Rear disc brakes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by s.wilson, May 20, 2020.
  1. May 21, 2020 at 11:07 AM
    #101
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    The mean average of the disc brake trucks unloaded is 143.2 compared to 147.7 of the Tacoma so it's 3% difference, the mean average of the loaded disc brake trucks is 147.2 compared to the Tacoma at 156.6 is 6% difference.
    Better performance, sure but is it a significant amount? No.
    boynoyce, JoeCOVA and auskip07 like this.
  2. May 21, 2020 at 11:09 AM
    #102
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    not worth putting $1500 to gain that 6% especially if people are looking for that be their first upgrade to the brake system
  3. May 21, 2020 at 11:11 AM
    #103
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
  4. May 21, 2020 at 11:17 AM
    #104
    Brofessor
    Brofessor Well-Known Member
    yep. 19 4runner’s brakes are very spongy-like and I need to press deep into the pedal. Not very confidence inspiring. On the other hand, 17 taco’s brakes have a much shorter engagement point and smoother feel.
    I much prefer driving the Taco than the 4runner... even with the drum brakes.
  5. May 21, 2020 at 11:22 AM
    #105
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    You didn't answer my question. Other than a few hundred bucks at the dealer, what downside is there to discs?
  6. May 21, 2020 at 11:24 AM
    #106
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Yup. SOS makes the backing plate and a small emergency brake cable adapter. Everything else comes straight from Toyota. The hardest part was removing the OEM backing plate from the drum brakes. I found it easiest to remove the axle and do it that way. No need for bearing removal or anything like that. Axle comes right out after you unbolt the bearing housing. Then cut away.
    I'm pretty sure the UPI kit and the Pedder's kit are one and the same. In case anyone was wondering.
    As far as them suggesting a master cylinder upgrade isn't necessary. I would agree. I ran mine with the OEM master cylinder for a bit, and it wasn't that bad. Doing the swap over to the Sequoia just made the pedal feel better and perhaps a little better braking force.
    The cost from SOS for the kit can be reduced. Or at least I was able to save a bunch of money. I got everything I could from Rock Auto, and then just got the backing plate kit from SOS. I want to say just the conversion kit was around $800 when all was said and done.
    Torspd likes this.
  7. May 21, 2020 at 11:25 AM
    #107
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    I did answer it, maintenance in the long run with rotors and pads would be more frequent than drums. Like I said in my case, in over 30+ years I've never had to replace / repair drums in any of my 5 trucks.
  8. May 21, 2020 at 11:27 AM
    #108
    pelts79
    pelts79 Well-Known Member
    I had 180,000 on my 05 tacoma, never touched the drums.
    boynoyce, stun gun and ToyoTaco25 like this.
  9. May 21, 2020 at 11:32 AM
    #109
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    This thread needs a drum brake... :rimshot: :rofl:
  10. May 21, 2020 at 11:41 AM
    #110
    rjdressen
    rjdressen Member
    Rich
    2020 Tacoma off-road Access Cab
    @vecdran weight does have bias however my F150 and the 2020 Ford F150 I test drove before buying this most recent Tacoma, did not share the same front brake bias as the Tacoma has. The braking isn't even close to being balanced on the Tacoma compared to other pickups, cars, and SUVs. It's never been great in this category and its why they've always needed front brakes around 30-40k.
  11. May 21, 2020 at 11:42 AM
    #111
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Discs are definitely more noisy & dirty. Definitely have to replace them more often. You still need to have a solution for a parking brake if you have rear discs - especially for a manual tranny. The fronts do most of the braking anyways. Not to mention how light the rear end is. With no weight on the rear end, how can you benefit at all from a better biting brake setup?
    On the other hand, discs brake pads definitely are much easier to replace. And "looks cooler" since everyone is concerned with looking cool.
  12. May 21, 2020 at 11:43 AM
    #112
    Pilsner
    18 TRDOR
    Rears don't need changing nearly as frequently as fronts to begin with, but even then pads are cheap and it takes as long to get your tools out and wheels off as it does to change pads unless you need rotors turned. For me that's an easy trade. I'm convinced that you just want to argue if that's your reasoning for drum superiority. I don't care how long you have had trucks, I'm not some rookie. I grew up working on circle track cars with my dad who raced. I have done full frame off rebuilds on 2 trucks and am working now on a third. I have had two track cars that had pad changes every time I got the track and when I left. I have replaced pads hundreds of times. I'll start a petition to go back to 4 wheel drums on the 2021 Tacoma and we can all save $300 on our next truck buy.
  13. May 21, 2020 at 11:44 AM
    #113
    TurboFire10
    TurboFire10 Well-Known Member
    Erik
    2018 TRD Pro
    ARE Revo, RCI rock sliders
    People just like overbuilding their shit for more than they actually need. How many trails actually require you to have 35’s or 37’s versus 33’s? And how many folks actually take their trucks on trails that extreme? Go ahead keep telling yourself you need an extreme build, should get a big brake kit if you “need” ultimate stopping power so bad.
    auskip07 and ToyoTaco25 like this.
  14. May 21, 2020 at 11:44 AM
    #114
    Pilsner
    18 TRDOR
    Rear braking is used more when loaded or towing then empty for sure. Rear discs have an internal drum e-brake.
  15. May 21, 2020 at 11:47 AM
    #115
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Sorry, you're right. On average the other 4 stopped 4.05 feet longer when loaded. The Tacoma stopped 8.9 feet longer... 2.2 times worse than the average of the rest of the group . All while having the second lightest payload added. Chevy - 1360 pounds, GMC 1400, Honda 1320 (lower payload than a Ridgline!) 880 for Nissan and 1000 for Toyota. :cheers:
  16. May 21, 2020 at 11:49 AM
    #116
    Pilsner
    18 TRDOR
    Of course we do. That's our thing. Dude, you bought a Pro. And those trails that "need" 35s or 37s, we don't even need to drive on them. I also don't need rifles that shoot half MOA at 500 yards when I can't, or giant titanium drivers when I suck at golf. So what? 'Merica
  17. May 21, 2020 at 11:51 AM
    #117
    ToyoTaco25
    North Carolina
    People like to re-invent the wheel. Fix shit that ain't broke, brother.
    Do it for Dale!
    Chew likes this.
  18. May 21, 2020 at 12:15 PM
    #118
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    So what....
    I'm not saying drums are superior to disc brakes, I'm saying there's no need to put rear discs on a Tacoma if drums work just fine. Judging by the sales over the other trucks in the segment most consumers seem to agree.
    You seem to be the one with a chip on his shoulder by "justifying" your view by your "experience in changing pads". I don't really care how fast you can change your pad, I haven't had the need to do anything with drums, most other people seem fine with that too.
    boynoyce, ToyoTaco25 and stun gun like this.
  19. May 21, 2020 at 12:25 PM
    #119
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
  20. May 21, 2020 at 12:31 PM
    #120
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    def several threads on this topic. which I assume has been mentioned. If someone you really want to do there are people that are helpful but expect a ton of this is a waste of time comments. If you are an Off Road or Pro model you will not be able to upgrade the master easily. I have a rear kit that has been sitting to the side due to that. I may get to it at some point but need more info on it. The conversions also use 5th gen brakes except the ones that went with BBK like @MESO
