TW Threads discussing rust prevention/treatment
Discussion in 'General Automotive' started by TacoGlenn, May 7, 2021.
  1. May 7, 2021 at 7:53 AM
    TacoGlenn
    TacoGlenn [OP] Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    see also: Rust Prevention/Treatment Consolidation Thread | Tacoma World
    Undercoating - new to the salt belt | Tacoma World
    products discussed: Amsoil, Cosmoline, Eastwood, Fluid Film, Ospho, Woolwax
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/349019-salt-protection.html
    products discussed: CRC 3-36, Fluid Film, Krown, Rust Check, Thompson's Water Seal
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/310580-tacoma-rust-prevention-experiment.html
    kudos to TM member Cold Iron for hands-on testing
    products discussed: Amsoil HDMP, bar and chain oil (no brand specified), Blaster Corrosion Stop, Boeshield T-9, Rust Cure 3000, CRC Heavy Duty Corrosion Inhibitor, CorrosionX Heavy Duty, Fluid Film, motorcycle chain lube (no brand specified), Tectyl 185GW, WD40 Long Term Corrosion Inhibitor
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/344874-fluid-film-question.html
    products discussed: Eastwood Rust Encapsulator, Fluid Film
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/307427-should-i-get-undercoating-applied.html
    products discussed: Fluid Film, Krown, Ospho, Por 15, Tectyl 185GW, WD40, Ziebart
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/302425-fluid-film-rust.html
    products discussed: bar and chain oil (no brand specified), Boeshield, Rust Cure 3000, Eastwood Internal Frame Coating, Fluid Film, Krylon, Por 15, Rustoleum, used motor oil, WD40
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/299334-undercoating.html
    products discussed: Rust Cure 3000, Eastwood Rust Encapsulator, Eezox, Fluid Film, hydraulic fluid, KBS RustSeal, kerosene, Krown, Por15
    http://www.tacomaworld.com/forum/1st-gen-tacomas/277203-rust-prevention.html
    products discussed: Eastwood Rust Encapsulator, Fluid Film, KBS RustSeal, Por15, Rust Check,
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/197023-rust-prevention.html
    products discussed: Amsoil HDMP, bar and chain oil, melted paraffin and mineral spirits, chainsaw oil (no brand specified), Fluid Film, Husqvarna chainsaw oil combined with wax candles, Krown, Lanox Mx4, LPS3, Oil Guard, Por15, Rustoleum, used motor oil, Valspar, Waxoyl, WD40, Ziebart
    http://www.tacomaworld.com/forum/technical-chat/229505-application-fluid-film.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/173635-rustproofing-undercoating.html
    products discussed: Por15
    http://www.tacomaworld.com/forum/1st-gen-tacomas/122487-line-x-rustproofing-undercoating.html
    products discussed: paraffin and ATF and mineral spirits, Waxoyl
    http://www.tacomaworld.com/forum/technical-chat/7756-rustproofing.html
    products discussed: motor oil
    http://www.tacomaworld.com/forum/technical-chat/353066-undercoating-fluid-film.html
    products discussed: Fluid Film, Krown, motor oil, Rust Cure 3000
    http://www.tacomaworld.com/forum/south-west/272233-rust-removal-protective-coating-frame.html
    products discussed: Eastwood Rust Encapsulator, Por15, Rustoleum
    http://www.tacomaworld.com/forum/1st-gen-tacomas/352886-spraying-frame-oil.html
    products discussed: Amsoil HDMP, diesel (or paint thinner?) with used motor oil or gear oil, Fluid Film, used motor oil
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/352107-rust-help-any-opinions.html
    products discussed: Amsoil HDMP, Rust Cure 3000, Fluid Film, Line-X
    http://www.tacomaworld.com/forum/1st-gen-tacomas/352162-confused-about-frame-rust-proofing.html
    products discussed: 3M Rustfighter, motor oil
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/352292-wheel-well-liner.html
    products discussed: Fluid Film, Rustoleum
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/350357-my-attempt-stop-frame-rust.html
    products discussed: Corroseal, Eastwood Rust Encapsulator, KBS Chassis Paint, Krown, Por15, Rust Bullet
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/350493-frame-clean-up-next-weekend-pics.html
    products discussed: Fluid Film, Por 15
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/350229-how-do-you-guys-deal-chassis-rust.html
    products discussed: Amsoil HDMP, Rust Cure 3000, Derusto grill paint, Fluid Film, Rustoleum
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/349991-fluid-film.html
    products discussed: Amsoil HDMP, Rust Cure 3000, Fluid Film, mineral spirits and No2 fuel oil and naphtha, Thompson's Water Sealer
    http://www.tacomaworld.com/forum/1st-gen-tacomas/348300-started-rust-control.html
    products discussed: Rustoleum and mineral spirits (4 parts mineral spirits and 1 part Rustoleum)
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/348066-frame-rustproofing-products.html
    products discussed: Amsoil HDMP, Rust Cure 3000, CorrosionX, Eastwood Internal Frame Coating, Fluid Film
