Rust Prevention/Treatment Consolidation Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoGlenn, Dec 18, 2014.
  1. May 17, 2020 at 11:30 PM
    #101
    jrowe4321
    jrowe4321 Well-Known Member
    Justin
    Los Angeles
    09 prerunner access cab
    Just had my first winter with Fluid Film and it's held up well, just noticed that it did wear away around the wheel well areas. Guess it does come off easily.
  2. May 18, 2020 at 5:08 AM
    #102
    GQ7227
    GQ7227 mw survivor
    J A Y
    if i can prove that CorrosionX HD sprayed in the high-splash areas in the wheel wells will not allow moisture/salt slop through and flash rust metal
    from what i have going on currently in a test spot it looks to withstand some direct water blasts with the garden hose and even a bit at the diy powerwand wash
    it would seem hardcore stuff to stick but on the difficult side to remove, so probably slightly hazardous
    https://www.corrosionx.com/products/corrosionx-heavy-duty
    srspicer likes this.
  3. Jun 1, 2020 at 5:01 AM
    #103
    GQ7227
    GQ7227 mw survivor
    J A Y
    do ANY of these numerous topic thread links contain internal frame pics on the 1st gen taco
    i would like to compare the pics I am pulling out of mine to compare and see how bad or good it is and how to move forward with whats going on, ... trying to make some sense of it all :goingcrazy:
    i tried the compressed air hose in there yesterday in one section with a camera to see whats loose and needs to come out of there
    Whammo likes this.
  4. Jun 17, 2020 at 6:12 PM
    #104
    Yota4me
    Yota4me Active Member
    USSA
    charocal filter delete/kn intake, rear cat delete. horn mod, 20% tint front windows, bull bar, M1 Full Syn, black plasti dip emblems. Next up aero turbine 2525xl muffler
    Found a local guy that sprays used motor oil/cut with a little kerosene so it thins out for spray gun. I asked him what he recommended he said come back two more times. Then it builds up a nice layer of film. Then monitor from there. Used oil is key. Side note there was a 98 s10 there pa all its life. Flawless frame, not one spec of rust. Wish I learned of this sooner. Cheers!
  5. Jun 18, 2020 at 3:26 AM
    #105
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Sounds like a recipe for a Molotov-Taco. :rofl:
    JL911, Whammo and srspicer like this.
  6. Jun 26, 2020 at 10:16 AM
    #106
    helomech
    helomech Well-Known Member
    Bryan
    San Diego, CA
    '10 4wd TRD Sport DC LB
    20% Tint on all windows
    I work as a Corrosion Control tech rep for Navy/Marine Corps aircraft. We use a lot of the materials that OP listed out here.
    One key to preventing corrosion is understanding how it works. It's an electro-chemical process requiring 4 basic elements. An anode, a cathode, an electrolyte, and a conductive path for electron flow.
    Given our frames our an alloy, there is a mix of metals in there (anode and cathode). The electrolyte comes in the form of rinse water/wash solutions/rain and snow + salts on the road that pool up in places or are allowed to remain on the surface of the frame and hardware. Given the "painted" surface of the frame is thin and probably not very flexible, cracks in that coating are bound to happen.
    I know the general public uses name brand items, but the MIL-SPECS in the attached manual can be translated into commercial off the shelf products that the everyday person can find and purchase. Just google the MIL-SPEC and a commercial product will most likely pop up. The manual (tables in section 8) gives characteristics for each MIL-SPEC. Some will last longer than others and all are dependent on environmental conditions your truck lives in. May help you make a more informed choice on what materials you choose to apply to your truck frame. ‍
    PS The attached website links to an open source document so there is no issue with classification.
    http://everyspec.com/USN/NAVAIR/NAVAIR_01-1A-509-2_CHG-1_31MAR2010_51497/
    Hay Lobos, Whammo, Kirky and 4 others like this.
  7. Nov 29, 2020 at 11:25 PM
    #107
    Smithgun2020
    Smithgun2020 2017 Tacoma TRD Sport
    JON
    South West Georgia
    White, 2017 TRD Sport-2 WD
    ranch hand grill, toolbox, light bar, flash pattern warning/emergency lights, no major suspension work
    Try Flex Shield Spray, the water sealant. It sprays on easily and gives a good thick coat that is durable. On my 2017 Black Taco, I used it to cover spots of paint spillage or other discoloration. It held up to a metal toolbox sliding around on it so I know it is tough. Leaves a rubberized surface. If it will stop leaks it should seal underbody metal.
    eherlihy likes this.
