Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Apr 13, 2018 at 2:17 AM
    #1881
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    I think that would of course help keep it dark, but i don’t think it would help keep it cool at all... I’m picturing a solar panel catching the radiant heat before it hits the roof and the inch or three between the panel and roof insulating it from adding unwanted heat through convection.
  2. Apr 13, 2018 at 4:52 AM
    #1882
    unclewilson
    unclewilson Well-Known Member
    Wilson
    Michigan or Colorado
    Several
    Lots
  3. Apr 13, 2018 at 6:05 AM
    #1883
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    been there. good reason to get up and start the day even being hungover
    frusteri4[QUOTED] and tonered like this.
  4. Apr 13, 2018 at 6:21 AM
    #1884
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I avoid the problem altogether by not ending up hung over.
    socalktk and unclewilson like this.
  5. Apr 13, 2018 at 6:27 AM
    #1885
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    Or the I only had two beers why am I hung over morning.....
  6. Apr 13, 2018 at 6:31 AM
    #1886
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    *innovative. I also sleep when the sun is not up.
    Shellshock and DoorDing like this.
  7. Apr 13, 2018 at 6:50 AM
    #1887
    YOTA 4X4
    Said no Canadian ever....
    :canada:
    bigdood, tonered and VE7OSR[QUOTED] like this.
  8. Apr 13, 2018 at 6:54 AM
    #1888
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    In the summer that’s about 5 hrs, less as you go further north.
    DoorDing likes this.
  9. Apr 13, 2018 at 7:07 AM
    #1889
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    I feel as one with my land and my cannon now, united under a lone star.
  10. Apr 13, 2018 at 8:08 AM
    #1890
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    I always thought those surplus booths would make for an excellent, whimsical, outhouse structure.
  11. Apr 13, 2018 at 10:54 AM
    #1891
    tjhaugh
    tjhaugh Member
    FYI, I checked in with KB Voodoo a week or two ago about the bed rails. They were out of stock and they said they are discontinuing them for 3rd Gen. I think the 2nd Gen were still available. If anyone knows an alternative, please share. I'm really interested for two reasons: (1) higher quality rail and (2) slightly lower height of the GFC (I'm really tight on space with my 70's garage height).
  12. Apr 13, 2018 at 11:05 AM
    #1892
    azninferno
    azninferno Well-Known Member
    Jeff
    Do we know what material the top sheet is? I don’t recall reading that
  13. Apr 13, 2018 at 11:39 AM
    #1893
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There needs to be stickys on the top of some threads!
  14. Apr 13, 2018 at 12:56 PM
    #1894
    gmacmt
    gmacmt Well-Known Member
    Graeme
    Montucky
    98 taco, Ram on 40's
    The roof will not act like a green house and heat the space. It is nearly opaque unlike a greenhouse roof. There is an insulative air pocket in the roof, and the roof panel is a reflective bright white that will bounce any radiative heat from the sun.
    Even though it does allow light through, it definitely transfers less thermal load than something like an aluminum panel, or thin fiberglass.
    The stock white color is not sky white like the stock tacoma. It is somewhat of an ivory color, which will match more vehicles and have less of an oppressive clean room vibe than a contractor top. If you want the bright white panels, we can color match as an upgraded option. The sky white is also unavailable in a textured powdercoat (the warm white has a fine sandpaper finish), so it will show scratches easier and be slightly less durable.
    bigdood, tonered, Evanike and 2 others like this.
  15. Apr 13, 2018 at 1:01 PM
    #1895
    Quadabaum
    Quadabaum Well-Known Member
    2017 Tacoma TRD OR 4x4 DCSB
    265/75R16 Falkens, ADS 2.5" Stage 3 Suspension, Go Fast Camper
    @gmacmt
    I know yall are slammed, just wanted to give a heads up that I sent another email. I am ready to submit a deposit and get on the build list. Ive already requested 9/1-9/10 off from work so I can pick it up in person.
    gmacmt likes this.
  16. Apr 13, 2018 at 1:03 PM
    #1896
    gmacmt
    Graeme
    Montucky
    About to go spend my friday afternoon/evening/midnight at a coffee shop catching up on emails. :alien: I will get back to you this afternoon
  17. Apr 13, 2018 at 1:05 PM
    #1897
    Quadabaum
    Awesome, thanks!
  18. Apr 13, 2018 at 6:18 PM
    #1898
    The Smith
    The Smith Well-Known Member
    Trinity Alps
    '17 4x4 V6 SR5
    When I peruse the GFC website, I don't find any mention of a deposit; rather, I only see the option to purchase for the full amount. Am I missing something? And if so, what is the deposit amount?
  19. Apr 13, 2018 at 6:20 PM
    #1899
    unclewilson
    Wilson
    Several
    Lots
    Pre order for Tacomas is over
  20. Apr 13, 2018 at 6:20 PM
    #1900
    YOTA 4X4
    I belive they only took $500 deposits during the Pre-order time frame, but to actually place the order we were all required to pay in full.. now that pre-order is over and they are available to buy a deposit isn’t really relevant. The deposit was really just to hold a spot in line while the concept was being finalized.
