Benson X's 'Bout Time BBQ Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Benson X, Sep 26, 2012.
  1. Sep 26, 2012 at 11:18 AM
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I call it the BBQ build, because it has been S-L-O-W paced and LOW budget.
    As it sits today (7/9/22):
    AM-JKLXAbXkhYuVf77gxG0nmsSJnVwHAXkFTXQxp_756f8cc633c704d7edb977883fe4542fc80b9b7f.jpg
    In the beginning (10/19/10):
    SUSPENSION:
    FRONT
    Current:
    • OME BP-51 set to 20mm
    • 1/4" spacer (both sides)
    • Light-Racing UCAs with xAxis Bushings
    • Total Chaos Alignment Cam Tab Gussets
    • Swaybar Removed
    Previous:
    • OME 90k Nitro shocks w/ 886 Coils
    REAR
    Current:
    • OME BP-51
    • OME Dakar Leaf Pack with D29XL AAL
    • Wheeler's U-Bolt Flip Kit
    • Famous Fab Shackle Flip
    • Daystar XJ Greasable shackles
    Previous:
    • OME Nitro Sport Shocks
    • 1" Block lift
    WHEELS & TIRES:
    Current:
    • Mickey Thompson Baja Boss A/T (285/75R16)
    • 16" SCS Stealth 6, MGM
    Previous:
    • Cooper STT Pro, 285/75R16
    • Mickey Thompson Baja MTZ P3 (285/75R16) on 16" Cragar Soft 8 "Steelies" (with a 3/8" hubcentric spacer).
      Read more HERE
    • Toyo Open Country (285/75R16) on 16" Cragar Soft 8 "Steelies" (with a 3/8" hubcentric spacer).
      Read more HERE
    • Goodyear Wrangler MT/R originals (285/70R17) on Plasti-Dipped 17" OEM Sport wheels with (4) 1" BORA spacers.
      BORA Write-up and Review HERE
    INTAKE & EXHAUST:
    • HiLux Snorkel with a EngineAire composite pre-cleaner
      Snorkel install/write-up HERE
    • aFe Magnum FLOW Pro Dry S reusable Air Filter
    • aFe 3" Cat-Back exhaust
      Review HERE
    • Doug Thorley "Pipe Bomb" Y-Pipe
    ARMOR:
    • Home-Built Sliders
      Write-up HERE
    • Home-Built IFS Skid & Mid-Skid *retired 7/1/22*
    • Home-Built "Trailer-Trash" H/C Rear Bumper
      Write-up HERE
    • Reinforced ARB UVP Skid Plate Trilogy
      Write-up HERE
    • ARB Front Bumper, 3423030 (modified)
      • Removed Turn Signal lights, replaced with Rigid SR-Q2 flush-mount LEDs (Driving pattern)
      • Added (2) 1" thick recovery points
      • Added (2) square cutouts for addtl. Rigid D2s (Amber LED - Driving pattern)
      • Added 3/16 plate rock guard
      • Trimmed about 3.5" inches off each "Wing" for better clearance in the wheelwell
    • All-Pro Steel Gas Tank Skid
    LIGHTING:
    • Rigid SR-Q2, Specter Driving pattern, flush-mounted in the ARB bumper
      Write-up HERE
    • Rigid D-Series, Amber LED, Specter Driving pattern, mounted in the ARB bumper
    • Rigid SR-Series PRO 10", Specter Driving/Spot combo, mounted in the hood scoop using a C4Fab mount
    • Rigid D-Series PRO, Midnight Ed., Diffused Flood pattern, mounted under the Front Thule bar on the canopy
    • Rigid D-Series PRO, Flood, mounted under the Rear Thule bar on the canopy
    • Rigid SR-M PRO, Diffused Backup Kit, mounted in the OEM rear bumper
    • 10" SeeLite SR LED Light-Bar, mounted in the front grille
    • Philips X-treme Ultinon Gen2 LED Bulbs
    • AlphaRex PRO w/ Hikari LED bulbs
