Drained my transmission fluid by accident - what now?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ComaTSS, Jul 18, 2015.
  1. Jul 18, 2015 at 6:09 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Paint the drain pan plug bright red/orange so you know what it is......
    Vegas Tacoma likes this.
  2. Jul 18, 2015 at 6:09 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Valvaline Max Life ATF fluid is WS rated for our trucks. Ran it in the '12.
  3. Jul 18, 2015 at 6:10 PM
    Gearheadesw
    Davenport Fl
    This
  4. Jul 18, 2015 at 6:10 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Not everyone is mechanical, or maybe working on an auto is a completely new thing. Some city folks grow up their whole life without owning a vehicle.
    I was rebuilding engines and helping with frame off restorations in high school and have a hard time understanding it myself, but not everyone grew up working with their hands.
    DrFunker[QUOTED] likes this.
  5. Jul 18, 2015 at 6:15 PM
    ComaTSS
    ComaTSS [OP] Member
    Evan
    Arkansas
    '13 PreRunner TSS Edition V6 SR5
    Got it. What do you think about just putting 3 quarts of one of the other brands that someone mentioned in there with the rest of the fluid that is still in there?
  6. Jul 18, 2015 at 6:18 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Measure what you drained out. Replace exact amount with compatible fluid.
    XCDave likes this.
  7. Jul 18, 2015 at 6:25 PM
    ComaTSS
    ComaTSS [OP] Member
    Evan
    Arkansas
    Looks like I am doing this tomorrow
  8. Jul 18, 2015 at 6:32 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    If you can't get the toyota stuff and need to drive, I'd think you could get away with adding something like valvoline maxlife as a temporary measure.
    I'd flush it completely as soon as possible though.
    Also, this advice is based on nothing more than my gut feeling so take it with a salt lick
  9. Jul 18, 2015 at 6:56 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  10. Jul 18, 2015 at 7:30 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    I'd just fill it back up with valvoline maxlife, do the temp check and not worry about it....
  11. Jul 18, 2015 at 7:34 PM
    mhorton1911
    mhorton1911 Fightin' Texas Aggie Class of '19
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    Trail Gear front and rear bumper, 5100's all 4 corners, Eibachs, toytec AAL 1980 Ford pickup horn, and lots of battlescars :)
    I love Wal-mart :)
  12. Jul 18, 2015 at 7:35 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    My, My, My...
  13. Jul 18, 2015 at 7:47 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    [​IMG] Oh, Dude. Dude.
  14. Jul 18, 2015 at 7:55 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I haven't used Maxlife yet, but many members here have with good success. I emailed Valvoline and asked them what they thought about using it, the attached image is a screenshot of their email response. For what its worth, I'm gonna flush mine the next time with Maxlife.
    Although this guy doesn't do the proper procedure to check the ATF level, and there is no reason for you to drop the pan at this time, it could serve as a good reference since the 4Runner and Tacoma use the same transmission. Definitely refer to the guides you'll find here on tacomaworld, he does some cringe-worthy stuff... but I thought I'd add it as a reference point (he used maxlife to mix with Toyota WS).
  15. Jul 18, 2015 at 9:05 PM
    #35
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I think I misspoke and that would actually be too little fluid.
    The fluid check plug doesn't work like it does on the diffs where you fill it until it spills out and that's the proper level.
    You have to check the fluid level at a certain temperature with the engine running. At the right temperature, it should trickle out (like the diffs) but if the engine is stopped it would pour out at that level.
    I know this because I did that. After flushing, I didn't get a trickle out of the check plug so I shut the engine off to add more and fluid immediately began pouring out of the check plug.
    There is a fill plug that's different than the check plug.
    I'm no expert but there's a good write up HERE that I followed and it worked out well for me.
  16. Jul 18, 2015 at 10:32 PM
    #36
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Tacoma's tranny drain plug is located a good distance from the engine oil drain plug. Compare this to a Corolla:
  17. Jul 19, 2015 at 2:09 AM
    #37
    DrFunker
    DrFunker Well-Known Member
  18. Jul 19, 2015 at 2:14 AM
    #38
    Jimmyh
    SC
    2012 Prerunner SR5
  19. Jul 19, 2015 at 6:01 AM
    #39
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    The 1st time I changed my oil I crawled under there and understood exactly how people do it. The so called oil pan is so tiny it even threw me for a second.
  20. Jul 19, 2015 at 6:21 AM
    #40
    Jimmyh
    SC
    2012 Prerunner SR5
    It's not about the size, but the location. Oil Pan under the Engine, Transmission Pan under the Transmission. I'm not trying to be snarky, I just don't see it. :|
    The oil pan is normal size anyway what is it 5 quarts for the 6 cylinder and 6 quarts for the 4 cylinder.
    Sounds about normal to me except the 4 cylinder is larger than normal.
    toomanytoys84 likes this.