    http://www.tacomaworld.com/forum/2n...ew-tacoma-owner-2014-frame-rust-question.html
    http://www.tacomaworld.com/forum/pr...r-less-waxy-tacky-alternative-fluid-film.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/343155-inside-frame-rust-proofing.html
    products discussed: 3M Professional Grade Rubberized Undercoating, Rust Cure 3000, Eastwood Internal Frame Coating, Eastwood Rust Encapsulator, Fluid Film, KBS Chassis Paint, Por15, used motor oil and tranny fluid
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/342633-undercoating.html
    products discussed: Amsoil HDMP, Rust Cure 3000, Fluid Film, Krown, Por15, Rust Check
    http://www.tacomaworld.com/forum/1st-gen-tacomas/340033-frame-coating-question.html
    products discussed: Eastwood Internal Frame Coating, Por15
    http://www.tacomaworld.com/forum/2n...astwood-rust-converter-rust-encapsulator.html
    products discussed: Corroseal, Eastwood's HD Anti-Rust, Eastwood Internal Frame Coating, Eastwood Rust Encapsulator, Fluid Film, KBS Chassis Paint, Krown, Por15, Rustoleum, Rust Bullet, Rust Check
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/289178-07-frame-rust-pics-what-best-way-fix.html
    products discussed: Boeshield T-9, Eastwood's HD Anti-Rust, Eastwood Rust Encapsulator, Fluid Film, KBS Chassis Paint, Krown, new/used motor oil, Por15, Rust Bullet, Rust Check, Rust Cure 3000, Rustoleum, WD40, Ziebart
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/355759-new-frame-rust-prevention.html
    products discussed: Amsoil HDMP, Fluid Film, Line-X, mineral spirits and paraffin wax and motor oil, Por15
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/356279-10yr-ownership-report.html
    products discussed: chainsaw bar oil, Fluid Film
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/359016-frame-rust-root-cause-supplier.html
    http://www.tacomaworld.com/forum/2n...evention-eastwood-internal-frame-coating.html
    products discussed: Amsoil HDMP, Eastwood Internal Frame Coating, Fluid Film
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/361830-frame-recall-question-fluid-film-users.html
    products discussed: Fluid Film, Por15
    http://www.tacomaworld.com/forum/2n...oordings-2012-tacoma-build-2.html#post5859821
    http://www.tacomaworld.com/forum/1st-gen-tacomas/335712-good-true-rustbullet.html
    products discussed: Fluid Film, Krown, Por 15, Rust Bullet
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/364566-too-late-fluid-film.html
    products discussed: Fluid Film, Rust Cure 3000, Thompson's Water Sealer, WD40
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/63704-got-undercoating.html
    products discussed: at fluid, Krown, used motor oil, WD40, Ziebart
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/368199-frame-restoration-did-myself.html
    products discussed: Corban-35, Eastwood, Fluid Film, Phosphoric acid, Por15
    https://www.tacomaworld.com/threads/kbs-rust-seal-review-picture-heavy.374144/
    products discussed: KBS Rust Seal
    https://www.tacomaworld.com/threads/frame-coating-from-auto-rust-technicians.330769/
    products discussed: Auto Rust Technicians (http://www.autorust.com/), Fluid Film, Rustoleum, Ziebart
    https://www.tacomaworld.com/threads/2015-rust.386209/
    products discussed: Carwell, Corrosion X, Fluid Film, Krown, Rust Cure 3000
    https://www.tacomaworld.com/threads/rust.394803/
    products discussed: Amsoil HDMP, Chainsaw bar and chain oil, Cathode Protection, Corrosion Free, Eastwood, Fluid Film, Kraft Dinna + tuna:D, maple syrup on mac & cheese:D, POR 15, Rust Cure 3000, used motor oil
    https://www.tacomaworld.com/threads/krown-treatment.399534/
    products discussed: Corrosion Free, Krown
    https://www.tacomaworld.com/threads/i-krownd-did-you.417341/
    products discussed: Krown
    https://www.tacomaworld.com/threads/undercoat-using-motorcycle-chain-wax.585315/page-2#post-19535874
    products discussed: Amsoil, chain wax, Fluid Film, 3M Cavity wax, Mavcoat, WD-40
    https://www.tacomaworld.com/threads/rubberized-undercoating-advice-and-opinions.631236/
    products discussed: general 'rubberized' coatings
    https://www.tacomaworld.com/threads/ziebart-vs-krown-vs-fluid-film.564544/
    products discussed: Fluid Film, Crown, Ziebart, Mavcoat, ACF-50, Rust Check
    https://www.tacomaworld.com/threads/i-sure-do-like-this-wool-wax.685937/
    products discussed: Amsoil HDMP, Fluid Film, Wool Wax, Ziebart
    https://www.tacomaworld.com/threads/new-2021-tacoma-need-rust-prevention-advice.692593/
    products discussed: Cosmoline, Krown, Fluid Film, Woolwax
    Frame Protection... Alternatives to Fluid Film | Tacoma World
    products discussed: Krown, linseed oil, used motor oil, chain bat oil, Rust Cure 3000, Boshield T9, Rustoleum, paraffin oil, Krylon, S2S
    Rust proofing | Tacoma World
    products discussed: CRC Heavy Duty Corrosion Inhibitor, Crown, Fluid Film, Kosmoline, Sta-Bil Rust Stopper, Ziebart
    Undercoating/Rust Prevention | Tacoma World