    • (4) LED Amber Emergency Flashers, mounted in the front grille, using a SHO-ME flasher module
    • OPT-7 Redline Triple LED Tailgate light bar
    ELECTRICAL:
    • Odyssey Extreme 31R-PC2150 Battery
    • Custom Steel battery Cage
    • Bussmann Waterproof RTMR Mini Fuse Panel (Part# 15305-6-2-4)
    • Bussmann CB285, 100-Amp Surface-Mount Circuit Breaker
    • 8-Button interior switch panel
    • Custom Fuse-block engine bay mount
    • Wired all circuits with Deutsch connectors
    AUDIO: *Complete JBL replacement*
    • Pioneer AVH-P6800DVD
    • Pioneer AVG-VDP1
    • Maestro RR
    • PAC SWI-X
    • Lightning Audio L-5600 Amplifier
    • Pioneer TS-SW2502S4 10" Sub
    • Polk DB6502 Components (Front)
    • Polk DB6502 (Rear)
    • @Mr Marv Custom Enclosure, behind the rear pass. fold-down
    • All new wiring all-around, RCAs, and 100-amp Breaker mounted on the battery cage
    EXTERIOR:
    • OEM Roof Rack
    • Debadged
    • Black Emblem on the Grille
    • Black TRD Grille Badge
      Mounting pics HERE
    • LEER 100XL Shell w/ Thule Tracker II rails
    • Tinted windows
    • Plasti-Dipped Hood & Scoop
    • WeatherTech In-Channel Window Deflectors
    • Custom-Designed TRD Skull Decal
    • DEPO Black Housing LED Tail Lights
    • DEPO Black Housing Headlights
    • Upgraded Splash Guards from @cnote4l (Gear Tech Customs)
    • Custom pin-striping, scratches, dents, and Dora mask
    INTERIOR:
    WINCH & RECOVERY GEAR:
    • Home-Built Hidden Winch Mount *Removed 9/28/13*
      Write-up HERE
    • Warn VR8000s Winch
    • Warn Spydura Synthetic Line
    • Warn Wireless Remote
    • Black Roller Fairlead w/ Daystar Delrin Rollers
    • DIY Removable Front License-Plate Mount
    • Tuff-Stuff Black Clevis hook
    • 60" All-Cast Hi-Lift (HL-605)
    • 32" 3.5 lb. True Temper axe
    • 14" True Temper hatchet
    • Bully 44" D-handle shovel
    • VIAIR 88P Compressor
    • FirstAlert PRO5 Fire Extinguisher
    • (3) addtl. Recovery points welded up front
    • DIY Hi-Lift & Tool Mounts
      Write-up HERE
    • DIY Jerry Can Mount + QuikFists
    • TRED 1100 Recovery boards
    • (3) 5-gal. NATO Jerry Cans
    • (4) RUD Grip 4x4 Snow Chains (Model 2532)
    • Recovery Bag: (4) D-Shackles, (2) Snatch Blocks, Frame Cluster hook, Shackle Receiver Hitch, 30' Recovery Strap, 8' tree-saver, 20' tow strap, tow hitch w/ 3-balls, ER tape
    • Recovery Tote: Emergency blanket, food/water, hand tools, tie-downs, jumper cables, flares, 2-person tent, (2) handsaws, machete, paper, fire-starter, (5) tarps, bungee cords, rope, 2x pair leather gloves, Off-Road spill kit, Rain gear, Trail Spares: CV, TREs/Inners, U-Joints, LR Ball Joints, Wheelhub, Fluids, Mac Tool Hitch Vise.
    • Bug-Out Bag: Emergency Blanket, Spare clothes, first-aid kit (addtl. F/A Kit in the cab), N. American Rescue TTS (tactical traction splint), (3) LED flashlights + spare batteries, food, water tablets, LifeStraw, headlamp, (2) Firestarters, Fishing gear, Silva Ranger Hi-Vis Compass, Pens/Sharpies/Hi-Liters, Trail tape, paper, duct tape, (2) multi-tools, (2) knives, Zip-Loc bags, toiletries, paracord, survival/safety literature.
