2018 Tacoma 60k miles. blown cylinder and cracked head
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaB2013, Aug 1, 2022.
  1. Aug 5, 2022 at 8:19 AM
    #181
    erwigg
    erwigg Well-Known Member
    Eric
    Oregon Coast
    2022 Tacoma access cab SR
    sounds like a perfect job for you since you so kindly volunteered
  2. Aug 5, 2022 at 8:26 AM
    #182
    Toyko Joe
    Toyko Joe Here for the pictures
    It looks like you have a scratch then in the same place on the block? Idk maybe it’s just me looking at it. :notsure:
  3. Aug 5, 2022 at 8:32 AM
    #183
    erwigg
    Eric
    Oregon Coast
    its one of those odd weird life things:
    consider:
    - people post a crazy amount of stuff on social media (TW is a type of social media)
    - law enforcement find a suspect's rants on social media prior to the criminal activity
    -and yes there are creeper-people do cyber-stalk cyberbully and cyber harassment
    best way not to be found out about something? or not to be creeped out? we can't post it on social media..... ugh i don't like how this all sounded but kinda like what the police say to the ones who they are arresting: anything you say can and will be used against you
  4. Aug 5, 2022 at 9:16 AM
    #184
    egb1776
    egb1776 Well-Known Member
    2017 Tacoma OR
    What side of the timing does the pseudo Atkinson cycle control, intake or exhaust?
    *Disregard the question, almighty google answered me, intake timing is adjust.
  5. Aug 5, 2022 at 9:28 AM
    #185
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    So posting tables isn't a thing apparently. I did some digging and ran out of time... Lots of P11EC and EE codes out there.
    This might give yall some leverage with the dealer? Dunno.
    User
    Link
    Symptoms
    Year
    Milage
    TacomaB2013
    https://www.tacomaworld.com/threads/2018-tacoma-60k-miles-blown-cylinder-and-cracked-head.773619/
    check engine light, P11EE, head gasket, crackd head
    2018
    61000
    TRD-ED
    https://www.tacomaworld.com/threads...-failed-leak-down-test-only-16k-miles.773172/
    seat of the pants miss, check engine light, 2&6 failed compression test, burnt valves
    2020
    16000
    djgynee
    https://www.tacomaworld.com/threads/2018-piston-value-issue-updated-7-21-22.769771/
    P11EE, burnt valves, #3 cylinder
    2018
    75000
    connell
    https://www.tacomaworld.com/threads/2018-tacoma-in-the-shop-bad-head-problem.646806/
    P11EE
    2018
    40000
    dan the welder
    https://www.tacomaworld.com/threads/engine-failure-at-35k.605928/
    “improper af ratio code”
    2017
    35000
    DMP
    https://www.tacomaworld.com/threads/check-engine-code-p11ec.652502/
    P11EC, burnt exhaust valve cylinder 1, replaced cylinder head
    2018
    47000
    Disco
    https://www.tacomaworld.com/threads/check-engine-code-p11ec.652502/page-4#post-25610899
    P11EC, new head
    2018
    35000
    tielur
    https://www.tacomaworld.com/threads/check-engine-code-p11ec.652502/page-4#post-26006846
    P11EC, new head
    2019
    27000
    JoeComa90
    https://www.tacomaworld.com/threads...-bad-head-problem.646806/page-3#post-27551914
    P11EE , new engine
    2017
    80000
    JAL
    https://www.tacomaworld.com/threads/2018-popped-a-dtc-code-p11fo.736952/
    P11F0
    2018
    40500
    alexwlkr32
    https://www.tacomaworld.com/threads/burnt-valve.662650/
    new head
    2017
    25000
    duop
    https://www.tacomaworld.com/threads/2gr-fks-engine-failure.705778/
    new engine, no compression 5 & 6
    2017
    110000
    Stretch22
    https://www.tacomaworld.com/threads...-bad-head-problem.646806/page-3#post-27534339
    P11EE
    2018
    Crashoverride
    https://www.tacomaworld.com/threads/check-engine-code-p11ec.652502/#post-22714053
    P11EC, cyl1 burnt exhaust valve
    2017
    73000
    mdc399
    https://www.tacomaworld.com/threads...a-2019-trd-or-6mt.598160/page-2#post-27023157
    P11EC, cyl 1 fuel air imbalance, new head
    2019
    49000
    Twotacojuan
    https://www.tacomaworld.com/threads...a-2019-trd-or-6mt.598160/page-2#post-27382621
    P11F000 , cyl 5 a/f ratio imbalance, failed valve guides leading to burnt valve, new head
    2019
    67000
    TigerChris
    https://www.tacomaworld.com/threads/p11ec-cel-code-water-in-fuel.748826/#post-26692626
    P11EC, cylinder 1 burnt exhaust valves,
    2017
    85000
    eroc002200
    https://www.tacomaworld.com/threads/p11ec-cel-code-water-in-fuel.748826/#post-26719686
    bad valve seat
    2017
    95000
    juan2
    https://www.tacomaworld.com/threads/p11ec-cel-code-water-in-fuel.748826/page-2#post-26899253
    replaced head
    2019
    35000
    Chippyb13
    https://www.tacomaworld.com/threads/p11ec-cel-code-water-in-fuel.748826/#post-26675189
    P11EC, replaced head
    2017
    100k
    Beshaw1221
    https://www.tacomaworld.com/threads/check-engine-light.750405/
    head gasket and valves replaced
    2019
    26000
    ILuvTaco
    https://www.tacomaworld.com/threads/help-engine-trouble-under-warranty.681822/page-3#post-24043401
    P11EC, replace head
    2017
    31000
    20005spd
    https://www.tacomaworld.com/threads...l-5-broken-valve-spring.693907/#post-24524357
    cyl 5 no compression, shaking violently @ 70mph, broken valve spring
    2021
    300
  6. Aug 5, 2022 at 9:32 AM
    #186
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    Thanks for compiling those. It would seem it’s mainly an issue with 2017+ 3.5s then. Perhaps they tweaked it to meet tougher CAFE standards around that time and reliability is suffering as a result.