  8. Jan 26, 2021 at 1:45 PM
    #108
    Armystrong
    Armystrong Member
    Jim
    2021 Tacoma SR5 DCLB 4x4
    I have a 2 week old 2021 Tacoma. Should I take preventive measures and spray the underside, recommended product that you have experience with?
    deusxanime likes this.
  9. Jan 26, 2021 at 1:51 PM
    #109
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I would if you live in a rust state.
  10. Jan 26, 2021 at 2:10 PM
    #110
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    If you live in a state that has winter and "salts" the road, then I'd say you should.
    Recommended to use a wax or oil based solution, NOT rubberized. Usually Fluid Film or a Woolwax coating is recommended, with touch ups at least once a year in the fall.
  11. Jan 26, 2021 at 9:30 PM
    #111
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Absolutely and fluid film is Great but if you’re in Canada just go to a Krown shop and have it sprayed
  12. Jan 26, 2021 at 9:38 PM
    #112
    Markcal
    Markcal Well-Known Member
    This paragraph on page #112 sums up our Tacoma frame rust problems:"Studies conducted by the U.S. Army Tank-Automotive Command show that the life cycle costs of rustproofing, rust damage, and repair are greater than the potential costs of designing a vehicle to avoid corrosion without supplementary rustproofing agents."
  13. Feb 18, 2021 at 9:25 PM
    #113
    Tmbrwolfe
    Tmbrwolfe Member
    Ron
    TRD OR access cab 4x4
    I guess all I have to do is read every article in Glen's bibliography. By the time I am done I will be 90 and my '21 TRD will still be high and dry in the garage without a spot of rust!
    That looks like many man-hours of wisdom. Someone should get Gutenberg to print it
    stonybrook likes this.
  14. Mar 25, 2021 at 12:42 PM
    #114
    psubrew
    psubrew Member
    2021 Cement TRD OR
    I just came out of my first winter on my new truck. I did Fluid Film pretty heavy back in early November before we had snow. I am pretty happy with the outcome, there is still a substantial coating in most places I sprayed, and no rust issues of note. I live in a salt-heavy state and we had a fairly hard winter.
    I sprayed with a compressor from a 1 gallon can. I think I used a bit over 1/2 gallon total. I plan to hit it again this fall for extra protection.
    ontarioyota likes this.
  15. Mar 25, 2021 at 1:11 PM
    #115
    spitdog
    Yep, do it every fall. I now use about 1/3 gal every fall
    ontarioyota and psubrew[QUOTED] like this.
  16. Apr 24, 2021 at 12:32 AM
    #116
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    Do you offroad? How clean do you have to have the under carriage before reapplying?
    Marc70 likes this.
  17. Apr 24, 2021 at 3:17 AM
    #117
    spitdog
    Just use a pressure washer if you have a lot of dirt or mud, I have a cheap 1700psi washer and it works fine. Let it dry a few days.
    If it’s not really dirty don’t bother.
  18. Apr 24, 2021 at 4:21 AM
    #118
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    x2 for Krown. I remove my spare when I take it in to get sprayed. Going forward, I will also be removing the splash guard under the engine when I take it in. Just makes it possible for them to get access to more spots to coat more metal.
  19. Sep 23, 2021 at 12:32 PM
    #119
    ahoy
    ahoy Well-Known Member
    '22 TRD Off Road
    This is an awesome thread. Thanks OP for all the work it took to compile all of that.
    May I ask, before my '22 Tacoma arrives, is anyone aware of rust-related failure issues or "trouble spots" on body panels of the 3rd gen Tacoma?
    The reason I ask that is, I live in South Dakota, where literally every car on the road has rust underneath. My trusty '11 Xterra that I bought new has surface rust all over the underside, which we view as no big deal here but someone living in LA might be horrified by it. I fully expect my truck to develop surface rust underneath, but if there are specific areas that could compromise the frame or body panels, I'd love to know which spots to look out for.
  20. Sep 23, 2021 at 3:07 PM
    #120
    JAGCanada
    Canada
    If you take the necessary steps, you won't get surface rust. I painted my underside when I got it new 11+ years ago and have had it sprayed each year by Krown. In between, theres been a little rust that I have cleaned up and repainted. Truck has spent its whole life in Canada. Don't know anything about 3rd Gens, but this approach isn't vehicle specific.
    WNYTACOMA, srspicer, ahoy and 4 others like this.
