2nd Gen DIY Maintenance Quick Reference Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlackBeerd, Jun 28, 2016.
  1. Oct 27, 2021 at 10:11 AM
    #61
    gregzz
    gregzz Well-Known Member
    greg
    las vegas nv
    2011 tacoma crew cab 4x4 v6 4.0
    Wheels/ tires, tint, level kit. Rock crawler rails. 3- 6" procomp lights with light bar on front bumper. Magnaflow # 12256 stainless muffler. Billet shorty antenna.
    AWESOME write up. Thank you!!
    Island Cruiser likes this.
  2. Oct 28, 2021 at 6:43 AM
    #62
    BlackBeerd
    BlackBeerd [OP] Well-Known Member
    Michael
    Austin, TX
    2010 Barcelona Red AC 4WD
    If you (or anyone) wants to do most of the legwork researching guides and finding all the information, I can put it together in a similar format and generate a pdf. This goes for 4Runners, 2.7 tacos, 3rd gen etc.
    My only reservation about doing this though, is that I can guarantee all the information for the 2nd gen guide is correct, since I've personally done those maintenance items on my truck.
  3. Oct 28, 2021 at 6:50 AM
    #63
    BlackBeerd
    Michael
    Austin, TX
    Will some of you confirm the links in the OP to both the online and print PDFs are still operational? Thanks.
  4. Oct 28, 2021 at 9:35 AM
    #64
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Both links worked for me.
  5. Nov 7, 2021 at 7:35 PM
    #65
    Charged Tacoma
    Charged Tacoma Member
    Justin
    Iowa
    05 TRD Sport Supercharged
    TRD Supercharger, 3" Toy Tech Lift, Wheels, Tires, Step up bars, Exhaust
    Very handy and detailed! Saved. Thanks for sharing my friend!
  6. Jan 12, 2022 at 7:30 AM
    #66
    slyguy47
    slyguy47 Nerd
    Jacksonville, FL
    15 AC TRD OR V6 4WD 5AT
    I keep this PDF saved on my PC, as well as an Excel sheet of all completed and planned maintenance done to my Taco. Excellent job getting this together! It is invaluable for somewhat novice mechanics like myself.
    DiscoYaker likes this.
  7. Feb 20, 2022 at 1:29 PM
    #67
    ricog101
    ricog101 Active Member
    Pacific NW
    2001 Xtracab 2.7l 4wd Auto (3RZFE Engine)
    Hiatus Camper OME Complete Lift Kit (~1.75") LED projector headlights Maxxis Razr AT-811 265/70R16
    Is there anything like this out there for 1st gens? (Specifically 2.7L 4WD 4 speed automatic (3RZFE Engine)). Thank you in advance! Been looking all over TW and can't find anything this awesome for 1st gens.
  8. Mar 5, 2022 at 9:42 AM
    #68
    idahodesert
    idahodesert Idaho Desert
    Boise, ID
    2025 TRD Offroad, Blue Crush, i-FORCE 2.4L 4cyl Turbocharged, automatic
    Excellent and useful post.
    Can you please add something like this to the coolant section?
    Radiator Cap pressure = 16.5 psi
    Useful for pressure testing your coolant system for leaks.
    Spec for my 2009 Tacoma 4L V6 manual transmission
    Thanks
  9. Apr 30, 2022 at 7:11 PM
    #69
    stonybrook
    stonybrook Well-Known Member
    Santa Fe, NM
    Thank you for this.
  10. May 2, 2022 at 6:57 AM
    #70
    abicigo
    abicigo Well-Known Member
    Alex
    Tampa, FL
    ‘00 Tacoma Reg Cab 2.7 4wd 5-speed
    Stock
    Just wanted to say thank you for the write up! This was very convenient when I did all the tranny and differentials fluids when I bought the taco
  11. May 7, 2022 at 4:30 PM
    #71
    Williston
    Williston Well-Known Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    This reference in priceless! Thank you! Posted 6 years ago, but I only just discovered this. I have been building my own parts list since i got my truck last summer. It's mostly Toyota parts numbers, (things like tiny lamps in the switches) the bed slide rail end caps, antenna removal tool, and the rear-camera connector end-caps that you're supposed to put on the harness ends the harness when you remove the tailgate, gas door rubber bumpers, power outlet covers. All of this small stuff was missing or broken on mine when I got it. I scanned your list and the parts numbers I had that are on my list all matched yours. The front/rear/xfer case maint list and info is awesome. Nice! Thank you again.