    MISC. MODS / PARTS:
    • OEM Heated Side Mirrors Mod
      Write-up HERE
    • Hidden CB Install *Upgraded to Anytone Ultra Compact CB*
      Write-up HERE
    • On-Demand Rear-view camera
      I used
      this write-up, pics HERE
    • Anytime ON Foglights
      I used this write-up
    • Always-On 12v Plug
      I used write-up
    • Disabled Seatbelt chime
    • Silent Fob (Arm/Disarm)
      This write-up works
    • Illuminated 4WD Switch
    • Horn Relocate
      Write-up HERE
    • Engine Bay / Winch area LEDs
      write-up HERE
    • Rear Diff. Breather relocate
    • ABS Kill Switch
      Write-up HERE
    • Yellow-Wire Mod (enables TRAC in 4LO)
      Write-up HERE
    • OBA Install (Viair 10007 Kit)
      Write-up HERE
    • Redline Hood Struts
    • Black SS Extended Brake Lines (from OCTaco)
    • Relocated 7-PIN Plug
    • IEDLS Polyurethane Carrier Bearing
    • Energy Suspension Polyurethane Bushings (Cab, Steering Rack and Radiator)
    • HookeRoad HDPE Tailgate flatpanel
    • Tailgate Reinforcement from @Mobtown Offroad (and @ndcmack :thumbsup:)
    • Cab Mount Chop with BAMF CMC Plates (from @ndcmack :thumbsup:)
    • Bed Stiffener Brackets from @At The Helm
    • ICOM F-121s VHF Radio and @RelentlessFab NMO Hood Mount
    COMING SOON / IN PROGRESS:
    FUTURE MODS / IDEAS:
    • Re-Gear w/ ARB Lockers Front & Back - added 10/2023
    • 35s (???)
    • T-Case and Rear Diff skids
    • High-Clearance rear bumper - added 8/21/20
    • Shackle Flip - added 5/9/22
    :thumbsup: Thanks for looking!!! :thumbsup:
    SEE BELOW FOR PICTURES
  2. Sep 26, 2012 at 11:29 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    PICTURES
    mvIePPScYLJlDjiKk3tl4Tybh9QWYlubU4yiMrRC_11bdf2cef3d68bdec919c0113c2b5a3d2a24d1b7.jpg
    lpHI5QKf2ql_uIzwGz5iQdBvyHgBxhcYjIasZvX-_ce81f8d36ec4cbbcf48c760acab87c9cfb6e477a.jpg
    PKj3GLUBQndEZXf9mUIwPyOth9ak-0yixFG_ZhTh_a32c484bd23de0890b5c3717f4a2ae7f227bdb5c.jpg
    B3B0-HPkzF61jY7jYp26GrDYo92RZWU2mHJRpEBx_d86d1165def61e797515310adb3e66bb16d1f9da.jpg
    qUN_q2K8eUquCeSSAtUjmocS5zksOnTMKM0K9Cg3_9f0ce807be32d158f17cee23a76cb9c925826f8d.jpg
    71elsJ-SikM7C8Ns-Ij5YBOzxo_bys8JQcpb2OIF_bb5174a659d3ceb956872200930a36f3e997c6bb.jpg
    DYosOhgSNaG8AIqwbMYUcUH6p4mlOIC4EvQQCKgi_716b6439205c5982ac5acd40ed6b947fb4bf2634.jpg
    R6hEEgEIUDFlTYh_djjpSElsPw7sBAb9H__Gtb1n_cb0cdbee7868cf0a003a3d0e0a6794f26f341fff.jpg
    j7nBJpi4IbfFNtgWT-AL7I4DOqI_aeTOdWKbKlck_49c048f2ed802dc1687457c1ea0bef567b8187c9.jpg
