Rcd lift kits
Discussion in 'Suspension' started by K1992f, Dec 21, 2010.
  1. Dec 21, 2010 at 8:37 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
  2. Dec 21, 2010 at 8:39 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    This is the 6" fabtech
  3. Dec 21, 2010 at 8:40 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    19.Temporarily install Rear Crossmember (RCD 20-57405-2) for reference when marking the frame for the differential cutout.
    You may be right, but I remember reading that you dont for 2wd. We dont have the front diff to clear. So that would require no cutting. Think theres another thread somewhere, I'll try to find it so the op has the appropriate info.
  4. Dec 21, 2010 at 8:40 AM
    K1992f
    K1992f [OP] Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    Price on icon from toytec are 1,440 the ultimate is 1,110 ... And I'm guessing both of them lift give you a 3" right ?? And if so will my tire size work 18 rockstars with 275/70/18 open country mt tire will this work ??
  5. Dec 21, 2010 at 8:42 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I'd go Icon if you can afford it. They make kits in nice stages. http://www.iconvehicledynamics.com/store/categories.php?category=Toyota/2005-%2b-Tacoma
  6. Dec 21, 2010 at 8:45 AM
    jr114
    Jon
    SoCal
    Truck
  7. Dec 21, 2010 at 8:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    I think the whole issue isn't with the diff being present or not, it's the "new" location of the LCA mounting points since they bolt up to the crossmember.
  8. Dec 21, 2010 at 8:50 AM
    TexasTacoma37
    Depends on the backspacing of the cockstars.
    If it's 4.5", then you can actually go with a 285/65/18.
  9. Dec 21, 2010 at 8:54 AM
    jr114
    Jon
    SoCal
    Truck
    First off let me say that I was wrong in my earlier post when I said that the front crossmember was cut. Its actually the rear crossmember.
    The RCD front crossmember/ drop bracket bolts up to the frame.
    The rear crossmember has to be cut in order to provide clearance for the differential drop.
  10. Dec 21, 2010 at 8:56 AM
    98tacoma27
    Ben
    Not Beech Creek
    LCA connects to the rear also. See page 12.
  11. Dec 21, 2010 at 9:03 AM
    jr114
    Jon
    SoCal
    Truck
  12. Dec 21, 2010 at 9:05 AM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    I had Toytec Ultimate kit and then sold it for the RCD kit. Best decision I ever made. I have the same truck as you also. 09 TRD sport. Check out my gallery and you can see pics of my truck with both kits on it. RCD rides and performs so much better it's not even funny. Go with RCD IMO.
  13. Dec 21, 2010 at 9:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    Hmmm...good point. It just makes you wonder why they don't have a "If you have a pre-runner, skip step#X" in the directions.
  14. Dec 21, 2010 at 1:33 PM
    K1992f
    Kanon
    Thanks to you all for the help I'm not going to pay out the money for the rcd kit .. So with that being said I'm think I'm going with the toytec ultimate kit for now and the price so is that a good choice for the price ??
  15. Dec 21, 2010 at 1:37 PM
    #35
    jr114
    Jon
    SoCal
    Truck
    I honestly have seen alot of threads out there in which people are not liking the ULK. If you do not need the adjustability, I would check out OME shocks, struts and coils. has some good prices on them and other susp. components
  16. Dec 21, 2010 at 1:37 PM
    #36
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    i never knew fabtech had this setup.
  17. Dec 21, 2010 at 1:41 PM
    #37
    jr114
    Jon
    SoCal
    Truck
    From what I read before I bought my Icons, its the 2.5" dirt logic adjustable coilover, fabtechs own uniball uca and their firt logic rear shocks. from what I remember its pricey as hell.
    549-UCA's
    1149-Front shocks
    600-Rear Shocks
    199-optional rear Deaver leaf pack
  18. Dec 21, 2010 at 1:43 PM
    #38
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    I have the toytec..and I don't like it..the ride is realllyy stiff
  19. Dec 21, 2010 at 1:46 PM
    #39
    K1992f
    Kanon
    Ok what about pro-comp 3" lift kit. ???
  20. Dec 21, 2010 at 1:50 PM
    #40
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    NNNNNNNNNNNOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!! Go with the Old Man Emu or the Toytec.
