JC1980's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by jc1980, Dec 11, 2013.
  1. Dec 11, 2013 at 9:20 PM
    jc1980
    jc1980 [OP] Well-Known Member
    MGM 4x4 TRD Off-Road (Extra Value Package II)
    See build link in signature or public profile.
    2014 Double Cab Automatic 4.0L V6 MGM 4x4 TRD Off-Road (Extra Value Package II)
    This is my first truck and I wanted to keep track of my mods, so I'm posting it in this thread. (It's a little messy, but does what I need.)
    This truck is also my daily driver and only vehicle.
    Tips and constructive criticism welcome.
    Purchased from Las Vegas Felcher Jones Toyota on 10/11/13.
    Some Nevada stuff and trail info:
    BLM OHV use and closures (check out the links on the right of the page also):
    http://www.blm.gov/nv/st/en/fo/lvfo/blm_programs/lvfo_recreation.html
    This site has some decent downloadable trail maps: http://offroadinghome.com/nevada/nevada.htm
    EveryTrail (offroading, biking, outdoors, hiking, etc): http://www.everytrail.com/browse.php?country=United+States&state=Nevada&activity_id=32
    A list of misc lift laws and where to find them on the NRS: http://www.liftlaws.com/nevada_lift_laws.htm
    Misc trails (backroads, hiking, wilderness, wildlife, etc): http://www.birdandhike.com/
    Some trails I took that I mapped using BackCountry Navigator TPO GPS:
    Potosi Pass->Wilson Pass->Goodsprings->Cottonwood Pass->Blue Diamond
    Rocky Gap Road from Blue Diamond side to Red Rock
    Burro Wash
    Mormon Well Road
    *Haven't been recording or taking pictures of recent trail rides.*
    FRONT SUSPENSION
    -Icon Stage 7 from SDHQ (12/2013 version)
    ------Billet Upper Control Arm
    ------Extended Travel Remote Reservoir Coil-over Shock Kit with CDCV
    -700# Icon springs installed by
    Matthew and crew at MCM Fab
    -Wheeler's Front Super Bumps
    -Wheeler's Front Super Bump Spacers (3/8" installed due to UCA's hitting fender well, added another 1/4"due to tires hitting upper fender well corner)
    -Sway bar removed
    REAR SUSPENSION
    ------2.5" Diameter Rear Remote Reservoir Shocks with CDCV
    ------2.0 Hydraulic Air Bump Kit
    All-Pro U-bolt flip kit
    Icon U-bolt flip striker plate
    -OME Dakar Leaf Pack (CS047R) +Extra Leaf (D29XL) and bushing kit from
    Wheeler's Off-Road, Inc. with 3° steel shim
    ------Napa U-Bolts Part # 650-4014 (Toytech U-bolt Flip Kit U-bolts are not long enough)
    DRIVETRAIN, BRAKES
    -All-Pro (Crown Performance) Stainless steel brake lines
    Differential breather mod into driver side bed lock box
    -Total Chaos Weld-on Spindle Gussets installed by Matthew and crew at MCM Fab
    -Beefed Taco carrier bearing bracket and frame plugs
    ENGINE
    -Exhaust rerouted with 14" Magnaflow (think it is 12198) exhaust and turndown before rear axle done by
    Sandrider213's family's shop Best Muffler Shop
    WHEELS AND TIRES
    -Cooper Discoverer ST Maxx LT285/75R16 from
    Discount Tire Direct mounted on SCS F-5's 16x8 4.50" BS in Shot-Peen Style Matte Gray by Firestone Complete Auto Care.
    ------TR412 valve stems(<1", 65# rating)
    ------Glad I had the CMC done by
    Matthew and crew at MCM Fab before installing
    ------Needed to trim lower part of fender flare
    ------Needed to bend down pinch weld a bit along with the lower body portion that the fender flare bolts on to
    ARMOR
    -4xinnovations rock sliders with kickout (Line-X'd - should have gone with powder coat or rattle can)
    BAMF Rear Differential Skid Plate
    -Hybrid front bumper
    -Relentless Fabrication full skid plate set (alignment issues with first t-case skid and alignment issues with second t-case skid)
    ------REMINDER TO SELF: DO NOT ORDER FROM THIS VENDOR IF YOU WANT QUALITY EQUIPMENT THAT FITS PROPERLY. I didn't read
    this post before making the order.