  7. Aug 5, 2022 at 9:33 AM
    #187
    0xDEADBEEF
    Not sure. from what I was reading, it was a lot of valve guide type stuff. Maybe they updated the head design or manufacturing process after 2019?
    Ozark_RegCab[QUOTED] likes this.
  8. Aug 5, 2022 at 9:35 AM
    #188
    Ozark_RegCab
    Nick
    Northwest Arkansas
    That’s possible. I gather there aren’t many reports on her of these issues in 2020-22 trucks?
  9. Aug 5, 2022 at 9:36 AM
    #189
    0xDEADBEEF
    Not really, but look at the milages. Good chance newer trucks haven't gone far enough yet to have given a meaningful report.
  10. Aug 5, 2022 at 9:38 AM
    #190
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I haven’t heard much about these failures in 2013-2018 Avalons and Camrys, so maybe it’s more prevalent in the 2GR-FKS as opposed to the regular FE. This is all just conjecture on my part though.
    0xDEADBEEF[QUOTED] likes this.
  11. Aug 5, 2022 at 9:40 AM
    #191
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Valve spring apparently broke on this one:
  12. Aug 5, 2022 at 9:40 AM
    #192
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Our sales reps drive Camrys, we have a few over the 200k mark.
  13. Aug 5, 2022 at 9:42 AM
    #193
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Yea my girlfriend has a 2013 Avalon, great car. It’s also faster than my old 2002 WRX lol
  14. Aug 5, 2022 at 10:34 AM
    #194
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    We aren’t talking about police looking for criminals. This is a huge corporation looking for ways to get out of paying.
  15. Aug 5, 2022 at 10:48 AM
    #195
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    When our guys were racing sk modified's, sometimes a valve spring or valve spring keeper would break. Our engine machinist chalked it up to sustained high rpm use rather than a defective part. Maybe a similar issue for some here. I know our service manage at the toyota dealer here said these engines aren't too happy when they have to run extended periods above 3k rpm.
  16. Aug 5, 2022 at 10:54 AM
    #196
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Yep. The polar opposite of just acknowledging the problem (which is WELL under the warranty period) and fixing it, and instead looking to see if the purpose built vehicle is actually used in the manner for which it was designed. Totally bizarre and over the line. I guess the monitoring shit they build into these vehicles to track all sorts of data isn't enough for them. For shame, Toyota. For shame.
    Ozark_RegCab likes this.
  17. Aug 5, 2022 at 11:57 AM
    #197
    Toyko Joe
    But but but you don’t get the HP peak until 6000rpm and torque is maxed at 4600 rpm? :goingcrazy::notsure: So why should it be babied at 3k rpm? :facepalm::frusty:
  18. Aug 5, 2022 at 12:17 PM
    #198
    erwigg
    Eric
    Oregon Coast
    no... you are right no one is looking for criminals.....I guess my question is why are people surprised/bothered/creeped out when their social media post come up later.
    but I digress from the point/opening statements of this post
  19. Aug 5, 2022 at 12:39 PM
    #199
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Does anyone know if there’s been enough backlash for Toyota corporate to honor the warranty on it? It has to be said it looks really bad on them..
    Talking about the GR86 here but some of the Tacomas refused service because of off-road use would apply also.
    MalinoisDad likes this.
  20. Aug 5, 2022 at 1:04 PM
    #200
    zoo truck
    None
    I think the 6k rpm is suppose to be for short bursts only if needed not to live there. I was recommended to keep the engine rpm under 2500 if you want long life.
    Junkhead likes this.
