  1. Dec 25, 2019 at 7:33 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I used 12 gauge on mine. Will be plenty thick since it’s a short run down to the engine bay. I just wrapped it in electrical tape and shoved it in the gap.
    BNTECHGO 12 Gauge Silicone Wire 10 ft red and 10 ft Black Flexible 12 AWG Stranded Copper Wire https://www.amazon.com/dp/B01ABOPMEI/ref=cm_sw_r_cp_api_i_Ke4aEb5XT9KT6
    751154E7-4E19-4964-9B64-FD8C1A8495D2.jpg 90A25A41-38B9-418E-A40F-215B8F772C0E.jpg
    AugustaTaco, irayfz6 and Matmo215 like this.
  2. Dec 25, 2019 at 8:14 AM
    mthew96
    mthew96 Well-Known Member
    mathew
    Western Massachusetts
    2008 tacoma TRD sport access cab 6 speed
    Bilstein 5100 kit and 1” spacer 265/70r17 duratracs BHLM DRL mod anytime fog light mod stubby antenna TRD shift knob LED tail lights TRD cat back exhaust
    1106163A-D325-47E1-BB61-F803E8443D2E.jpg 37998EAD-08F0-4906-B17F-685E7F0645F8.jpg
    Im deff gunna look into making a platform like that with storage boxes underneath. Mainly just for the same purpose as yours. For the pup. I wanna keep the back seats intact just in case though.
    Unfortunatly I don’t have the same rear seats as yours. I have an 08 access cab so my rear seats look like this. 37998EAD-08F0-4906-B17F-685E7F0645F8.jpg
    However maybe that will make it easier because they do swing forward to already make a somewhat flat platform but idk if I trust my 100lbs dog to be supported by those plastic bars that go over the top.
    So I deff wanna make a plywood 60/40 floor that’s carpeted to cover the seats and storage and make a flat cargo space in the back. It’ll just be a slight variation from what I see on the newer trucks with the different seats.
    I will prob have to try and source thinner or be more crafty with the storage bins having that plastic bar over the top of the seat. Or maybe I can remove that entirely and rest the seat on the cases instead. I’ll have to look closer at it. My seats look like this opened up 1106163A-D325-47E1-BB61-F803E8443D2E.jpg
    AugustaTaco, irayfz6 and Rick_Taco like this.
  3. Dec 25, 2019 at 8:18 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have the same back seat as you. Flipped them over, and put a sheet of plywood on top. Only additional supports is a 2x4 at each front corner. My dog is 86 lbs and never once has it crossed my mind there’d be an issue.
  4. Dec 25, 2019 at 8:31 AM
    mthew96
    mathew
    Thanks for sharing that! That’s like exactly what I’m trying to do. The only difference is I wanna have the plywood floor as two piece. 60/40 so that way it can be picked up and moved over to get to storage bins or to maybe flip one of the seats up and use them if need be.
    Did you keep the plastic bars that run over the top of the seat and do the 2x4 for support or did you remove the bar and use just the 2x4?
    As for the space underneath the seats. Do you think a storage case would fit under there and double for a little extra support and a little extra storage at the same time. Or do you think any storage solution that would fit under there would be so small and oddly shaped it would be practically useless?
    Do you notice any restriction in the front seat adjustment with the plywood there? Still able to tilt back and relax and adjust the seat for different drivers etc?
  5. Dec 25, 2019 at 8:48 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    I got the letter. Threw it to the side. It’s 12 years from date of purchase, so I’ve got some time.
    I bought these. Had to get them from Romania, but worth every penny!! Way better than LED glare.
    https://www.tacomaworld.com/threads/gy6-35-hir-921-reverse-light-upgrade-vs-high-power-leds.474996/
    WYJH22[QUOTED] likes this.
  6. Dec 25, 2019 at 8:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I set the seats where I wanted and built around that. I can still recline all the way back but I can’t slide back any further, which is fine. I have some loose stuff stored under there, but not a container. I also can store stuff under the seats as well. I have some MRE’s, some recovery gear, tree savers, soft shackles, etc. Some soft sided bags would be good if you’re trying to keep small loose things. I left the bars on the seats.
    if you want to store more and never use the seats, I’d just remove the flip down part entirely. That’d give a lot more room under them. That’s on my list, just hasn’t been a priority
    JKU3000 likes this.
  7. Dec 25, 2019 at 9:41 AM
    Rick_Taco
    Rick
    Indiana
    Merry Christmas Everyone!
    Tore into my transmission this week. I am pretty sure I blew up 3rd gear and the clutch that controls reverse and 4lo. I am doing a full flush with pan drop and filter change in hopes it’s just the cooked fluid.
