FS: 2012 Tacoma DCSB, $34K/58k miles (Fully Built! 35's, TC +2 LT, Gears & Lockers etc.)
Discussion in '2nd Gen Tacomas For Sale (2005-2015)' started by AaronArf, Aug 27, 2016.
  1. Aug 27, 2016 at 12:06 PM
    AaronArf
    AaronArf [OP] Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    SOLD!!!
    2012 Tacoma Double Cab TRD Sport Upgrade w/ ENTUNE
    4.88 gears, ARB lockers, +2 Total Chaos Race Series long travel, Icon Coil overs, Method 105 BEADLOCKS w/ matching spare.
    20160825_185511.jpg 20160827_145708.jpg 20160827_145722.jpg 20160827_145738.jpg 20160827_145758.jpg 20160827_145923.jpg 2016-04-16 11.19.16.jpg2016-04-16 11.17.07.jpg
    Super reliable, been to Moab and back. Also was my DD up until this past December and I've only wheeled it once since then which is why its going up for sale. Not in a rush, so please no low balling. I AM NOT PARTING IT OUT!!!
    Build thread has everything documented:
    https://www.tacomaworld.com/threads/aaronarfs-2012-dcsb-build.213614/
    Modifications
    Armor/Recovery
    Pelfreybilt Front Bumper (Full hoops, Light bar cut out, Fog cut out)
    Pelfreybilt Skids (IFS/MID/REAR/GAS TANK)
    Warn VR10000-S Winch
    Warn Wireless winch controller
    Factor 55 Flat link winch thimble
    Factor 55 Aluminum Hawse fairlead
    Custom Winch Solenoid mounting bracket
    Brute Force Fabrications High Clearance rear bumper w/ swing out & bed side protection
    BEEFED Bolt on sliders with Kick outs (Medium Width)
    Trail Gear Rear Weld-on Diff guard for 8.4" rear (PN: 300655-KIT)
    Pelfreybilt Hi-lift Jack mount
    Pelfreybilt Axe/Shovel mount
    Hi-lift Xtreme 60" Jack
    Suspension
    Total Chaos +2" Race Series Long travel Kit
    ICON Long travel remote reservoir coil overs with #700 Eibach springs, CDC and IVD coating
    Total Chaos Alignment cam tab gussets
    Total Chaos Coil bucket gussets
    Total Chaos Spindle gussets [Sway bar version for extra strength]
    Total Chaos +2 Extended CV axles
    SDHQ High angle CV Boots
    All Pro U Bolt Flip Kit
    ATO Shackle Flip kit
    Rubicon Express XJ shackles
    OME Dakar Leaf Packs
    ICON Hydo Bump kit
    ADS 2.5" Piggyback Reservoir 10" travel rear shocks
    Wheels/Tires
    Method 105 Matte Black Beadlock Wheels 17x8.5 (4.75BS, 0mm Offset)
    Goodyear MTR 35x12.50R17
    Spidertrax 1.25" wheel spacers [REAR]
    Lighting:
    FXR HID Retrofit by Ambiguous (Osram SVS 4300k bulbs, Morimoto 35w ballast, Apollo shrouds, XBAL LED Halo's)
    Famous Fabrication Hood hinge light brackets
    Rigid Industries LED D2 Dually Driving pattern lights
    Rigid SR2 20" Combo Driving/Hyperspot LED Bar
    Rigid D2 Amber Driving LED's for Fog lights
    LED Lights (Dome, License plate, Map lights)
    FLYZEYE V2W LED Dash light
    FLYZEYE 3VP Console light
    Fog light mod (On Anytime)
    886 Bulb Reverse Light mod
    Rock Lights (Oznium LED Modules)
    Interior:
    Weathertech floor mats
    Wet Okole Seat Covers Front & Rear (Charcoal/Black)
    ImMrYo Rear View Mirror relocation bracket
    OTRATTW Switches in custom housing
    Ultra Gauge EM V1.2
    Misc:
    ECGS Assembled Differentials (Nitro 4.88 gears, ECGS solid spacers, ARB Air lockers)
    Stock Fenders & Flares Cut ~4" Front/Rear
    Airflow Snorkel
    Red line Quick lift Plus hood struts
    Stainless Steel Goodridge Extended Brake lines by OCTaco
    Fumoto Oil drain valve
    Blue Sea 5026 Auxiliary fuse panel w/ Blue Sea 7144 100A Breaker
    Blue Sea USB Charging ports (One in bed / One interior)
    Rear Diff breather mod (Toyota PN Union: 90404-51319, Plug: 90930-03136 & Fuel line)
    Pelfreybilt Bed side supports
    On Board Air (Air Zenith OB2 Compressor, 5 Gallon AVS Aluminium tank, 165 PSI on /200 PSI off Sealed Viair Pressure switch)
    Powertank ARB Solenoid manifold
    Cab Mount Chop
    Exhaust Re-Route
    Trasharoo
    Iggy Switch panel
    Prinsu CABRAC Roof Rack
    Energy Susp. Poly Bushings
    Custom Dual Optima Battery set up 4/0 Winch wire, 1/0 Gauge wire, Artec Grp 34 mount, BlueSea Isolators)
    COMMS
    Cobra 75WX CB Radio
    Wilson 5000 Antenna (Mounted on Prinsu Roof Rack)
  2. Aug 27, 2016 at 12:24 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
  3. Aug 27, 2016 at 12:36 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
  4. Aug 27, 2016 at 12:45 PM
    DaveEli
    DaveEli Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    Why???????:confused:
    kgarrett11 and scottalot like this.