    ------T-case skid plate fixed by
    -RCI Metalworks fuel tank skid
    -Rear Bumper
    -Reinforced Steel Tailgate Skin by Mobtown Offroad with vertical ribs
    EXTERIOR
    -Removed decals
    -Debadged
    -Mud flaps removed
    -Pop N Lock driver side bed lockbox
    Beefed Taco frame plugs
    B.A.M.F. Bed Tie Downs
    -Pop & Lock PL5400
    -DIY Tool Mounts inspired by
    DIY Hi-Lift and Tool Mounts thread (used a thicker and wider flat bar)
    -Hi-Lift jack bed mount
    -Total Chaos Bed Stiffeners
    -BOLT 5/8" Receiver Lock TOYOTA
    -Color matched grille from
    Camelback Toyota Parts
    -Toyota D-Rings on center and fwd bed bolts
    -1" RAM motorcycle handle bar top clamp M6 fitting on driver side front roof rack mounting hole to mount a GoPro (having too much glare from front windshield on videos)
    Andres Black Shot-peened Devil Horn emblem on grill and Model T emblem on front skid plate
    -Delta Bike Hitch Pro Locking Fork Mount
    -Front fenders removed
    -Trimmed inner lip of front fenders, tires hitting and bending them when bottoming out.
    INTERIOR
    -Broadway mirror clipped on
    -Tinted SunTek 18%
    BirdDawg IndustriesClearview-Rearview
    -BirdDawg IndustriesTech Deck
    -Salex Center Console Organizer
    Salex Glove Box Organizer
    Icon billet auto shift knob
    -OTRATTW Contura V Rockers on center console and rear sunglasses holder (upper LED independent and lit from shifter column dimmer, lower LED dependent)
    -Misc RAM mounts
    -Rugged Ridge 13305.14 Grab Handles
    -Big Sky SBR-2G Gun Rack on DIY 1" brackets mounted on rear grab handle bolts
    -Front and Rear Weathertech FloorLiner™ DigitalFit®: Black
    Blueinstinct's Armrest / Center Console Cover
    LIGHTING
    -DIY LED strip hood light on pin switch
    -10W CREE light form
    Lifetimeledlights on a DIY mount on my bed rail.
    Map light on with dome light
    -Rigid Industries 90521 SR-Q White Spotlights installed on Famous Fabrication hood hinge light brackets
    -Fog Light Anytime mod thanks to ND4
    -Mounted on front bumper
    ------Rigid Industries 50231 D2 Driving Lights
    ------Lifetime LED 20" 20 LED bar
    -2x 3VP-RS LED Light by Flyzeye Designs
    Beefed Taco frame light mounts
    -Rigid Industries 93551 SR-Q2-Series Flush Mount White Diffused on Rear Bumper
    COMMS, ELECTRONICS, SAFETY, RECOVERY GEAR
    -Aux fuse block tray and setup (Blue Sea 7144 circuit breaker and 5026 fuse block)
    -OTRATTW Contura V Rocker LED swap from blue to white (didn't have the independent/dependent combo I wanted in white)
    -DROK USB interface power supply in overhead console for items mounted near rear view mirror (always on)
    -Blueskysea dash cam in front of rear view mirror
    Ultra-Gauge installed on windshield mount
    -Battery Cage with Group 31M battery (Northstar NSB-AGM31M on July 2016, NSB-AGM31 on February 2022)
    -Viper 5706v with remote start(Install Guide)
    -Hypertech Speedometer/Odometer Recalibration Device 730117
    -Cobra 75 CB (plug on center console) and antenna (on Passenger
    BAMF CB Mount)
    ------Cobra AC 702 4-Foot Microphone Extension Cable
