  1. Jul 29, 2018 at 2:01 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    That's the most colorful axle I have ever seen! I've replaced lots of axles in FWD cars but I have never seen a red CV boot before. Never knew they had in colors other than black or gray.
  2. Jul 29, 2018 at 2:04 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I drove it home...
    Might as well hoe it out
  3. Jul 29, 2018 at 2:05 PM
    Boba_Taco
    Boba_Taco Active Member
    Joe
    Asheville, NC
    2002 Tacoma TuRD SR5 3.4L 4WD
    How’s that working out for you so far? Was it a call-to-order sort of deal?
    I really need to replace mine but the crown nut under the lower ball joint is rusted to all hell.
  4. Jul 29, 2018 at 2:06 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Got me a new tire for the spare. Although I've never had to use it before (knock on wood) I figured I should get a new tire for it.
    Was going to buy a used tire on ebay for $105 shipped, no need for a new tire. I hate Walmart but they had the same exact tire for $105 + tax so I went & got it, got it mounted somewhere else though. I got tired of looking at my crusty old spare & I feel much better now. :rofl:
  5. Jul 29, 2018 at 2:36 PM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    1. I got the washers off the sleeves by grinding the crimp and hammering with a ball joint fork. Then i torched and pressed out the sleeves. Then i melted and scraped off the rubber off the sleeve. Then i took a abrasive wheel and cleaned them up. Now i have to grind down the crimp so the washer will fit up at the end of the sleeve. The end of the sleeve is flared out, thin and very sharp. Once i get these ready ill lube em up with grease and press in the ES bushings. I have some Superlube on order from Amazon so ill have to work on something else for now. I have everything taken out up front. Does anyone know of a COTS grease i can use on the bushing? Does anyone know if the washer just sits ant the end of the sleeve or does it need to be attached (welded)?
      Today at 11:51 AMEditDeleteReport
      Multi-Quote +Quote
    < Prev12345
    BYJOSHCOOK, HCFab and SwampYota like this.
  6. Jul 29, 2018 at 3:25 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    This is why I stopped the grinding method, I feared it wouldn't pop back on. The ball joint press method saves all the metal and pressed back on.
  7. Jul 29, 2018 at 4:15 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Flexed it out so I could wash it later. AC1AC262-9338-4431-A8D6-64738E3188D4.jpg
  8. Jul 29, 2018 at 4:16 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    @BartMaster1234
    BartMaster1234 likes this.
  9. Jul 29, 2018 at 4:17 PM
    tony2018
    tony2018 Well-Known Member
    u joints, extended exhaust bracket and extended rear brake line came in. Truck parked in the garage. Gettin ready to install the 5100's and wheelers 5 leaf springs. Gonna be a long night.
  10. Jul 29, 2018 at 4:17 PM
    HCFab
    HCFab Hudson Custom Fabrication
    Zach
    Central Idaho
    Overland 04' v6 4x4 5spd Xtracab, Lunar Mist.
    LOL, Poor truck...
    He looks sad.
  11. Jul 29, 2018 at 4:18 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Looks horrified.
    HCFab[QUOTED] likes this.
  12. Jul 29, 2018 at 4:51 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    What does the extended exhaust bracket do?
  13. Jul 29, 2018 at 4:59 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    NM, I'm an idiot, should've know. I just chopped mine off after the very first time going to the desert. Looks better like that.
    Prayn4surf likes this.
  14. Jul 29, 2018 at 5:01 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I did to. That stock tail pipe is f'n hideous.
  15. Jul 29, 2018 at 5:06 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yeah it is. I remember when I chopped mine off, truck was only 5 yrs old & it was all crusty looking already too.
  16. Jul 29, 2018 at 5:20 PM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    He first thing I did when I got mine was dump the tail pipe. It’s a must.
  17. Jul 29, 2018 at 5:55 PM
    HCFab
    Zach
    Central Idaho
    Picked up a used hood seal finally!
  18. Jul 29, 2018 at 5:56 PM
    tony2018
    screw you guys!!!:bananadead:
  19. Jul 29, 2018 at 6:01 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Washed my baby. She cleans up well
  20. Jul 29, 2018 at 6:15 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Completely agree. If I were him I’d just purchase a new ECU. Too many things can go wrong.
    Speedytech7 likes this.