  5. Aug 27, 2016 at 12:51 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Trades? Lol
    Question: since both batteries are in the bed. Where do the winch pos/neg cables Run to?
  6. Aug 27, 2016 at 1:04 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    No time to drive it :anonymous: This is my first time on TW since like June?
  7. Aug 27, 2016 at 1:07 PM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Not lying cause I would've bought
  8. Aug 27, 2016 at 1:11 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Have a 4/0 line direct to the aux battery in the bed for the winch so there is no voltage drop. Wire is HUGE lol. It's grounded direct to the frame up front. All of the other connections to the factory wiring are on dummy terminal posts mounted on HDPE with 1/0 ran to the battery bank switch in the cab to switch from batt 1 and 2, off and both.
    Link to pics: https://www.tacomaworld.com/threads/aaronarfs-2012-dcsb-build.213614/page-78#post-11767218
    scottalot likes this.
  9. Aug 27, 2016 at 1:27 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Incredible deal for someone. So much work went into this great build. Hope another TW'er gets it.
    ebbs15, ChamYota, DaveEli and 3 others like this.
  10. Aug 27, 2016 at 1:48 PM
    DaveEli
    David
    Virginia Beach
    Eli wants it.
    Techoma and AaronArf[OP] like this.
  11. Aug 27, 2016 at 1:49 PM
    TBuzz
    TBuzz Well-Known Member
    Colorado
    00' 4runner, No Longer Stock
    Bumpers, Sliders, 33's, ADS f&r, budbuilt, home built belly and bumper, s/c, urd,4.88, arb's
    Dayuum...I have always rubbernecked at your build,,I must resist temptation.
    AaronArf[OP] and Acerwin like this.
  12. Aug 27, 2016 at 3:12 PM
    sect0r
    sect0r Well-Known Member
    Oregon
    14 TRD Sport
    King Mid Travel, BAMF w/ 12" King's, ect
    Always loved your build. Someone is about to get the deal of a life time!
    AaronArf[OP] likes this.
  13. Aug 27, 2016 at 3:31 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    you're not kidding. I told myself I was going to keep it forever haha. Who am I kidding...I can't leave anything stock.
  14. Aug 27, 2016 at 4:05 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Alright so I think I have this figured out...you've pimped out the Civic and started watching the Fast and Furious on repeat
    kgarrett11 likes this.
  15. Aug 27, 2016 at 4:33 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Haha civic will be going too if all goes as planned.
  16. Aug 27, 2016 at 5:14 PM
    DaveEli
    David
    Virginia Beach
    Eli really wants that truck.
  17. Aug 27, 2016 at 5:48 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    I'd love to see it go to a good home:stirthepot:
  18. Aug 27, 2016 at 5:49 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    She could get mine for cheaper ;)
    DaveEli[QUOTED] and ckeene9 like this.
  19. Aug 27, 2016 at 10:13 PM
    DaveEli
    David
    Virginia Beach
    But yours is not red.
  20. Aug 28, 2016 at 6:20 AM
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    wow...awesome build a price. what's the future plans? very curious.
