TRD Sport vs. OR
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kenneth.morris07, Mar 17, 2014.
TRD Sport or OR
Poll closed Apr 16, 2014.
  1. Sport
    34.8%
  2. Off Road
    65.2%
  1. Mar 17, 2014 at 9:02 AM
    kenneth.morris07
    kenneth.morris07 [OP] كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    Looking at possibly getting a 2014 DCSB. I've been thinking I want a TRD OR, but I've found a TRD Sport that the dealer has added a ton of options(lift, wheels, tires, lights, grill insert, etc) for a really good price. I'm not too sure of the differences between the two factory packages. Anyone who knows, chime in please. Thanks
  2. Mar 17, 2014 at 9:08 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Go to the top right of your screen
    Click on search
    Type in: "sport vs offroad"
    Read the hundreds of threads comparing the two.
  3. Mar 17, 2014 at 9:17 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Do you want a double cab long bed? if the answer is no.... get the off road... even in a 4x2 configuration the locking rear diff is worth it. in a 4x4 config, locking diff and atrac (both not found on the sport) make the truck so much more capable.
  4. Mar 17, 2014 at 9:26 AM
    XXXX
    sKiP
    05 Prius
    Both are overpriced IMO.
    Just get a SR5 and mod what you want.
    8.4 rear > 8.0 rear
  5. Mar 17, 2014 at 9:40 AM
    mistaare
    mistaare Well-Known Member
    silver. sport.
    I vote for the OR.
    I bought the sport never thinking I would really need a-trac and lockers.
    Stupid me.
  6. Mar 17, 2014 at 9:54 AM
    XXXX
    sKiP
    05 Prius
    um...yea so buy a locker. ARBRD129 + 8.4 rear is far superior to any e-locker rear and will cost you less to DIY vs buying from Toyota.
  7. Mar 17, 2014 at 10:19 AM
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    13 4x4 DCLB tacoma V6 TRD Sport
    5100 Bilstiens set at 1.75, progressive leaf pack, BFGs, All-Pro rear Bumper(white), Storm troopered out
    It depends if your gonna use it as a truck for haulin or for offroading.
    I like the sport for the LB and I will probably never need the rear diff locker or atrack
    If your looking for short bed only then offroad is probably the best choice.
    Edit: also see above you can always add a locker later on
  8. Mar 17, 2014 at 10:29 AM
    OOWTacoma
    OOWTacoma Well-Known Member
    FortySeven
    Claremore
    Special edition :)
    small mods here and there
    offroad because of locking diff and atrac. does great in mud, snow and sand.
  9. Mar 17, 2014 at 10:38 AM
    XXXX
    sKiP
    05 Prius
    Just a quick fact to all the people saying "OR for the slick stuff"
    locker use onroad in snow is retardedly unsafe
    Open/open rears (what off roads have) suck on slippery road conditions and so do lockers. The reason offroads have ATRAC is because open/open and lockers suck so bad in the slippery road conditions Toyota needed to come up with something so the sports with mechanical LSD weren't running circles around them.
  10. Mar 17, 2014 at 10:41 AM
    looking4vr
    looking4vr Well-Known Member
    Brad
    Lusby, MD
    17 DCSB TRD OffRoad 6MT
    Bone Stock, for now
    This is priceless...I love my girl next door lol :D
  11. Mar 17, 2014 at 10:53 AM
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    I always thought of the locker as something to use when rock crawling, or maybe trying to pull something heavy in a slick conditions. but not for driving normal speeds on or offroad.
  12. Mar 17, 2014 at 10:58 AM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Either Offroad or SR5, I think the Sport looks like crap.
  13. Mar 17, 2014 at 11:07 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    THIS.
    The rear locker works only in low range (on the 4WD trucks) and is for emergency getting out or pulling a Sport out (tiny joke here).
    A-TRAC also works only in low range, for slow, crawling across, up, over uneven, loose, rocky surfaces... amazing system, use it anytime I am in low range, no reason not to.
    The Sport has not had a mechanical limited slip since 2008. In 2009 ALL Tacomas got electronic limited slip (TRAC/TRAC OFF/ AUTO LSD).
  14. Mar 17, 2014 at 1:09 PM
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    not another of these threads...:deadhorse:
  15. Mar 17, 2014 at 1:12 PM
    kenneth.morris07
    Kenneth
    College Station, TX
    08 PreRunner
    not another troll....
  16. Mar 17, 2014 at 1:12 PM
    kenneth.morris07
    Kenneth
    College Station, TX
    08 PreRunner
    No I already have a prerunner. I'm gonna swap it for a new truck.
  17. Mar 17, 2014 at 1:18 PM
    spencer44306
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
  18. Mar 17, 2014 at 3:14 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    It all depends on what YOU want. Not what everyone else wants. I got a sport because of the color matched stuff, bigger 8.4 rearend & hood. Each person has different reasons for buying what they do. I wanted the color matched bumpers because i'm leaving those on. I wanted a 8.4 because i wanted and slightly bigger/stronger rearend that i plan on adding an arb locker to. And yes, i actually like the non functional hood scoop.:rolleyes: In the end, either option is good since it's a Tacoma. You will be modding it anyway, especially if you get on this forum!