    ------Firestik Fire-flex Cable Assembly W/low-profile Fire-ring and Stud
    ------Firestik SS-3H Heavy Duty Stainless Steel Antenna Spring
    ------FireStik K-1A Push-n-Twist quick disconnect
    ------Firestick II 4 feet Tunable Tip- Black
    -Red Fire Stick W/orange Safety Flag - 4ft
    ------Firestik R-1A External Locking Quick Disconnect
    ------Firestik SS-H2F Heavy-duty Safety Flag Mounting Spring
    -2x
    Armor Tech Offroad NATO Jerry Can Mounts (pre-drilled mounting holes on Jerry Can Mounts do not line up to bedrails, had to drill new holes to fit)
    ------1 red and 1 blue jerry can from
    Lexington Container Company
    -Hi-Lift X-Treme Jack and heavy duty base plate
    -Misc survival and recovery gear
    -Engo Model EPF12000S (solenoid relocated to passenger side aft engine bay)
    -Factor 55 ProLink Loaded
    -Factor 55 Aluminum Hawse Fairlead 1.5
    -2x sets of Maxtrax from the
    Maxtrax GB!! (using Maxtrax carry bag for storage)
    MISC
    -Firestone Complete Auto Care Lifetime Alignment
    -Discount Tire Warranty
    -Cushioned Ball Mount For 2" Hitch: 10-3/4" Rise - 12" Drop - 10,000 lbs etrailer.com
    FUTURE MODS/WISH LIST/IN PROGRESS
    -Misc LED's to make use of all the OTRATTW Contura V Rockers (front roof, rear roof, grille, reverse, etc)
    Misc photos on post #4
    Pictures of some mods on post #6
    Dalandser likes this.
  2. Dec 22, 2013 at 7:24 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Great start! ;)
  3. Dec 22, 2013 at 7:29 PM
    Yotski
    Yotski Well-Known Member
    Alex
    Hilo, Hawaii
    13 SSM Access Cab V6 6 Speed 4x4 TRD Off-Road
    Wet Okoles, Toytec BOSS 3in Kit, Allpro Standard Leaf pack, Ext Bilstein 5100, OEM Skid Plate(destroyed), Thule Racks, Method NV, KM2s, Rigid Grille & Light Bar
    Looking good so far! I noticed you want zero trimming. So did I. I have 16x8 rims with 265/75 KM2 and i have no rubbing and no trimming. Perfect for me. :D
  4. Jan 27, 2014 at 4:01 PM
    jc1980
    A few days after getting it (already had a few things before I purchased the truck).
    SDHQ Icon Stage 7 Suspension Kit with All-Pro U-bolt flip kit, Icon U-bolt flip striker plate and All-Pro (Crown Performance) Stainless steel brake lines
    Before and after suspension install.
    12/10/13:
    01/25/14:
    03.01.14 (Solo run almost to Burro Wash. I turned around right near the end because it looked like it was going to start pouring.)
    03.09.14 (Solo run from Potosi pass to Goodprings back up to Blue Diamond near the Travel Center)
    03.23.14 (Solo run on Rocky Gap Road from Blue Diamond to Red Rock. Took the easiest routes.)
    03.24.14 Made it to Burro Wash this time
    06.06.14 Out in the desert shooting
    06.17.14 Test driving new wheels and tires. Still have some trimming/fitting to do.
    06.18.14 Out checking tire clearance
    09.10.14 Photos I edited that I took at work.
    IMG_20140910_new_zps476a4334_f78fbdef90900f5329098775e9b4814060cd1627.jpgsideeagle_zpsbdde9faf_2a32f8f0a7a765ad22118d54c48be38f89a6a3e4.jpg
    10.17.14 Mormon Well Road
    01.18.15 Delamar Ghost Town, NV
    20150118_1253052_zpser8yibec_edit_142165_6ea27d4c830a9ca8f80c78f2d3e80a9df6f80d3f.jpg
    At home after the run:
    03.21.15
    06.19.15
  5. Mar 6, 2014 at 8:18 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
  6. Mar 15, 2014 at 10:13 PM
    jc1980
  7. Mar 15, 2014 at 10:13 PM
    jc1980
  8. Mar 15, 2014 at 10:27 PM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    Sub'd. Very nice so far.
  9. Mar 16, 2014 at 12:31 AM
    TheRedTac0
    TheRedTac0 Just a Taco guy, both food & truck
    Christopher
    Las Vegas
    2006 5-lug Regular Cab Impulse Red
    BHLM, Black Housing Altezza Taillights, 3-piece billet grille, Fatbob's 2.75" Lift with AAL, 15x8 Ion Alloy Wheels wrapped in 31x10.5 Falken's
    You should make it out to a Vegas/BBT meet sometime :D
    nice to see another Hendo representative :cool:
    Check it out on the Vegas BS thread!
  10. Mar 16, 2014 at 1:27 AM
    jc1980
    Will do! Sub'd to the Vegas BS Thread, I've been checking up on it every so often when there are updates.
  11. Apr 16, 2014 at 8:31 PM
    ThomasMore66
    Did you ever decide on 265 vs 285 tires? Having the same debate.
  12. Apr 17, 2014 at 12:08 AM
    jc1980
    After all the things I have already done to the truck, I wouldn't mind trimming if needed. I'm thinking of going 285. I'm just waiting on some funds and other mods to be completed, which may take a few months or so.
  13. Apr 17, 2014 at 3:24 AM
    ThomasMore66
    Have you used the CDC valve on the shocks? My stage 4 doesn't come with that standard, but I understand the stock setting is an equivalent to 4.
  14. Apr 17, 2014 at 6:12 AM
    jc1980
    Yeah, and there is a noticeable difference. I initially kept it at 4 and set it to 6 or 7 while off roading. Now I set it on S (lowest) for normal street driving and 5 or 6 off road. I haven't set it to the highest setting yet.
  15. Apr 17, 2014 at 7:21 AM
    ThomasMore66
    I think I can add it to my shocks in the future. How is it to turn that knob once you've been through mud, etc.? It needs a solenoid and a switch from the cab...
    Sorry to see your note about R-Fab. I was leaning that way for some future mods. Now I'll re-think.
  16. Apr 17, 2014 at 12:23 PM
    jc1980
    You can definitely upgrade them. I haven't done a mud run in the truck yet, but it shouldn't be too bad as long as you don't mind getting dirty and if needed just wash the knob off a bit. An in-cab adjustable shock would be nice. I just adjust my shocks when I let the air out of my tires and reset them when I air them up, I also do a pre and post inspection of the truck then too.
    I'd rather not get into it, but I wouldn't let my experience sway you from them. I didn't appreciate how they dealt with my issue, their initial "fix", and that their excuse for the problem does not seem logical from a customer and production perspective. You should definitely do your research on products the companies that make them to make proper comparisons. The main reason that I went with them is that they were in state and I wanted to spend my money here first before I went out of state.
  17. Apr 17, 2014 at 12:44 PM
    bullaculla
    Da big big island!
    Great pics and video :)
  18. Apr 17, 2014 at 7:35 PM
    ThomasMore66
    So, what did you have to do to manage this: Wheeler's Front Super Bump Spacers (3/8" installed due to UCA's hitting fender well)? I'll have the same UCA's once I get everything installed.
  19. Apr 17, 2014 at 8:31 PM
    jc1980
    There is a nice short stretch of dirt road on the way to work that I take to bypass traffic and only adds 5-15 mins to my normal no traffic travel time depending on how fast I want to go, and I usually try to go faster than I should. The main one I take is the reverse route of the Primm dirt track to Jean airport video above and another harsher route on the other side of the freeway when that main one is closed due to races. There are also quite a few trails around Vegas that you want to go relatively fast in, but I'm trying to slow down on those types of roads now. It's just from hard hits going fast on bumps. Here is a video of the bumps compressing on this post by DDD.
    The red circles highlight some of the points of contact:
  20. Apr 17, 2014 at 8:48 PM
    ThomasMore66
    I'm dying to have my stage 4 installed. I got OME leafs in lieu of the AAL's and that's what's holding up the show.
    ecgreen likes this.