  12. May 14, 2022 at 2:40 PM
    #72
    ToyotaGuy59
    ToyotaGuy59 Member
    Scott
    Houston
    ‘15 Silver Prerunner TX Edition
    TheOnlyPajooned likes this.
  13. Jun 18, 2022 at 4:40 PM
    #73
    jkauf
    jkauf Well-Known Member
    2013 Tacoma Supercharged - Stock
    Great write up. Just had a simple question cause I’m about to change my front & rear diff and transfer case oils
    the quick guide and manual say different types of oil for these jobs.
    Owners manual says to use:
    Differential F&R: 75w-85 GL-5
    Transfer: SAE 75w-90
    Quick guide says 75w90 for all three. Was this to make things simple?
    overall great post, thanks for all the info
  14. Jun 20, 2022 at 8:10 AM
    #74
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yes, very common for us to run 75w-90 in all three. You can get the real deal direct from Toyota if you want, but its expensive. Most any quality 75w-90 gear oil will carry the GL-5 rating
  15. Jul 7, 2022 at 1:46 PM
    #75
    whiskeybiscuit
    whiskeybiscuit Well-Known Member
    Awesome write up, subd for future maintenance.
  16. Aug 1, 2022 at 12:07 PM
    #76
    3dogs
    3dogs Member
    Pittsburgh
    2013 Tacoma TRD
    Well done! Thanks!
  17. Sep 24, 2022 at 7:52 AM
    #77
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Parking Brake Cable 2nd Gen.... Manual Transmission
    I am gearing up for some major damage on my VERY old original rear brakes...
    found 2 great videos for the 2nd Gen parking brake cable.
    First diagnosis. The cables have snapped free of the anchor on the rear and cause the brake to lock up (same symptoms I have)
    https://youtu.be/pmUmsf0WgeI?t=796
    And a very nice install...
    https://www.youtube.com/watch?v=4JuVrd5pUbA
  18. Jul 20, 2023 at 8:07 AM
    #78
    DrroyBeige
    DrroyBeige New Member
    2012 PreRunner 2.7L
    I see that this guide is for 4.0.
    Are the procedures more or less the same for a 2.7?
    My main concern for the moment is the coolant, this will be my first time flushing my truck and I wanted to do it right.
    Scrat likes this.
  19. Jul 20, 2023 at 7:53 PM
    #79
    Scrat
    Scrat GRYLNG
    Jacob
    Woodland Park
    V6 SR5 '15
    ARE CX Topper, Yakima rails with various accessories, Bilstein 5100, Icon RXT, OME 886 coils, Firestone Ride-Rite, 265/75/16 KO2, Mobtown Offroad Rear Bumper., Diode Dynamic map and dome lights, headlight harness, Cali-raised bed stiffeners, Cali Raised accessory bed mount, Cobra 75wx st, Leixen VV898e, Safari Snorkel, SOS Sliders, CBI Full skids pack, and more coming!
    From Auto Repair Source for 2.7, 2015yr
    COOLING SYSTEM AIR BLEED PROCEDURE
    Procedures
    Type Location Procedure
    - - A. Tighten the radiator drain plug
    B. Disconnect the 2 vinyl hoses.
    C. Slowly fill the system with engine coolant
    D. Check the coolant level inside the radiator by squeezing the inlet and outlet radiator hoses hoses several times by hand. If the coolant level goes down, add coolant.
    E. Install the radiator cap securely.
    F. Slowly pour coolant into the radiator reservoir until it reaches the FULL line.
    G. Warm up the engine until the cooling fan operates.
    H. Set A/C as follows: Fan speed : Anything except off. Temperature : toward warm. A/C switch :Off
    I. Squeeze the inlet and outlet radiator hoses several times by hand while warning up the engine.
    J. Stop the engine and wait until the coolant cools down.
    K. Remove the radiator cap and check the coolant level inside the radiator.
    L. If the coolant level is below the full level, perform the steps from C to K & repeat operation until the coolant level remains at the full level.
    M. Check the coolant level inside the radiator reservoir tank again, if low add coolant.
    IDK what it means in step B...if you don't have peacock valve then this might be the difference in the 2.7 and 4.0
    Otherwise. Seems very similar to 4.0. drain, fill run, and for flush, repeat. I've done it twice on my 2nd gen '15 4.0 no issues and very simple.
    I highly recommend a radiator fill funnel. Amazon has them for decent price.
  20. Jul 21, 2023 at 3:24 PM
    #80
    DrroyBeige
    2012 PreRunner 2.7L
    thanks for the help.
