2nd Gen Tips, Mods & More
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcBob, Mar 26, 2008.
  1. Jan 5, 2012 at 7:58 PM
    #101
    Darth Tater
    Darth Tater If I can't get you out, neither can anyone else.
    Marlin
    Las Vegas, Nevada!!
    06 4X4 Taco, ARB, DBL Cab
    ARB,WARN 8K (F&R), 3" lift, Snugtop, tube steps, factory roof rack, Dick Cepeks,
    I am planning on going to the Moab meet in May, but don't want to drag along a camper, with associated stuff.
    This is a raised platform to go in the bed of your truck. It is 59" long, and 56" wide. The vertical supports are 9" tall. It is made from 3/4" ply, and cost less than $100 including hardware. The top is made in 4 pieces, the middle right one being hinged for access to the 48" long compartment underneath. The outer two sit on top of the fender wells, with minor shim work. The carpet is made from outdoor carpet I cut with a razor knife, and stapled down. The lights came from Sam's club, run on 6AA batteries, and have a common switch you can see on the right side of the bed, next to the tailgate. A BCLB would be a little longer, but could be thrown together in a couple of hours with a nail gun and a table saw. The whole thing is held down with carabiners to the bed loops I installed on the factory bed bolts, instructions are located elsewhere in this thread.
    PM with questions.
  2. Jan 5, 2012 at 8:03 PM
    #102
    Darth Tater
    Marlin
    Las Vegas, Nevada!!
    I have a 2006 TRD Sport 4X4, and the recommended tire for a TRD Sport/Off Roads is a 265 series tire, it is 32 inches tall. Without a lift, you have to be more careful about width, not height. If you have a leveling kit, 33X12.50 are possible, but you would have to remove the mud flaps and trim the fender flares, or the tires will rub when you turn the wheel or do any kind of articulation.
  3. Jan 6, 2012 at 4:13 AM
    #103
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    depends...are you talking 5 lug 4cyl or 6 lug 4 cyl?
  4. Jan 6, 2012 at 4:20 AM
    #104
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
  5. Feb 19, 2012 at 4:50 AM
    #105
    desertrock
    desertrock Well-Known Member
    Keoni
    El Paso, TX / Fountain, CO
    Tacoma TRD Off Road
    ToyTec Adjustable Coils W/Bilstein 5100's, Lower front Dif Kit, Rigid Industries Dually s, Throttle body spacer, ARB Front Bumper (some mods), ALL Pro Rear Bumper, Rear Expedition Leaf Springs, Rock Sliders, upgraded Tie Rods, Budbuilt fuel tank skid plates, KN Cold Air intake, Warn HID Lights-4", Banks CatBack Exhaust, Total Chaos UCA, AllPro Transfer Case Skidplate, 886 Rear backlight mod, rock lights, TRD Hawaii Off Road decal (sockmonkey), Garage built Tire Carrier.
    NE1 knows the part number for a U-Joint(s) on a 2006 Tacoma TRD Access Cab?
  6. Feb 19, 2012 at 5:59 PM
    #106
    no mods
    no mods Well-Known Member
    cincinnati
    Some stickers
    I think they are a standard 1330. Spicier
  7. Feb 19, 2012 at 6:02 PM
    #107
    no mods
    cincinnati
    Some stickers
    U just have to figure out what crap uses a 1330 at ur local parts store. Should be like 13 bucks
  8. Feb 21, 2012 at 11:00 PM
    #108
    nelly.hartley
    nelly.hartley Member
    Lewis, Colorado
    1963 VW Crew Cab
    Hey thanks, this has been a helpful thread.
  9. Feb 23, 2012 at 9:59 PM
    #109
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    I'm having that same problem, I washed my truck yesterday and had the alarm go off three times. Did you eventually find a solution?
