Transmission The new 6 speed AC60 Series automatic in the 2016 " WRITE UP WITH PICS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gearcruncher, Jan 29, 2015.
  1. Jan 29, 2015 at 8:26 PM
    gearcruncher
    gearcruncher [OP] Well-Known Member
    Canadain bumper technician
    _AC60 AC60F AWR6B45
    __________________________________________________________________
    WHEN PERFORMING A TRANSMISSION LEVEL CHECK , YOUR ENGINE MUST BE RUNNING . Too many members are missing this very important part of the procedure
    https://www.wheels.ca/top-ten/seven-shifty-transmissions-to-avoid/#:~:text=When Toyota redesigned,to other automakers.
    Read what gears magazine has to say about your transmission .
    https://gearsmagazine.com/magazine/introducing-the-toyota-ac60e/
    Read how gears magazine checks your transmission fluid
    https://gearsmagazine.com/magazine/servicing-the-cooling-system-in-the-ac60e/
    Nomad valve body for supercharged and heavy towing applications
    https://automatictransmission.com.au/shop/nomad-heavy-duty-valve-body-to-suit-toyota-hilux-6-speed/
    Valve bodies are available but make sure you are buying the correct one for your application .
    https://www.shenghaiautoparts.com/shop/valve-body/ac60-valve-body/
    Downshifting complaint much the same as the A750E
    If you guys are having downshifting concerns you have to remember that your injectors shut off when you remove your foot from the gas pedal . Toyota did this to save fuel . Combine this with your torque converter remaining locked up can really be fealt in the drivers seat .
    If you are fealing a slight clunk while at a stop where you have to apply more break pedal , get use to it .
    Here are more downshifting concerns from fellow members https://www.tacomaworld.com/threads/3rd-gen-automatic-shiftin.396877/#post-10989186
    2016 Tacoma 6th Gear at 30mph ???????
    https://www.tacomaworld.com/threads/2016-tacoma-6th-gear-at-30mph.402179/
    Shifting issues with thew new 2016 , Watch this U tube video
    https://www.youtube.com/watch?v=gv5t92hfZnw
    Check your universal joints . When you purchased your truck , Toyota forgot to grease them . Look here for instructions https://www.tacomaworld.com/threads/check-your-u-joints.409042/page-36#post-12267209
    CHECK YOUR OWN FLUID LEVEL .... WRITE UP WITH PICTURES
    https://www.tacomaworld.com/threads/3rd-gen-automatic-transmission-fluid-level-check-diy.547455/
    I have the factory repair manual for your 2016/17 truck . Send me a pm and I will send you the file . You must be an active and contributing member at Tacoma World . If your post count is zero , I will not send the file
    TECHNICAL SERVICE BULLETINS
    https://www.tacomaworld.com/threads/t-sb-0077-16-rev-1.457782/page-61#post-14232103
    Transmission makes noise on hills ?
    https://www.tacomaworld.com/threads...ops-then-grinds-as-it-drifts-rearward.532217/
    Are you interested to find out whats been done to your truck while it was on warranty or another owner ?
    Type in your VIN # and see what,s been done to your truck at the dealership
    http://www.toyota.com/owners/web/pages/home
    Before you go to far , take a couple minutes out of your time and read this
    Here is a good explanation on how your transmission works . Take a couple minutes out and read it http://www.sonnax.com/tech_resource...in-the-pump-pr-converter-cooler-lube-circuits
    Got a clunk you cant figure out ? chances are you are feeling AXLE WRAP .
    Axle Wrap has been a burden to Tacomas for many years .
    Read here to figure out if you have it
    Axle wrap and clunking solved http://www.tacomaworld.com/forum/2n...-lurch-stopping-started-axle-wrap-solved.html
    LOW ON TRANSMISSION FLUID ?
    Delay to drive like a low fluid condition / reports are coming in . get your fluid checked https://www.tacomaworld.com/threads/low-idle-and-transmission-issue.39755
    You heard on the internet that there may be a low level concern ?
