Official 1995.5-2004 5lug tacoma lifted/lowerd suspension guide and general info
Discussion in '5 Lug' started by Sperrunner, Apr 21, 2018.
Was this thread helpful?
  1. Yes
    67 vote(s)
    95.7%
  2. No
    3 vote(s)
    4.3%
  1. Dec 16, 2019 at 11:01 PM
    #101
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    4x4 pick up spindles will work. You put passenger side on the driver n driver side to passenger. Pickup are front steer n tacoma are rear steer which is why you swap sides. The pickup spindles use all pickup hubs, brake rotors n calipers. The hubs are for 6 lug which is the same as prerunner rear end.
    These spindles allow you to use a lower uniball and are super strong. ESB LT kits use them and so does JD Fab.
    Tour991 and Das it mang like this.
  2. Dec 17, 2019 at 12:43 AM
    #102
    jruiz555
    jruiz555 Well-Known Member
    When you say pickup do you mean tacomas that are prerunner and or 4x4?. Any pictures? If that would work i dont see why a 5 lug couldnt have front diff brackets welded in and converted to 4x4
  3. Dec 17, 2019 at 1:03 AM
    #103
    BikerinBlak909
    SoCal
    96 LT 5 lug
    Pickups were made up to 1995 before the Tacomas
  4. Dec 17, 2019 at 6:14 AM
    #104
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    So if u converted rear to 6 lug u can do the front as well with the pickup spindles and other parts u mentioned? Or is it not that simple with plug and play?
  5. Dec 17, 2019 at 9:36 AM
    #105
    jruiz555
    I thought pickups were 5 lug?
  6. Dec 17, 2019 at 9:37 AM
    #106
    jruiz555
    Wouldnt the caliper be relocated to the back
  7. Dec 17, 2019 at 10:51 AM
    #107
    Das it mang
    Az
    1996 T100 SR5 MT
    Looks like the pickups were 6 lug if they are 4x4 from quick search
  8. Feb 7, 2020 at 2:33 PM
    #108
    fortiz619
    fortiz619 yeh i drive a 2wd big woop wanna fight about it?
    Southern California , IE ,SD
    04 Tacito 5lug, 16 tundra, 07 tundra
    So I’m finally getting to rebuilding my daily’s front suspension, I purchased the moog 81072 instead of the 81070 you recommended did I mess up ?
    Justrydin likes this.
  9. Feb 7, 2020 at 2:39 PM
    #109
    Das it mang
    Az
    1996 T100 SR5 MT
    U bought the 4 cyl 5 lug coils IIRC.
    If he is 6 cyl it will be like a lowering kit to the front, probs one inch shorter than stock like the v6 coils give one inch rise from stock with 4 cyls
    fortiz619[QUOTED] likes this.
  10. Feb 7, 2020 at 2:53 PM
    #110
    fortiz619
    My Tacoma is an 04 5 lugg 4 cyl, I bought the 81072 hoping to get an inch in lift to level out
    Das it mang[QUOTED] likes this.
  11. Feb 10, 2020 at 6:20 AM
    #111
    Das it mang
    Az
    1996 T100 SR5 MT
    ah yeah I see now. Well unless ur previous coils were old and sagging u wont gain much. 81072 is the Part # u need for the v6 5 lug coils
  12. Feb 10, 2020 at 3:39 PM
    #112
    Das it mang
    Az
    1996 T100 SR5 MT
    @fortiz619 BTW, saw u managed to get a 1st gen skid onto ur 5 lug based on ur post history.
    Can u tell me how u did it?
    Just drill into existing skid new mounting holes that line up the 5 lug ones?
  13. Feb 17, 2020 at 10:46 PM
    #113
    fortiz619
    Its pretty much a direct bolt on besides removing and re installing front tow hooks
  14. Feb 19, 2020 at 6:25 AM
    #114
    Das it mang
    Az
    1996 T100 SR5 MT
    Sweet, thanks! Did u manage to get the second piece of the skid to fit as well under the cross member? Wondering if new holes are drilled to match if it'd work
  15. Mar 11, 2020 at 7:32 PM
    #115
    Adominguez24
    Adominguez24 Adrian
    Adrian
    '01 Tacoma 2.4l Step-Side
    Cooper Discoverer A/T on 15x8 Trailmaster wheels, Pioneer Deck, Kicker Speakers, Rockville 12" Sub, Limo Tint
    What do you guys think of this set-up? My wheels also stick out currently about 1.5 inches, how much more would the front stick out with the spindles?
    Will I need any more parts? longer brake lines etc. ?
    I assume the 1.5" front spacer will provide .75" of lift
    Front suspension: ~4.75" of lift
    4" Doetschtech spindle lift
    1.5" spacer (fatbobs kit)
    Rear: ~4"? lift
    2" shackles
    maybe 2 inch aal? does anyone know what the lift is for this?
    Fabtech shocks
    https://4x4.fatbobsgarage.com/toyot...hackle-lift-kit-2wd-5lug-1995-2004-p8506.aspx
    https://4x4.fatbobsgarage.com/toyota-tacoma-2wd-5-lug-fabtech-add-a-leaf-kit-955-04-p33952.aspx
    https://4x4.fatbobsgarage.com/mobile/fabtech-performance-twin-tube-shock-single-p32084.aspx
    Das it mang likes this.
  16. Mar 12, 2020 at 8:55 AM
    #116
    Das it mang
    Az
    1996 T100 SR5 MT
    sounds like a good build planned! Very similar to mine except I'm prolly gonna leave the rear stock with the spindles and spacer in the front until I get a new leaf pack and hopefully a bed cage. As of now I have the spacer and probs gonna put it on for now with new shocks bc I'm getting some rub on the front tires stock rn. Dont't wanna bash fenders or cut yet but well wee
    you do not need extended brake lines. The spindles will push ur right and left tires out 4.5 inches each from what I've read
    This is what the truck will look similar to.
    https://www.tacomaworld.com/threads/trdchriss-build.161543/
  17. Mar 12, 2020 at 8:56 AM
    #117
    Das it mang
    Az
    1996 T100 SR5 MT
    ive heard the AAL makes the rear VERY stiff, even more so than people complain about the front spacer. Unless u load the bed up often or tow for like trips and stuff I would stick to the shackles
  18. Mar 12, 2020 at 8:59 AM
    #118
    Das it mang
    Az
    1996 T100 SR5 MT
    btw look into kyb shocks on Amazon if u want to spend less, I've also heard the fabtech shocks are stiff too if u want an alternative. Amazon has the spacer for like 30 bucks too, etc.
  19. Mar 13, 2020 at 10:21 PM
    #119
    Adominguez24
    Adominguez24 Adrian
    Adrian
    Thanks I’ll take that into account, is there another option to lift 4” besides the spindles to lift the truck? I’d like to keep these wheels but I don’t know if I want the tires sticking out 4.5” that is really far out
  20. Mar 16, 2020 at 1:57 PM
    #120
    Das it mang
    Az
    1996 T100 SR5 MT
    V6 5 lug coil springs have gone up in price somewhat, but that would be you're only other alternative if the tire poke bugs you too much.
    moog 81070 coil springs are the part number for them. U can stack those with the spacer for bout 2 inches, or stack the daystar spacer with the control arm/lift springs combination from doestch on their website. The spindles are always just hands down the best bang for buck when it comes to lift with these trucks.
