Development of DIY Electronic Upgrades
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LostTime77, Feb 1, 2020.
  1. Feb 1, 2020 at 1:21 PM
    LostTime77
    LostTime77 [OP] Well-Known Member
    Well, here's the thing I don't understand. Exhibit A is that there exists a billion 3rd gen remote starts. Exhibit B states that in order for a remote start to work, it must communicate to the ECU in some way... right? If the only way to make a remote start work for a PTS system in the first place is to bypass the immobilizer and tell the ECU to start the vehicle.. why have the rest of the pieces not fallen into place? Why have they instead just not spoofed all the other actions I listed? It's not enough to just spin the starter motor by turning on the starter relay, the ECU needs to be in a state to be officially 'commanded' to start via some authorized communication.
    Therefore, since aftermarket remote starts ARE already doing the communication part... what is the issue with the other spoofs? If we take a look at the signals involved, they are mechanical. All button presses detected by the vehicle (brake press, unlock button press, PTS press) - these are all electromechanical implemented by a normally open switch (for brevity sake).
    Therefore:
    1. Spoof the fob being in range (spoofing the immobilizer comms to the ECU) - ALREADY being done somehow
    2. Spoof the user pressing the handle lock / unlock button - Either a CAN alert to the ECU OR a 2 pin signal OR touch signal
    3. Spoof the user opening the door - A 2 pin signal (door detect switch)
    4. Spoof the user pressing the brake pedal - A 2 pin signal
    5. Spoof the user pressing the PTS switch - A 2 pin signal
    Just doing these operations in sequence seems logical and easy to me. This must mean 1. They really have not figured this out (which I don't believe) or 2. There is another issue which I am not aware of.
  2. Feb 1, 2020 at 1:21 PM
    Kevin8se7en
    Kevin8se7en Well-Known Member
    2017 Inferno OR
    For someone who speaks with such certainty, you didn't seem to understand anything the OP even wrote. Everyone understood the OP but you. Go away and reflect on that for a bit.
  3. Feb 1, 2020 at 1:40 PM
    St0rm-Tr00per
    St0rm-Tr00per Well-Known Member
    SoCal
    2018 TRD OR 4X4 DCLB - Super White
    “Semi-Pro”/“PrOff-Road”
    I’m definitely interested in whatever you end up coming up with.
  4. Feb 1, 2020 at 1:41 PM
    LostTime77
    Kevin8se7en:
    It's OK. I am not the best at being concise. I also don't think I explained my full intentions well enough.
    Also, I speak loosely about "spoofing" these signals. I am here to assure you that this is indeed not only possible, but stupidly easy. There are 1001 ways you can skin that cat. If anybody wants an in depth electrical explanation I will give it.
    shane100700 and JasonLee like this.
  5. Feb 1, 2020 at 2:32 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  6. Feb 1, 2020 at 2:36 PM
    LostTime77
    There could be a switch in the seat. I never thought about that; however, I can confirm its not needed for the start process. I am used to a standard key ignition.. and when I had it, I could start my vehicle by standing outside the door and just leaning in.
    I don't like sitting in my truck to start it if I am just coming right back out, so I generally end up leaning in the door, depressing the brake pedal with my hand, and pressing the PTS button. This happens without me sitting in the seat.
    RyanDCLB likes this.
  7. Feb 1, 2020 at 2:43 PM
    hardshelltacomarine
    hardshelltacomarine Active Member
    William
    2019 Barcelona red Tacoma TRD sport mt w/raptor lined A.R.E. Shell
    I’m interested in any progress you make on any of these ideas.
  8. Feb 1, 2020 at 2:44 PM
    RyanDCLB
    4/19 DCLBOR
    That reminds me of a couple Tips and Tricks on the 3rd Gen that I wanted to mention:
    35. If the engine is running just press Push to Start button in any shift (R-N-D or S)except in P and radio won't go off (or a cellphone/bluetooth phone call for that matter). (Courtesy of abec)
    63. To start the truck without having your foot on the brake (useful for when a rider goes to the truck before you do and is sitting in the passenger seat) push the PTS button once and release, then push the PTS button and hold it till the truck starts (Approximately 10-13 seconds). This process was tested on a 2017 & 2016 Tacoma TRD Off Road with an Automatic Transmission and still requires the smart key to be in the vehicle in order to start.
  9. Feb 1, 2020 at 2:50 PM
    tgarza74
    tgarza74 Well-Known Member
    Mario
    2016 SSM TRD OR
    OvTuned
    Likewise!
  10. Feb 1, 2020 at 2:55 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    This all sounds great. I would be all over the remote start I only need to start once. I put my hand on the brake to start it again every winter morning lol All I can offer is an additional idea: Something or some way to disable the door ajar chime electronically without just unhooking the door switch. To this date, there is no way to do this.
    xxTacocaTxx likes this.