    Look here https://www.tacomaworld.com/threads/just-dropped-her-off-for-trans-issues.414853/
    Here https://www.tacomaworld.com/threads/transmission-slipping-when-cold-and-after-reverse.408895/
    Here https://www.tacomaworld.com/threads...tic-shifting-and-drivability-problems.401475/
    Here https://www.tacomaworld.com/threads...rive-transmission-creep.411337/#post-11612215
    Here https://www.tacomaworld.com/threads/3rd-gen-transmission-fluid-level-check.410615/
    Here https://www.tacomaworld.com/threads/tell-me-about-the-new-automatic-transmission.397788/
    3rd gen owners learning how the transmission works https://www.tacomaworld.com/threads...-automatic-transmission.397788/#post-11238563
    Driveline vibration 10 to 15 mph while slowing down
    TSB-0171-16 Driveline vibration
    https://www.tacomaworld.com/threads/oh-no-tsb-0171-16-driveline-vibration.463992/
    Install a transmission cooler on your 16/17 with pics ( Write Up )
    https://www.tacomaworld.com/threads/3rd-gen-transmission-cooler-upgrade.482280/#post-14723804
    TSB https://static.nhtsa.gov/odi/tsbs/2018/MC-10143952-9999.pdf
    Watching transmission temps with torque pro ?
    https://www.tacomaworld.com/threads...-pids-for-torque-pro-and-similar-apps.513531/
    Transmission Fluid Temperature PIDs for Torque Pro and NOW APPLE!
    https://www.tacomaworld.com/threads...ure-pids-for-torque-pro-and-now-apple.513531/
    Speed sensors
    https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/AC60E/product/19981/
    Complete teardown
    https://www.youtube.com/watch?v=Qs2P-uENGh0
    Changing your transmission fluid ???????????????????
    Listen to the guys who do it every day
    http://www.atra.com/transmission_service
    Howling noise fix https://www.tacomaworld.com/search/1300913/
    LISTED BELOW ARE THE UNSOLVED PROBLEMS THAT MAY BE TRANSMISSION RELATED .
    Buzzing issues https://www.tacomaworld.com/threads/poll-how-many-of-you-are-having-vibration-issues.400856/page-3
    2nd gear to 3rd gear upshift flare when cold
    https://www.tacomaworld.com/threads...ot-hunting-or-vibration-related.427172/page-2
    High speed vibrations https://www.tacomaworld.com/threads/unusual-vibration-at-higher-speeds.397620/page-2#post-11150675
    Vibration at 2000 rpm https://www.tacomaworld.com/threads/vibration-in-gas-pedal-floorbed-and-steering-wheel.394823/
    Whining noise inside the cabhttps:// AB60 valve body swap https://www.youtube.com/watch?v=Du5X7LcVX5c
    Shift modulation package for the ab60 trans http://www.ukrtrans.biz/files/2011/10/Toyota_AB60_Transmission.pdf
    Aftermarket shift solution!
    https://www.tacomaworld.com/threads...troller-now-available-for-gen3-tacoma.490113/
    SHOULD YOU USE THE PARKING BRAKE WITH AN AUTOMATIC
    I use the ebrake every day and I have an automatic transmission. Using the ebrake when parking is recommended in the Toyota manual . Living way up North in the snow as I type this , they use all kinds of salt .Its better to use the ebrake than have it seize up solid and pay $500 bucks to have all the cables replaced when its time to sell the truck.
    With this said , using the ebrake keeps the rear brake shoes adjusted properly and saves your front brakes from wearing quickly
    You're also being very nice to the parking pawl inside your transmission. Lots of people just jam it into park on an incline and don't ever use the e-brake. Or worse, jam it into park when the vehicle is still rolling. An e-brake cable is a cheap fix compared to a transmission problem.
    Look what happens when you dont use the E brake http://www.tacomaworld.com/forum/2nd...ml#post9531711
    HondaGM, genotekate, tonered and 14 others like this.
  2. Jan 30, 2015 at 9:49 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Interesting link there :thumbsup:
  3. Oct 29, 2015 at 12:35 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    @gearcruncher Are you looking for what model is new transmission ?