  10. Feb 25, 2012 at 6:47 PM
    #110
    DOUBLEJTACOMA
    DOUBLEJTACOMA Active Member
    Jeremy
    Jasper, Alberta
    Blacked out SR5
    -Black Halo Projector Headlights with HIDs -Black Billet Grille -Night Shaded Tail Lights -Exhaust (Magnaflow) -URD 2.7L Supercharger (soon, may need help)
  11. Feb 26, 2012 at 12:12 AM
    #111
    DOUBLEJTACOMA
    Jeremy
    Jasper, Alberta
    Blacked out SR5
  12. Feb 28, 2012 at 6:58 PM
    #112
    jpaw30
    jpaw30 Well-Known Member
    if you wash your car/truck in the winter there's a good chance the hood latch is all gunked up with garbage and the sensor is blocked up. Had a honda that did that all the time.
    Look for a sensor or wires going to the latch area and wipe them off.
  13. Mar 12, 2012 at 9:28 PM
    #113
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Been here on TW a while, but have been lurking and reading up more recently. I am a red seal technician and work for a Toyota dealer. I also own a 2010 TRD sport. It is currently 100% stock, and will be going through some changes soon. If anyone wants DIY threads, videos, or anything of the sorts. Let me know. I also have full access to all of Toyotas factory information. Pm me for any requests, questions, and I look forward to getting to know a lot of you.
    - S
  14. Mar 13, 2012 at 7:16 AM
    #114
    no mods
    cincinnati
    Some stickers
    I want to see the press/jig that removes the entire bearing (including inner race) when swapping a wheel bearing on a late model taco.
  15. Mar 13, 2012 at 10:08 AM
    #115
    1GR
    Scott
    BC, Canada
    I will get pictures of the jig today for you. The rest of the process will be with regular press+blocks etc. Will explain later with pictures. If I get a wheel bearing come in, I will do a step by step.
    front wb or rear seals/bearing?
  16. Mar 18, 2012 at 12:31 PM
    #116
    Lobster13
    Lobster13 Most give some, some give all!
    Josh
    New Mexico
    12 Sport 4x4 Barcelona Red w/ camper shell
    Fox 2.0 rear, Camburg UCAs and Camburg adj. coil overs. Avid sliders (thanks Big Dustin).
    Hello all. On Friday (16th) I got my first Taco, it's a 2012 Sport, 4dr SB 4x4. I'm looking to see what I can do to make a great truck awesome! I've heard great things about the magnaflow and flowmaster exhausts, anyone know how banks does on their product for the Taco?
    I'm also looking at air filters. I know K&N is a good choice but what is the best for the Taco?
    I've read some on here that say the supercharger hasn't come out yet for the 2012s but does anyone know what the milage would be on a Taco with the supercharger?
    Thanks for the help guys!
  17. Mar 19, 2012 at 8:05 PM
    #117
    Darth Tater
    Marlin
    Las Vegas, Nevada!!
    Supercharger=gas mileage will suck. You don't buy a S/C for mileage. On a positive note, you shouldn't have any trouble getting where you want to go, quickly.
  18. Mar 20, 2012 at 7:39 AM
    #118
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    I lost about 1-2 MPG when I installed it. currently I get around 15-16 mixed city / highway, but I have a lead foot...If you're on it a lot, you'll drink the tank dry in 140 miles or less, but if you do a lot of towing, your mileage will actually go up quite a bit while towing since you dont need as much pedal... Of course like Darth Tater said, you dont buy it for mileage, you install it for the grin factor :D
    Lycanistic likes this.
  19. Apr 9, 2012 at 9:46 PM
    #119
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
  20. Apr 24, 2012 at 3:56 PM
    #120
    Tacoma11
    Tacoma11 Member
    Sonny
    Houston
    2012 SR5
    Stock
    TcBob, is there a mod to keep the head lights from coming on when 2011 Taco is locked via key remote?
    I did the seat belt beep mod, that's a cool mod. Wife likes it to. No more beeping when out on the lease.
