Mid Travel with BS Thread - There's a LOT of information in there, but it isn't always easy to find what you're after. I subscribed mainly to follow along. Try seaching that thread for ideas.
    2nd Gen. Builds - Start cruising through these to get a feel for what you like, what modifications will allow you to do what you want to do, etc. People are usually happy to answer questions in their build threads, and many have detailed information, like DIYs and parts lists. For example, here's the parts list for my mid travel suspension.
    My mid travel setup is actually fairly mild compared to many, but it should be fine for me. Before tires, I'll have a little over $3k in the suspension. There are less expensive, very capable options that may also meet your needs, such as an OME, Bilstein, or other setup.
    Long travel is a whole different world, with amazing amounts of money spent to build amazingly capable trucks. LT trucks can make high speed desert runs through terrain that's beat anything else to death, and they can make very impressive jumps in the dunes. They aren't the most practical vehicles for daily drivers, and if you get into LT, you'll get used to making repairs. If you read an LT build thread, you'll see what I mean. Done right, LT will cost several thousand in parts and a take lot of labor. While an MT suspension can largely be a bolt-on install, LT will require a fair amount of welding to reinforce a lot of areas, along with other custom work.
    Take your time and you'll find the right answer for you.
  14. Mar 18, 2013 at 10:07 AM
    #474
    Rollin77
    Rollin77 Member
    Sudbury, Ontario, Canada
    '11 Blown Toy Taco TRD Sport
    TRD supercharger. TRD catback.
    So I'm another looking to get some height and a much better ride out of my stiff 2011 TRD dual cab. (Im looking for 3"). I don't off road almost ever. I'm looking to run a larger wheel, preferably a 20, but I could go down to 18. (Ex- 285/70/20- somewhere in that are). I'm hearing lots about toytec and OME. I would also change the UCAs. what's the best equipment from both that'll work perfect for me? You guys are great!!
    Thanks alot
  15. Mar 18, 2013 at 10:16 AM
    #475
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    OME is great on road & off.
    OME 885s without a spacer will give you 2.5" & with a 1/4" spacer will give you a full 3".
    Dakars in rear if you want to maintain rake or 1 1/2" to 2" AAL if you want to level it.
  16. Mar 18, 2013 at 3:26 PM
    #476
    DoorDing
    Bodie, CA
    yes
    I'll add that if you end up needing UCAs, Light Racing seems to have the least expensive option.
  17. Mar 19, 2013 at 8:01 AM
    #477
    YOTA LOVER
    NH
    Any major lift you put in is going to void just about every warranty you have. That means the emperor is going to leave you high and dry when a commonly known fault happens.
    If you're happy with 2-3" of lift get the OME kit. Its new springs and shocks all around, they are heavy duty and time tested. You can get the whole kit (everything you need) for $900-1000, and if you have a moderately stocked garage you can do the install yourself in under a day.
    Are you really going to pound the snot out of a brand new truck?
  18. Mar 19, 2013 at 9:37 AM
    #478
    Cwpick76
    CW
    Wichita, KS
    Blacked out badges.
    2-3" is fine. not really looking to make it stand up more, but I know I will need more clearance and room for suspension to travel.
    This is what I saw on toytec:
    OME Suspension lift kit
    Front coil options: Heavy_886_coils_(200+_lbs_add_front_weight)
    Top plate spacers: No_top_plate_spacers
    Rear Options: Complete rear OME CS047R springs with U bolts (+ $469.00)
    Front Diff drop kit: 4X4
    Add Rear shock stone guards (Pair): Yes (+ $26.00)
    NEW! Assemble front shocks/coils with new bushings: NO
    Do I need front diff drop kit? (what does it do?)
    Should I get top plate spacer? (what does it do?)
    Do I need to replace UCA? or lower? or both?
    Most kits have said get longer rear brake lines, is that true here?
    $100 for them to assemble front shocks/coils with new bushings...Is it worth it?
    As far as pounding the snot out of a brand new truck... "new" is a relative term. I am only looking to pound the crap out of the suspension ;-
    The suspension is just my next project on the truck and I am looking to start buying parts and pieces, or at least saving up for them. Installing them is still down the road... I will put it through moderate paces, moderate speeds. Mainly I want to be able to have some fun in it without worrying about an OEM part imploding because I did some wheeling in it.
  19. Mar 19, 2013 at 10:40 AM
    #479
    4Wheelin4Banger
    Randy
    Save up buy the whole lift at once (with extra $ for UCAs) get it aligned & see if you need new UCAs.
  20. Mar 21, 2013 at 10:24 AM
    #480
    YOTA LOVER
    NH
    What I found with the OME kit on my 2011 is that there is no NEED for UCA replacement or new brake lines. I would certainly recommend getting the steel brake lines upgraded because it is a smart move, and get them 1-2" longer than stock to account for the lift and have plenty of slack to play with. Only going up 2" or so doesn't really mess with the stock geometry, so your alignment should be pretty straight forward.
    You can throw in the Total Chaos (or similar) UCA for good measure, but I feel it is overkill at that lift height. If you're going to go higher at a later time than it could be a good investment now.
    I installed the diff drop just to ensure that at full extension I wasn't stressing the CV joints on the half shafts. Again, the geometry isn't too far out with a 2" lift, but I opted for safer over sorry approach. I'm running the All-Pro full skid, so I don't have to worry about exposing the diff.
    I'm not sure what they're talking about with the new bushings on the front shocks. The OME springs and shocks (up front) just drop right in. It's not like having to compress the spring to get it out of the strut or anything. If you decide to go w/new UCA than you should certainly upgrade the stock bushings on the LCA while you've got the front end torn apart. It took a lot of pounding on my gen 1 to wreck the stock LCA and UCA bushings, but when I did there was hell to pay.
    I honestly have no idea what the top plate spacer is. The only spacer I had to install was at the drive shaft bearing because I have the 4 door w/ 6' bed, thus the longer drive shaft.