    In all the documents now new transmission is listed as Its AC60 E/F
  4. Dec 13, 2015 at 11:10 AM
    gearcruncher
    Select parts.
    car name 711160 HIACE/REGIUSACE (2013/12 - )
    model name TRH226K-LRTDK6 (2015/01 - )
    ENGINE 1 2TRFE 2700CC 16-VALVE DOHC EFI
    BODY V1 STANDARD VAN
    GRADE DX DX TYPE
    GEAR SHIFT TYPE 6FC ATM, 6-SPEED FLOOR SHIFT
    ROOF HRF HIGH-ROOF
    NO.OF DOORS 4D 4-DOOR
    SIDE WINDOW SG SIDE GLASS
    SEATING CAPACITY 02S 2-SEATER
    BUILDING CONDITION IV6 CAMPER CHASSIS
    DRIVE TRAIN 4WD 4 WHEEL DRIVE
    Select image size.
    [​IMG] [​IMG] [​IMG]
    • [​IMG]
    Enter the parts code or parts number
    parts code parts no parts name start - end note PRICE/1 QTY(JPY) PRICE/1 QTY(USD)
    04351 04351-26210
    Add inquiry
    GASKET KIT, AUTOMATIC TRANSMISSION OVERHAUL 2015/01 - TRH216,219,226,228,229 CONTACT US CONTACT US
    30030 30030-26B90
    Add inquiry
    TRANSMISSION ASSY, REBUILT 2015/01 - TRH216,219,226,228,229 CONTACT US CONTACT US
    35000 35000-26B90
    Add inquiry
    TRANSMISSION ASSY, AUTOMATIC 2015/01 - TRH216,219,226,228,229
    AC60F CONTACT US CONTACT US
    Parts http://toyota.7zap.com/en/jp/hiace/711160/trh200v-
    rktdk/2/3512/359187a/
    http://toyota.7zap.com/en/jp/hiace/711160/trh219w-jdtdk/2/3512/359185/
    Part code Title information
    90105-06053 BOLT(FOR MANUAL DETENT SPRING)
    90105-06255 ** Std Part
    90105-05005 BOLT (FOR TRANSFER RELIEF VALVE PLATE)
    35303A 11 RING, O (FOR OIL STRAINER)
    35210B 11 VALVE, SOLENOID(SL3)
    35290C 11 VALVE, SOLENOID(SLT)
    35280A 11 VALVE, SOLENOID(SLU)
    35290B 11 PIN, STRAIGHT (FOR LINE PRESSURE CONTOROL SOLENOID)
    35285 11 PLATE, SOLENOID LOCK
    35330 11 STRAINER ASSY, VALVE BODY OIL
    35410 11 BODY ASSY, TRANSMISSION VALVE
    35210D 11 VALVE, SOLENOID(SL4)
    35210A 11 VALVE, SOLENOID(SL1)
    35210C 11 VALVE, SOLENOID(SL2)
    91511-C0625 ** Std Part
    91511-C0635 ** Std Part
    90105-06202 BOLT(FOR CYLINDER HEAD COVER)
    35240D 11 VALVE, SOLENOID(SL)
  5. Dec 13, 2015 at 12:05 PM
    gearcruncher
    genotekate likes this.
  6. Dec 13, 2015 at 12:06 PM
    gearcruncher
    One thing I am not a fan of is a pre heater and all you 3rd gens have it .
    When you start your truck in the morning , the pre heater bypasses the transmission cooler and circulates the fluid leaving the torque converter and directs that fluid back to the transmission pan .
    You rely on 1 tiny valve always functioning properly .
    What happens when that 1 tiny valve sticks in the open position and you continue driving your truck ?
  7. Dec 13, 2015 at 12:06 PM
    gearcruncher
    tundra fill procedure
    Title: AB60F AUTOMATIC TRANSMISSION: AUTOMATIC TRANSMISSION FLUID: ADJUSTMENT
    NOTICE:
    This transmission requires Toyota Genuine ATF WS.
    After servicing the transmission, you must follow the ATF adjustment procedure.
    Maintain the vehicle in a horizontal position while adjusting the fluid level.
    1. PRELIMINARY PROCEDURES
    (a) w/ Trailer Towing System (w/Transmission oil cooler thermostat):
    (1) Using compressed air, etc., blow dust off the thermostat cap to clean it.
    (2) Using a screwdriver, push the shaft of the thermostat.
    HINT:
    Pushed amount: 5.5 to 7.0 mm (0.217 to 0.276 in.)