  11. Feb 1, 2020 at 3:05 PM
    RyanDCLB
    4/19 DCLBOR
    Dealer or Carista app, but I'm sure you're aware that if you push the door switch once, it will turn off the door ajar chime. :thumbsup:
  12. Feb 1, 2020 at 3:08 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Not sure if it’s been said yet, but my guess is the single start option is what most would want. I have cell based remote start and it’s annoying to double start. I don’t know what my $ tolerance is for a solution for that. Probably about $100. But that’s on top of the system I already bought.
  13. Feb 1, 2020 at 3:19 PM
    VB25
    2018 TRD OR ACLB AT
    False. Not a customizable option, sadly. Pressing the button does not work in Access cab. Unless it’s the beeping after you shut the truck off entirely and the steering wheel needs to lock. I wanna listen to the radio with the doors open in accessory mode.
    RyanDCLB[QUOTED] likes this.
  14. Feb 1, 2020 at 3:25 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol you only have 13 posts. Nobody knows you here yet. You could be the best damn developer out there but nobody knows that from one post.
    In addition, you are speculating quite a bit in your post. I am an engineer. We don't speculate.
    Good luck and if I were you I would develop whatever you want to make you happy. If it works, present it to others to see if they want the same.
  15. Feb 1, 2020 at 3:35 PM
    #35
    LostTime77
    I shouldn't need tons of rep on a forum for people to understand my profession if I tell them. Regardless, this is not something that is too big of deal.
    I am not sure what you mean by engineers not speculating. When you want to ship product, it has to be specified, sure. When you want to come up with new ideas though, you have to investigate and form a theory on why something works the way it does. The investigation part is what should fill in the holes. I have no clue what the communication looks like between the electronic units, which is why I need to reverse engineer it and investigate. I cannot say with 100% certainty that my ideas are sound, only likely. The point is: I can't form a reliable idea of what it looks like with the available information. You have to start somewhere.
    From my experience, engineering is not cookie cutter. Most of the time, you don't know every input and output at the beginning of the project. This is what testing and investigation is for.
    Its not like I am asking anybody to build a bridge in which they "speculate" how wind forces are going to make it dance: https://www.youtube.com/watch?v=rp8hvyjZWHs
    That stuff carries lives. Likewise, I wouldn't ask anybody to use a new device I made that was based on speculation.
  16. Feb 1, 2020 at 3:51 PM
    #36
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Not to be a debbie downer but you have to prove to us that you can even create a single functional product. I've seen a few successful engineers here who presented their products rather than just talking about it. I wish you the very best.
  17. Feb 1, 2020 at 3:52 PM
    #37
    tgarza74
    Mario
    2016 SSM TRD OR
    OvTuned
    Huh? He doesn't have to prove shit...I mean that's the beauty of the ol interwebs isn't it. Say whatever you want, do whatever you want, believe, don't believe...
    AKGSD and shane100700 like this.
  18. Feb 1, 2020 at 4:01 PM
    #38
    LostTime77
    Yeah, I think some people are mis understanding. I don't think I have said a single time that I was making a product, even in my original post. I only asked if there was interest in looking at these ideas. I don't need to prove anything to anybody on this forum. I am not asking for buy in. The issue is that I see a lot of forum posts on remote starts and other issues that just seem to come to a dead end after a certain time. Therefore, I don't have an idea if anybody is still interested or if they have moved on.
    Just FYI, there is such a thing called "market evaluation" in companies, where they will spend some up front time trying to understand the market for a product to see if its worth their time. I am doing the same thing here (minus wanting to make money.. more of an open source type thing).
    The only thing that I ask is that I don't get the whole "snobby", "know it all", "I have seen this before", kind of talk out of respect for the community forum: not trying to blast people's ideas before they have evidence to do so. I specifically tried to form my post to not talk about making an actual device for the masses. I am a curious embedded engineer, that's all. If it turns out that something good comes of it, then you are welcome to partake in anything I plan to offer.
  19. Feb 1, 2020 at 4:03 PM
    #39
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I want one of you ever get this in production.
  20. Feb 1, 2020 at 4:21 PM
    #40
    TacoSportTRD
    TacoSportTRD Well-Known Member
    Michigan
    2017 TRD Sport AC 4x4 V6 Barcelona Red
    A couple times I tried an experiment with the remote start, I stood at the open door with my finger pushing in the door jamb switch and remote started the truck.
    I figured if it worked then I could hook up a toggle switch to keep the circuit closed.
    As soon as I let the jamb button loose the alarm went off so that leads me to believe that there is also another switch or sensor somewhere.
    There are switch's or sensors under the seats but they are for passenger detection regarding the air bag system