    BQfF2KB67N3KjF6U4tPYiWfwiIx0_TRdtES43yWi_b2395c55d114385c1f36cc9237df943a0143fade.jpg
    zf14cGat3Cf4FyZ7F47xZ1m66q0vz1l-EidRypdR_e9c0e54072021c952b93fbeb68ccc154700701ed.jpg
    ARMOR:
    Home-Built Sliders
    ARB UVP Skid Set (heavily reinforced)
    AM-JKLXlijtvzmFpujvM3_dpBl66WIhzToptlRyI_3939a2f6e6e0636ef4df06c244e4347102e26fe4.jpg
    AM-JKLUcYk7fgCHSXHpeXbNI82JfAJ6sCv6QN4AZ_bc10f9f73c6d0b225007b7ce7f41f4ba04b243c5.jpg AM-JKLUvgM3_1v1394X636G1SzCAfsxTJ_y4MYDJ_78160442d14380795df23b1894e9bdfe78b8e7ac.jpg
    ARB Bumper, 3423030 (heavily modified)
    RwkQRjkoCunJH-jHlULwG2fqyG86IBQq05WmRrhG_f7234cf4922e3c0e35795b4724f8b8e968f9ee83.jpg
    3dGdkeqAHAB53D43A-7rXJqllsPIGzIiRAFAMTgu_031c163faf0afb79999581d6d898700eaa6448d4.jpg
    OU8YrVPeDADthQYh9N6oJvH6Vkea2SDmwWEcsSwo_2d1f36a4be45bd543da72499bbc3129b6007221b.jpg
    NL5zxNozRrH8AKY7C0SXLA27oBeYBhn66CamnC3B_20d4f598595e93bcbe06ed14cb7faf1098182761.jpg
    0Pu-TonC8DWzt2tyDzVTr9n1rBfEqSAwuT4tgP7U_1ca6b673221b23415094200c6992955edca5d788.jpg
    wazg7ZlQzEQtyHhenZg_BfC1zrZR3c9NGq37Oqgj_51a5134cc1e115e3e1980bf664076f0ce59dde14.jpg
    dxTO8IWq4FALdv1_ZCXKIoGZopIji4WW-eyRjHYG_85803a0f2d37d681553cb46200e3686aac1278b9.jpg
    anpzm7721ydVAugWfC9GBJkjYVm3FLKqybtTDCjm_7f3cac5a633e5c0ee09955f1ebd5eaa660b27fde.jpg
    jJFG5C5-6MpMsuPBlpiuwndFGEvykV7bZLiVZB-j_a05dbbd1bb3562b032d620b4b875d94d5a7cdd5d.jpg
    qy1qlRZ_meygCyYYUseOEc_gWizczVY3K6YSt58A_c4172dd71e5d84ab5c5fa93b116aa168d50a9e84.jpg
    Home-Built "Trailer Trash" High Clearance Rear Bumper
    Over the course of a few months, I got drunk and fab'd a high-clearance rear bumper using:
    • The "skeleton" of a rusted-to-shit All-Pro Tube bumper
    • Scrap metal from a demo'd mobile home,
    • A busted swingout tire-carrier from a buddy's DIY bumper
    • OEM tow hitch
    • Copious amounts of beer.
    :cookiemonster::cheers::sawzall::welder::itllbuffout:
    ACtC-3fav9tbL44WjLIyZsUQWeTAAnbT1aXxa5OR_ccf21cfbf4ae94032c5cbab9222ca27597678421.jpg
    ACtC-3fcBkem5SLFPa2xzgYKxOGXVp9h5_B9q_p__3f63971bf40aa0ac69b3ec13ddbf3f76b5f57954.jpg
    ACtC-3f6ZoZfafvSZPhOgFXLi3CI3AiJLkUp330M_bcf5741993f255adf1ae7c4097e9e94b65f6dba4.jpg
    ACtC-3f36v--NuAXSjiuDJnRunLZv3rDP4S3yoFV_472667c609d8833052840cbb1666487684813cdb.jpg
    ACtC-3ehI6n0bcVoLpAT7oJ9ThjV_rExadfRqEHi_33f161ad007625140682aef5d1e6eaf3ef86bc24.jpg
    ACtC-3cmgbuJ4COKV2u6IvpQYnNPiQwf4Corky_4_5f51f1683fda5488ff00eff39edcfd271fc1b03f.jpg