    Push the shaft until the screwdriver contacts the step inside the cap.
    (3) With the shaft of the thermostat pressed, push a pin into a hole on the side of the thermostat's cap. Insert the pin until it passes through the hole on the other side of the thermostat's cap to fix the shaft in place.
    HINT:
    Pin diameter: 1.0 to 1.8 mm (0.0394 to 0.0709 in.)
    2. BEFORE FILLING TRANSMISSION
    When you have replaced the entire transmission, transmission pan, drain plug, valve body and/or torqueconverter, proceed to the "TRANSMISSION FILL" procedures.
    When you have replaced the transmission hose and/or output shaft oil seal, proceed to the "FLUID TEMPERATURE CHECK" procedures.
    3. TRANSMISSION FILL
    (a) Remove the refill plug and overflow plug.
    (b) Fill the transmission through the refill hole until fluid begins to trickle out of the overflow tube.
    (c) Reinstall the overflow plug.
    (d) Fill the transmission with the amount of fluid listed in the table below.
    Reference Capacity:
    Repair
    Fill Amount
    Transmission pan and drain plug removal
    2.1 liters (2.2 US qts, 1.8 Imp. qts)
    Transmission valve body removal
    4.7 liters (5.0 US qts, 4.1 Imp. qts)
    Torque converter removal
    6.1 liters (6.4 US qts, 5.4 Imp. qts)
    (e) Install the refill plug.
    HINT:
    If you cannot fill the listed amount of fluid, do the following below:
    (1) Start the engine to idle.
    NOTICE:
    Check that electrical systems such as the air conditioning system, audio system and lighting system are off.
    (2) Move the shift lever through the entire gear range to circulate the fluid.
    (3) Wait for 30 seconds with the engine idling.
    (4) Stop the engine.
    (5) Remove the refill plug.
    (6) Fill the transmission with the remaining fluid until the amount in the table has been filled.
    (7) Install the refill plug.
    4. FLUID TEMPERATURE CHECK
    NOTICE:
    The ATF temperature can be confirmed by using a Techstream.
    (a) Turn the ignition switch off.
    (b) Connect the Techstream to the DLC3.
    (c) Turn the ignition switch ON.
    (d) Enter the following menus: Powertrain / Engine and ECT / Data List / A/T Oil Temperature 1.
    (e) Check the ATF temperature.
    NOTICE:
    If the ATF temperature is above 44°C (111°F), turn the ignition switch off and wait until the fluid temperature drops to between 37 and 44°C (99 and 111°F).
    5. FLUID LEVEL CHECK
    NOTICE:
    It is necessary to change to temperature detection mode in order to idle the vehicle appropriately.
    The ATF temperature must be between 37 and 44°C (99 and 111°F) to accurately check the fluid level.
    (a) Enter the following menus: Powertrain / Engine and ECT / Active Test / Connect the TC and TE1.
    Standard condition:
    Indicator lights on the combination meter blink.
    HINT:
    Also when not using the Techstream. Using SST, connect terminals 13 (TC) and 4 (CG) of the DLC3.
    SST: 09843-18040
    (b) Start the engine to idle.
    NOTICE:
    (c) Slowly move the shift lever from P to S, then change the gear from 1st to 6th. Then return the shift leverto P.
    HINT:
    Slowly move the shift lever to circulate the fluid through each part of the transmission.
    (d) Move the shift lever to D, and quickly move back and forth between N and D (once within 1.5 seconds) for at least 6 seconds. This will activate the fluid temperature detection mode.
    Standard condition:
    Indicator light [D] remains illuminated for 2 seconds and then turn off.
    (e) Return the shift lever to P and terminate the Active Test on the Techstream.
    (f) Using the Techstream, allow the engine to idle until the fluid temperature reaches 37 to 44°C (99 to 111°F).
    HINT:
    The indicator [D] will come on again when the fluid temperature reaches 37°C (99°F) and will blink if it exceeds 44°C (111°F).
    Indicator [D] Indication of ATF Temperature
    Below 37°C (99°F)
    Exceed 44°C (111°F)
    Turn off
    Turn on
    Blinking
    (g) Remove the overflow plug with the engine idling.
    (h) Wait until the overflow slows to a trickle.