    But it’s Christmas so I’ve got to wait until later to bring it up to temp so I can check fluid level and then take another test drive.
    https://www.tacomaworld.com/threads/diy-full-flush-for-automatic-transmission.68462/
    These threads really helped too.
    https://www.tacomaworld.com/threads/verified-alternatives-to-toyota-ws-atf-automaitc-transmission-fluid.373083/page-2
    https://www.tacomaworld.com/threads/torque-converter.535379/
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
    https://www.tacomaworld.com/threads/the-torque-spec-guide.318116/
    https://www.tacomaworld.com/threads/no-reverse.302139/
    9ADCD077-4D99-4044-8748-E90F3028BD1D.jpg B33EE55A-4AFF-4FEB-8D63-22BD8C3788CC.jpg 55CF9B2F-C52F-40BD-B172-E42FDA1F3F9C.jpg
  8. Dec 25, 2019 at 10:48 AM
    MtnMan307
    MtnMan307 Well-Known Member
    Aurora, Colorado
    2010 DCSB TRD OR, 2017 Prius 4 Touring Lyft Car
    Weathertech floor mats, Bilstein 5100s front/rear, TSB leaf springs, Pioneer head unit, Mini D2S headlight retrofit.
    I probably need to do that in the spring. New tranny fluid and drop the pan.
    JKU3000 and Rick_Taco like this.
  9. Dec 25, 2019 at 10:51 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I only raised them about 2 full turns from where I got them from the factory. I'm right around 2.5" of lift
  10. Dec 25, 2019 at 10:58 AM
    mthew96
    mathew
    I would really like to keep the functionality of the seats should I ever decide/need to carry a passenger in the back id like it to be useable. That’s why I was planning the 60/40 split for the platform. It would be easy to pick one side up and put it over to the other side so the seat is useable for a passenger, or for access to the the little built in storage compartments.
    Iv also been looking at the possibility of keeping the seats folding over the factory storage compartments and finding storage bins that are tall enough to be level with the top of the seat. Then build the platform over that.
    Like what RogueJuan showed in another thread about access cab rear seat organizing/platform
    Edit: I also plan to do a head unit and a small 10” sub that gots the amp built into the box and what not. It’s a thin little sub box and only a 10” but it really is all you need in our small cabs. It kicks pretty good. So I might think about incorporating that laying flat on one side and then the pelican case idea on the other side and then build the platform over that. I can make something to support over the subwoofer side if needed.
    That’ll keep the sub tucked away and still full use of the platform. As well as a case for storage. Then if I build the platform with the 60/40 or 50/50 whatever it works out to. I can move one side over and take the case out and put it in the bed or wherever. Then carry another passenger and still have the sub. And it’ll be tucked away safe from and damage of throwing things in the back seat with the sub.
    I’m leaning towards this option the most. I can always pull the sub out and put a storage bin over there just like the other side and have the sub on top of platform or where ever. The setup has a lot of flexibility and purpose in one. I like.
  11. Dec 25, 2019 at 11:27 AM
    Beer-toe
    Beer-toe Well-Known Member
    Berto
    Menifee
    Dad Mobile
    Stickers
    Mounted and setup with my pages.. ultragauge mount sucks dick, had to get creative but I actually like where it is alot and easy peasy to run the cable.
    And these temps normal for cold start up and idling for a little?
  12. Dec 25, 2019 at 12:00 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Merry Christmas everybody! I scored myself two method NV wheels! I think they are heavier than what I currently run, which sucks but oh well. Going to powdercoat the bead look bolts white.
  13. Dec 25, 2019 at 12:37 PM
    zhekakz
    zhekakz Well-Known Member
    eugene
    seattle wa
    2013 silver tacoma
    I used 10 gauge I have a long enough piece laying around worked out perfect
    I think my previous wires were 14 gauge which came with the old light bar
    I think it’s better to get the cables with the lights
    I didn’t on this one because mine was already all ran and I though it would be the same
  14. Dec 25, 2019 at 12:46 PM
    soxfan387
    soxfan387 Active Member
    Lee
    Eastern MA
    2012 Tacoma SR5 4x4
    Some minor Christmas add ons. Added “the gashole” from Meso customs, and made the Tacoma Attic from Blue Ridge fit my ‘12 (designed for ‘13 and after). Merry Christmas everyone!
  15. Dec 25, 2019 at 2:09 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Removed rear bumpstop spacers, adjusted some options on my alarm from the laptop, tweaked the headlights a bit and most importantly, washed and waxed.
  16. Dec 25, 2019 at 3:45 PM
    Reddy
    Reddy Well-Known Member
    Scott
    Ohio
    '11 TRD OR AC
    OME 885's/Dakars/265's/belly skid
  17. Dec 25, 2019 at 3:54 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    New aluminum skids to replace the old steel ones. Not as strong obviously but so much lighter. Merry Christmas TW!
    dpele, Grumpy, 05Taco4x4 and 18 others like this.
  18. Dec 25, 2019 at 4:13 PM
    chiffonade
    chiffonade Well-Known Member
    CBI sliders finally came in :)
  19. Dec 25, 2019 at 4:26 PM
    mthew96
    mathew
    Man I keep seeing your truck on here and I gotta say I’m jealous. That’s a beauty right there. Is that the original paint? Very clean and simple build, but just right man. Everything complements each other and works together nicely. If I was you I’d pat yourself on the back. That is a nice truck you have a lot of reason to be proud of it. I wish I lived in a nice climate and could have a truck that clean.
    will.i.was[QUOTED] and JKU3000 like this.
  20. Dec 25, 2019 at 4:28 PM
    mthew96
    mathew
    Who makes this gauge? Does it just plug into obd and read from computer? I like it and wanna get one for my truck. I have an 08. Does it only work on the newer ones?
    JKU3000 likes this.