    ACtC-3d7PWFdBf4s7QxaRDj0kdlDoTfxZIecR-0y_2ecf5ff8630bb4ce8a0602248ebf4a1144416d6a.jpg
    ACtC-3c92RfNbd9Bm__LQt5_cMZTyjFuXqcPT7ek_a00cbd1b955e4952cf3a118846fc2b35a93559a7.jpg
    ACtC-3c-AboH_zaKGbjHKdqgxFTd1a6bCeMSGnE9_eeaa431054a5b143c74e81484560f026fc9d675d.jpg
    ACtC-3f7WYp05r79Aqc_zpI344e1RiEzZOMw0_ds_95fa7f71efeab76e912fbd3e5134c7727fc28814.jpg
    ACtC-3cOdZEJ0WSFqbuhUOZ9YoH88ndgz7qB1stM_2d8d0a1c969408a7acbd9dc72424f14f16e2f090.jpg
    LIGHTING:
    x71TagBE88K-CODTHWT9O_QK6a9iIhnitAyWgTHK_bdd792b6b6f996bbe7b54ef5cc8bad48d7d19465.jpg
    QKb3D-AZ2gZBjAXz9CL4CcfQTZs71uVb-SW4aO4e_53515db67d7fb49aa10ec0598586cf94baf91440.jpg
    LZn7aMnxJLk43S9FshbFDdXSH1VO6YSNriFliUe-_61687392c53a9eb4d9e444c15f4057707d0246a3.jpg
    AfcnXmh4DlU-rmI8O7aRMBSSrN8zdGpqLOgwNs7V_98284f69869ad822e087a7a0990f179987cc2414.jpg
    oUCgVafigrYhvkqMymSBXaak5NeqHD3Dt0_ZQiey_9d5cef4689dffc5c18b7718fb21416d61f191756.jpg
    qO3EhjC0lo4d9tTMiormUEURSqG2BoUqcDkcc8z0_bb4013ac28428e1b64885107f7191d5ac23b8d7c.jpg
    ELECTRICAL:
    ndYrh_VNxNjHq6GJRlEPrZtzrkfD8KVJW61M0ItI_abaf7620712fb4a4dd0adecf6921be4255398405.jpg
    0XpKWXnEAJilq7pOHwkT6HS1oVRz9r2UkzaEJx11_a7699e7c80dcd40220d51190aebfc0993ea3344b.jpg
    4b293qH48Uk4CcCvPfBZQ5_w4fvSz-HUIQx3Q0bH_967299936ab59ba3029026dd9103924f45837f21.jpg
    1sUeGe_W6aXxd27uiClw_zFp4tufxRmQIhdaju7H_0ca054359f357a2a8df3ef7da95ca05473f12f5b.jpg
    bRYperKDRtoN1kV61snDdlItbULZ8_lotBKWnLOB_61adaa761e834d2ebbb7a2069675c4b97ecae316.jpg
    UX9c0qnVHTWh2CmhfxNP9Mn6o9Cllh1pWRCXBGe8_6329180bc808d35ca4ca488df3cf49c496412c1c.jpg
    31Y2D6zdKGscJqlWYfe4pN253X-UVv4U6ilttWG-_630f4712574c8066b3e1ace09a7b2fab60cf9c6d.jpg
    Xh_vL7aWn2lHvB8dMk2SbisnTCuJ7riEqTq8zlAb_bbd00e6d39a45961fb45cf30a62d475461540afe.jpg
    Q52swMakJ4Dv0g2IXHvM752BzKB7zT_x7kmoZdo6_1c665739a056b9828cf34eb82c729e27c6698ae9.jpg
    MISC. MODS / PARTS:
    DIY (3) Jerry Can Mount + Fire Extinguisher & Addtl. QuickFist
    KYkYpmtkhzYALcJxQzxDsrlGjtwn3F6FS9k7ZeUh_16354a62022b3ebae1e958ea5b92bb542ea3188e.jpg
    qyQhOI_m0tVnh6HAX9cAsLEOHyG5WkB9i89miffo_22db4ed03c4b66a88233339465ce736797854173.jpg
    jnhWqdiwLvLcWXUe1AG9KmvOnk3trx02FJzW6UNv_6612d7b00c5586413eecc619e3b3d79b5bc803d5.jpg
    2dgxkBYOZBWm2wie6i2h7Z4cy7i41l9b8g0UBO8q_0319778229e1c7270a666133e1ab7ccfefcf6ef8.jpg
    Hidden CB
    tmyCcRmmLkP8dQAA4mnJd04u58LecANGkzscnSPH_9c6eb03dfcc4df5ebe6201916cd85907b7be2269.jpg
    ABS Kill Switch
    Tailgate Reinforcement (from @Mobtown Offroad)
