PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 9, 2020 at 8:03 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I found this mysterious puddle of goo under the snowblower last night after is sat in the same spot for maybe seven or eight hours...
    Too thick to be gas or oil; People on the snowblower forum where I’m a member seem to think it’s grease or oil from the auger drive...?
    shakerhood likes this.
  2. Dec 9, 2020 at 8:34 AM
    PennSilverTaco
    Charlie
  3. Dec 9, 2020 at 8:54 AM
    PennSilverTaco
    Charlie
    Wanted to have this picture as my avatar for this thread, but for some reason it doesn’t work...
    :annoyed:
    shakerhood and Taco critter like this.
  4. Dec 9, 2020 at 9:10 AM
    Lil Taco Guy
    Lil Taco Guy Well-Known Member
    07 Tacoma, Base, manual
    Pro Comp, AAL, Bilstein, 3.73 LSD, intermitent wipers, cruise control, Wet Okole
    Have you checked if your truck is "pre-wired" for cruise control ?
    it is very likely that it is and you won't have to mess w/ adding any wiring or the clock spring (spiral cable)
  5. Dec 9, 2020 at 9:23 AM
    PennSilverTaco
    Charlie
  6. Dec 9, 2020 at 9:34 AM
    PennSilverTaco
    Charlie
    I only had to get the "cruise control" wire and all research points to my truck having the proper clockspring; Right now it's a 50/50 "Schrödinger's cat" type of situation with regards to whether or not my truck is prewired for cruise control. I've got some people telling me that Toyota stopped putting the same wiring harness in all trucks (even base model) beginning the in the 2009 model year (I've got a 2010 manufactured in August 2009); I've other people (like you) saying it's likely that my truck is prewired. The people who say my truck isn't prewired also say that unless I tap directly into the ECU (which I do not feel comfortable doing), I would have to replace the entire wiring harness (and possibly the ECU) with one from a truck with cruise control; This could end up costing more than half of what my truck is worth!
    As of right now, my truck is Schrödinger's cat, but instead of being both alive and dead it is both prewired and not prewired at the same time...
    My truck is going in for a tire rotation at my mechanic's on Friday morning, and he has the tool necessary to remove the driver's airbag, so we are going to test if the truck is in fact prewired.
    DiscoYaker likes this.
  7. Dec 9, 2020 at 9:35 AM
    PennSilverTaco
    Charlie
    Appears to be a broken link...
    :redxfall:
  8. Dec 9, 2020 at 9:39 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think new Volvo is Chinese, l would not want one either.
  9. Dec 9, 2020 at 9:40 AM
    shakerhood
    Southern Ohio
    Sounds about right
  10. Dec 9, 2020 at 9:40 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    I am now aware
  11. Dec 9, 2020 at 9:41 AM
    PennSilverTaco
    Charlie
    You have the same problem?
  12. Dec 9, 2020 at 9:41 AM
    El Duderino
    Jeremy
    HI->PNW
    Grease
  13. Dec 9, 2020 at 9:41 AM
    PennSilverTaco
    Charlie
    It was leaking gas, but that's fixed...
  14. Dec 9, 2020 at 9:42 AM
    El Duderino
    Jeremy
    HI->PNW
    Nope I was just referencing your magnet that I am now aware.
  15. Dec 9, 2020 at 9:42 AM
    El Duderino
    Jeremy
    HI->PNW
    Good to hear. Is the gas an oil gas mix?
  16. Dec 9, 2020 at 9:44 AM
    PennSilverTaco
    Charlie
    4-stroke! Uses 5W-30 oil and mid-grade/89 octane gas!
  17. Dec 9, 2020 at 9:48 AM
    shakerhood
    Southern Ohio
    My lawnmower had developed a small oil leak which l finally traced to a drain tube being slightly loose.
  18. Dec 9, 2020 at 9:48 AM
    PennSilverTaco
    Charlie
    Do you use one of those metal C-clamp thingies?
    shakerhood[QUOTED] likes this.
  19. Dec 9, 2020 at 9:50 AM
    shakerhood
    Southern Ohio
    On the lawnmower?
  20. Dec 9, 2020 at 9:55 AM
    shakerhood
    Southern Ohio
    I was able to get a wrench up inside there to tighten that tube up.
    PennSilverTaco[OP] likes this.
