Frame questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomasaurus Rex, Sep 7, 2019.
  1. Sep 11, 2019 at 6:22 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    the problem is moisture trapped in the frame. It will make it rust too
    GQ7227 likes this.
  2. Sep 11, 2019 at 6:28 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i live in an area that sees extreme humidity from time to time
    so less chance for it all to evaporate thoroughly too i think!
  3. Sep 11, 2019 at 2:23 PM
    Tacomasaurus Rex
    Tacomasaurus Rex [OP] Well-Known Member
    Brian
    2003 Black Tacoma 4x4 TRD fully Automatic
    Gonna probably buy a used frame but am considering buying these frame (repair/strengthening) sections from I think it's... Automotix.net. I'll cut a nice hole in frame where the afore mentioned will cover. I'll clean and treat inside of cutout/frame then cover and I guess weld these over the top. Stuck my finger in hole in frame the other day and discovered some large flakes. I have one more question but I'm gonna ask it seperately in following post.
  4. Sep 11, 2019 at 2:31 PM
    Tacomasaurus Rex
    Brian
    What's the best way to administer some of the afore mentioned posts treatments for the rust problem?
    What is best and easiest treatment. Need to get on it, Winter is coming. Here in Kansas it's rained like no other year. If we don't have 10 foot of Snow this year it'll be a miracle. Ugh, here comes the brine solution.
    ac.stur11 and GQ7227 like this.
  5. Sep 11, 2019 at 6:45 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    I use one of the Fluid Film guns, with the long wand, and 360 degree nozzle, but rather than Fluid Film, I use about a quart of heavy weight differential fluid. It is about the same viscosity as fluid film, so sprays about the same. I do the inside of the frame, and also anywhere else I can get to, excluding brakes, exhaust, up inside the bed, tail light cavity, and so on. Also use the standard spray nozzle to basically paint all of the remaining surfaces with the same fluid. Gives it a more manly scent than fluid film, and I think it sticks on a whole lot better. YMMV
    GQ7227 likes this.
  6. Sep 30, 2019 at 6:07 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    wow!, it took 20 days for me to get started with the magnet tool, is working well but wow is it cumbersome, total garbage paint inside there
    i am wasting time and winter is coming soon.... it is also getting darker out earlier
    had a bunch of Wisconsin sand to hose out inside of frame too the other day, floor jacked rear and am starting on driver side
  7. Sep 30, 2019 at 6:46 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    This guy has an interesting approach for lifting a bed to change a truck fuel pump. I wonder where he picked up the red stand that he's using to support the bed?
    https://youtu.be/AXKMEtEaM-U
    I think I'm going this route to remove the bed. I can put my engine hoist to good use.
    https://youtu.be/LikSKgKtWWo
    GQ7227 likes this.
  8. Oct 1, 2019 at 5:20 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i have not made it to this point of removal yet, and most likely won't until after winter is over!
    are you finding some defective crackling crunchy paint way back up under there?
  9. Oct 7, 2019 at 8:43 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    exactly how thick is the metal part where it transistions from C to box, its at an angle sort of and somewhat difficult to get to unless you're lifted
    is the thickness of that particular piece the same thickness as the rest of the frame?
    or is it the thickness of the bed and cab mounts, which are NOT very thick at all
    does anybody have deets on this?
  10. Oct 7, 2019 at 8:46 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    was my last question located within ANY of those links? ^^^
  11. Oct 8, 2019 at 8:38 AM
    970btu
    970btu Well-Known Member
    Ty
    Las Vegas
    99 Tacoma 3.4 5spd ext limited TRD 55K and counting
    OME, SPC UCA, ARB w/warn 10K winch, TG Rock Defense Rear, Marlin Clutch, Custom hi clearance under bed spare mount. 285/75/16. A ton of repairs done and a list up to come modifications.
    I cant remember 100%
    But I recall the C part being slightly thicker than the boxed section. However it is still weak and known to buckle in exttreme wheeling, and trailer hauling.
    boxed my frame all the way to the back but there are some makers of frame reinforcement.
    https://tacomabeast.com/products/1st-gen-tacoma-frame-plates
    http://www.lowrangeoffroad.com/toyo...cement-plates-by-trail-gear-120166-1-kit.html
    box kit https://trail-gear.com/catalog/product/view/id/6457/s/120165-1-kittacoma-rear-frame-box-kit/
    others who have done it
    https://www.tacomaworld.com/threads/rear-frame-reinforcement-what-are-the-options.590837/
    safe-t-cap has some really nice pieces for the back https://www.autorust.com/product-category/toyota/
    GQ7227[QUOTED] likes this.
  12. Oct 8, 2019 at 8:44 AM
    970btu
    Ty
    Las Vegas
  13. Oct 8, 2019 at 5:40 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
  14. Oct 8, 2019 at 6:18 PM
    970btu
    Ty
    Las Vegas
    I would measure mine with my gauge tool but I already boxed it. sorry
  15. Oct 17, 2021 at 8:46 PM
    #35
    ac.stur11
    ac.stur11 New Member
    Andy
    98 Tacoma 4x4 2.7L
    The easiest/quickest is just to remove the rust and weld steel in place of it and re treat that section of the frame. Although, if you want a long term solution you could do what I did and go on Facebook Marketplace and find a frame that was a replacement for the recall. I would highly suggest stripping it to the bare metal to re coat it yourself. HEAR ME OUT ON THIS remove the bed, support the engine, transmission, and cab. from there you will be able to remove the suspension system and lower the frame down. from there you should be able to slide a new to you frame under the cab and reinstall everything. with some luck this process cost me under $2,000. A word of advice is if you don't know how to install or remove something go on youtube and search tacoma 1st gen (something) replacement. this saved me hours on just some hidden bolts, with some tips by trained professionals. if you have any more questions feel free to reach out. we're all stuck in the rust together.
  16. Oct 18, 2021 at 3:08 AM
    #36
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the Forum!
    Good info But the thread is 3 years old