    a7-SSiGxiwVmTdwLHeYk1dlH8MYEUqSB0SPRZNac_259a823bb14165c3546969f609c673708dee1f76.jpg
    Solid Stainless Steel Skull - Threaded for Shift Knob, powder-coated black *Removed 8/8/22*
    _pFNlTHtfaGDDu3fO6Swupl91H5MoJJtsKa9AKia_8c4e8b146321a3e8bd375773bd60ce5ee93285f0.jpg
    _OlJ5TGmGIoazC1FtNIbH8SYeonfVyt1hShDZiJL_28fb08cfd8b96baab1977f77277c075aa42ca634.jpg
    sjPnBsrdwDzBNBj3wS2M401vo5c8HNq78Y46kOFy_5e8377308a9dc71cad48d6c9913f552759f75658.jpg
    GITD Skull - Threaded for Shift Knob
    AL9nZEVo5LsJWfl6edGxLPOnNID0CG75jCaQ8XuH_4badfa32e51ab460a66157ee2531a36a96a075dc.jpg
    AL9nZEWhzwFsbqb0hfeTkviSOPvXUQl8psbVZJGg_6fe370247f0e0a7b4bdfe29154c1e9249cf11f18.jpg AL9nZEWv5H8PBOEdZDtUZrjyMn0DXyWVjMTsHsXz_53184ca730478e51699354009f91f62765602435.jpg AL9nZEW1HoWnvHASxTEvPtR9hQhVgpvSofbsRxgH_940497be3a86e82c7d49e6febca20c7cc47cf277.jpg AL9nZEVZBP3bAj46YfnBdToae2O6MZJmRTaSeDEF_2756014e5b37c67c0efc1557cef6794733c4777d.jpg
    AL9nZEUABIDNIApvVxLP4bSSplUp5ZktXCT67gY3_c43e732cc4ac6be281e5477a3139ff97dac7cd22.jpg
    WheelSkins Euro Steering Wheel cover (Black and Dark Grey with Grey stitching)
    Y-KoXI-GEeV1sGJS0X_2W6jXHVNAAqUxtc1r13Pk_0808cb7f1ff376ccc941014363b70f275825071a.jpg
    6WlvH1XfilIWXgzXxkmFmtNw9oUi4p2JlYbeQ1JY_3a02fccbce6199ff060b8871bfa990641f275a02.jpg
    QydT3axL1IfGEaJbKrFDu6mbBi-3aE3tFd-Mt1WL_c469beb939798c33f7abb016068466766ba1c72b.jpg
    Bed Stiffener Brackets (from @At The Helm)
    srT4LMLB-jicPO8UXU2mWeXyzpIhRn3wCNtBuWcx_bc61111c3d887ef67fcadad9a7dd9cca2db2483b.jpg
    Garmin 60CSx w/ RAM Mount
    @flyzeye designs V2W (Amber/White/Amber):
    KQUhbWiFtFHwakHfUQuGL9CsoS1TPCfYzgt1Zx7o_e919f95c26075f0967edbbc239d1cbeffeda5fdb.jpg
    SPYqTeAMSyGh64XwjLHz7GOwoaCyjNIgMIF0fKx0_8fed1d039661738cf1117045a2dacb31201261f4.jpg
    Upgraded Splash Guard Fender Liners from @cnote4l (Gear Tech Customs):
    KshMwYSVG-ovIzA79m8cGNuTAgmhPmBVuZN9bsKq_e576252728ca78572b631e2301e5200882466e49.jpg iRiul9-VI00HbsMKTC7Y_riBQVOHq5eW1hWS74qA_45e2148490abbcbacfcac301bcbf4da5eef5bfd2.jpg
    Misc. Patches and Trail Toys Merit Badges (from @SMKYTXN and @Bennett707)
    36p0dUFnCtaweB13dSYaqfuZPOWZV5BPKk_daLQ8_199bcb16ebd73ae9858ce38da99e3f1b8e070402.jpg
    Gv2zUlCDw_YsBzSkzan30nV9y4_x74Jh4qgFaISP_079a55f525d546f5cc7569c9facb666edcf0f9eb.jpg
    CUSTOM SHOP/TRUCK TOOLS:
    DIY Coilover Hitch Mount:
    This allows me to bolt the coilover to the top-plate and secure it in the receiver hitch while I adjust the preload. Way safer than previous methods I've used, hahaha!