    NOTICE:
    If the fluid does not overflow, do the following below:
    (1) Remove the refill plug.
    (2) Refill the transmission through the refill hole until fluid begins to trickle out of the overflow tube.
    (3) Wait until the overflow slows to a trickle.
    (i) Install a new gasket and the overflow plug.
    Torque:
    20 N·m {204 kgf·cm, 15ft·lbf}
    (j) Install a new gasket and the refill plug.
    Torque:
    39 N·m {400 kgf·cm, 29ft·lbf}
    6. COMPLETE
    (b) Disconnect the Techstream from the DLC3.
    (c) w/ Trailer Towing System (w/ Transmission oil cooler thermostat):
    (1) Remove the pin by pushing the shaft with a screwdriver.
    NOTICE:
    Make sure the shaft of the thermostat is protruding from the hole on the cap.
    (d) Inspect for automatic transmission fluid leak.
    NCtaco914 and dontstealmyride like this.
  8. Dec 13, 2015 at 12:06 PM
    gearcruncher
  9. Dec 13, 2015 at 12:06 PM
    gearcruncher
    saved for write up
  10. Dec 13, 2015 at 12:06 PM
    gearcruncher
    saved for write up
  11. Dec 13, 2015 at 12:07 PM
    gearcruncher
    saved for write up
  12. Dec 13, 2015 at 12:07 PM
    gearcruncher
    saved for write up
    Bossman14 likes this.
  13. Dec 13, 2015 at 12:07 PM
    gearcruncher
    HOW TO DOWNLOAD THE COMPLETE REPAIR MANUAL FOR YOUR TRUCK DIRECTLY FROM TOYOTA .
    How to download repair manual from TIS
    https://techinfo.toyota.com/techInf...urce_url=https%3A%2F%2Ftechinfo.toyota.com%2F
    The toyota information system contents toyota vehicle repair manual which used to be PDF links, it's now chm mode which is only webpages. I am trying to download the manual for my vehicle in two days and here is the fastest way I figured out.
    Please share if you have better idea. I can't make those hyper-link work since they all became image in the pdf files.
    Tools you will need
    Firefox
    PDFCreator
    TIS login account ($15/2 days)
    Install PDFCreator, create a new profile, change the Auto-save option; Change the filename to <Title>, update the directory for auto-save. You need create a new printer to use this new profile, which can auto save your pdf to particular folder.
    Login TIS and open the repair manual, for the first page, make sure you selected the new PDFCreator printer as your current printer and print your first page, double check the pdf file at the auto-save folder and make sure that fits you want. I took the footer and header off so it looks much nicer.
    For firefox, type “about:config” in the address bar and add print.always_print_silent as Boolean and set it to true.
    Now, for each page you click on the left, there is a print icon on the top right corner, click that will print a new pdf file to the auto-save folder. For each page, you will need two clicks to save to pdf format.
    Go through all your pages and hit the printer icon. You should be able to download the repair manual in couple hours. The PDF files will have the full text title in the pdf file name, which you can easily search.
    I got my two vehicles' repair manual done in 7 hours.
  14. Dec 13, 2015 at 12:23 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    What is the difference between AC60E and AC60F ?
  15. Dec 13, 2015 at 12:25 PM
    gearcruncher
    2 wheel drive and 4x4 . The extension housing on the rear of the transmission and the output shaft are different
  16. Dec 13, 2015 at 12:32 PM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    Here's a dumb question. Is there a transmission fluid dipstick on the 2016? I can't seem to find mine.
  17. Dec 13, 2015 at 12:34 PM
    gearcruncher
  18. Dec 13, 2015 at 12:34 PM
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    2016 Blk TRD Sport 4X4 DCSB
    Cracked W/S
    That's a negative ghost rider.
  19. Dec 13, 2015 at 12:36 PM
    FritoBandito
    Texas
    Thanks! Thought my eyes were deceiving me. Mine also has the issue when it's cold and I put it into drive it doesn't seem to engage.. then lurches.
  20. Dec 13, 2015 at 12:42 PM
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    Same checking procedure as the 2nd Gen except for one thing. Once you are in AT TEMP CHECK mode you remove the jumper from the OBD2 port. This allows the engine idle control to operate so you can get an accurate reading.