    :cheers:
    9XUWU6WaKizLIUlryec6uTgtq_bzASqc99glaqnn_d319847efd772b9cb0a59b1ceaf1afe6247ee009.jpg
    KrJ7_doMBpmtZf86AsILYONS_E3XThj3vu7eJZ3P_9e3b4fcb70990dd13e988b5e219773cfe6cab2ae.jpg
    DIY Portaband Table: Converts my portaband into a vertical band-saw with a 5" throat. Scrap metal saves the day - and saves me about $150.
    ZCZF9XUaCBLFfxGIMIWmkCjtWjiOhpP0Y9saMvaA_995cae14e0258cf4071d4998f7783e574abd4f9d.jpg
    MlEVKKXmxQw0umGTgCqAwnHyjY9MjFncJj7szkZF_f508b3fb56ea47554773321668538d7753d2e8bf.jpg
    OOPS: (some of these are not my pics: @stikle, @Chickenmunga, @mutilatedjak)
    yfW0-Nhud2uXih1NWTADER1v__HG5q1oJfYWYzBT_74829f7155d855657490e4f3f3c515dc6a44bd85.jpg
    22GcEaBBAvqOcxZTQsHzWdJoIgmafmJgktcFe6Yl_30fe7d9388b32d2ca18765fc6f65e00784d3c0bc.jpg
    _JFf6T-k1WkpQTt15vMoq0ifAyqKEVIgqgJFZRQN_9acc6c96db38bb0704787c17a9e5175a4a474b8f.jpg
    wC3T033AQ1y3dcxk4SPLyZkpPUliruYVubl3RWBD_1be92937c229c529c6d2935adaa31cc947242bcf.jpg
    ZOvMX2K_g07a_6l5az8-HFULh3BCGJQD4NACHCfr_1cf023cb2259a2cbb87311fcbb0c63b6cf3d51f4.jpg
    u2EwgNA_ua-POO7QEvVBKSHYPA5-8JucPcdP3G92_91d2414a12d8395e43ea082073273fdccb6c6bc1.jpg
    MXLhBAITIjmO8gnUDTvyEr8nLjO7zRrV1qTkZlJm_94f0a035d0f8364b6fe4327e1fafb020bc605649.jpg
    OFUeZ00f05XbpmuIZH2uM-OclcBimuZTJCvPNnOu_2cb0229bd6cd70e40877640f80c465326da3d1ac.jpg
    Rj9w_9DNr5q3PCd7wr9xPBOFHqllRfib_HTX42uC_7c12a626920373389592143e8f3fa3489865fb38.jpg
    Xp34DXSIn-LxOFBkDVMYyyY3wH8C18TigCkRuAPa_55040fe996f44681a20aa44db8ca4fed0fdcf9e9.jpg
    Please PM me with any questions or feel free to leave comments here
    :thumbsup:Thanks for looking!!! :thumbsup:
  3. Sep 26, 2012 at 11:31 AM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    'Bout time you got a build thread
  4. Sep 26, 2012 at 11:33 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    :rolleyes: hence the clever title :D
    Thanks Mitch!
  5. Sep 26, 2012 at 1:28 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
  6. Sep 27, 2012 at 8:12 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Lovin it!
    Looks like you've done a lot of the stuff that I would like to do.
    Needless to say, great job!
  7. Sep 27, 2012 at 8:27 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks Cowboy! :thumbsup:
    I have tried to do write-ups for most of the mods, but let me know if you have any ???'s or need help with anything.
  8. Sep 27, 2012 at 11:40 PM
    toyotaT32
    toyotaT32 Well-Known Member
    Thomas
    Palmer, Alaska
    3 inch revtek in coil spacer, all pro bumper, smittybuilt 8000 winch, 265/75/17 BFG AT, cookie monster stuffed animal in bumper... UPDATE 10/17/12.... OME886 Coil lift with spacer. UPDATE 9/6/13..... Plasti dipped 17inch eagle alloy wheels. 285/70/17 Goodyear Duratracs, 6 bulb rigid industries LED D2 lights
    Nice truck man! That's a good lookin color! Well built!
  9. Sep 28, 2012 at 2:10 AM
    DitchDoc
    DitchDoc Well-Known Member
    Logan
    Western North Carolina
    03 V6 QC TRD Limited 4x4
    2003 DC 4x4 TRD Cap K&N FIPK
    Awesome Sauce!!! :jellydance:
  10. Sep 28, 2012 at 12:39 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks Thomas! I'm quite fond of it myself :p
    The paint used to be flawless and sparkly and shiny...now it looks like a hoochie hoodrat ex-g/f took her fake nails and went to town on it.
    The MGM paint looks good, but it show scratches, swirls, and pinstripes worse than black paint.
    almost as awesome as Roy Shildt himself:
    (Watch: The King of Kong: A Fistful of Quarters & Chasing Ghosts, both very sad movies)
  11. Sep 28, 2012 at 12:43 PM
    toyotaT32
    Thomas
    Palmer, Alaska
  12. Sep 30, 2012 at 8:02 PM
    gdry06
    gdry06 Well-Known Member
    Gary B
    PNW
    06 TRD SPORT
    3Link'd with trailgear rock assault housing, 295x75x18 Nitto m/t shackle flip kit w/ omd spring refurbs, roof rack, toyota toolbox
    finally a build thread Ben, tell Ninja Steve, keep up with the sick as pics. So when we going wheeling again?
  13. Sep 30, 2012 at 8:21 PM
    Large
    Large Red
    Nice clean layout of the mods, I'd +1 but on my phone, it'll have to wait til I turn on my pc.
  14. Oct 2, 2012 at 8:07 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks Gary! Still got some work to do, but it's slowly getting there. Ninja Steve is still jumping out of trees, and taking badass pictures. He's having to teach me the ways, since I just got a new D-SLR too.
    Let's get a meet put together soon! Maybe somewhere local up here? Mike and I were talking about scouting Evan's Creek, or maybe somewhere accessible even in the snow (since it's getting to be that time soon)
    Thanks Cody! :thumbsup:
    Let me know if you have any questions on the mods.
  15. Nov 5, 2012 at 8:08 PM
    wmflyfisher
    wmflyfisher Well-Known Member
    Wes
    PCB, FL
    2010 Sport 4x4
    Just stumbled across this build. Honestly one of (if not the) cleanest, most well thought out rigs that I've seen on TW. Just my opinion, don't add a plate bumper! You're rig is PERFECT the way it's set up. Especially the hidden winch mount. Nice ride!
  16. Nov 5, 2012 at 10:19 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Hell yeah, thanks Wes! There's still a few things I wanna do to it: lockers, regear, skids, rear bumper, tool mounts, addtl. roof rack, maybe wheels. But, as you might have figured out, TW is a blood-sucking, gold-digging tramp that takes all your money. :p
    I basically want to make it a capable overland/expedition rig that is pretty versatile and still aesthetically pleasing.
    Slowly getting there. :cheers:
  17. Nov 6, 2012 at 7:33 AM
    wmflyfisher
    Wes
    PCB, FL
    2010 Sport 4x4
    No doubt TW is blood sucking! This is the 05 that I sold last year for a full size truck (very stupid mistake).
    http://www.tacomaworld.com/forum/2n...easonable-price-my-05-4x4-6spd-90k-miles.html
    I'm currently in the market for another Tacoma and plan do set it up very similar to yours :)
  18. Nov 6, 2012 at 7:58 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Dude, that was a sweet ride! You have good taste ;)
    If you get another Taco build started, check out my write-ups and let me know if you have questions. :thumbsup:
  19. Nov 24, 2012 at 1:30 AM
    dustin81
    dustin81 DUSTOFF
    Rio Rancho, NM
    09 TaCo Lifted TRD
    PRO COMP 6" Lift Stage II PRO COMP 2.75" Coilovers PRO COMP MX-6 shocks PRO COMP skid plate Bushwacker Fender Flares Smittybuilt Chrome Steps KC Chrome 6" SLIMLITES Billet Custom Grill JDM window vent visors Window Tint Flowmaster TRD CAI
    nice rig. I like your winch set-up
  20. Nov 26, 2012 at 9:08 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks Dustin! It's still a work in progress, but I like the way it's coming along so far.
    I finally got to test my winch out this weekend to pull myself out of a bad situation. Worked flawlessly, and the under-hood LEDs helped me to see what I was doing. :D
